mozzwald Posted July 27, 2020 Author Share Posted July 27, 2020 1 minute ago, DrVenkman said: So I received my FujiNet today - yay! Unfortunately, I can't seem to get the #Config utility to let me enter an SSID for my home LAN. As it loads, it's trying to connect to "thegrid" which I presume is @mozzwald's home or test network. The Github test plan/documentation says to press X to enter a new SSID/password but that gets no response. What am I doing wrong? Whoops, I must have forgot to do a clean flash after testing. You can use the flash utility from https://fujinet.online/download/ to get the latest firmware. 1 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 27, 2020 Share Posted July 27, 2020 1 hour ago, mozzwald said: Whoops, I must have forgot to do a clean flash after testing. You can use the flash utility from https://fujinet.online/download/ to get the latest firmware. No worries. I figured it out from a different part of the Git wiki (SELECT during device boot loading.) This was loaded from FujiNet over the internet. Waaaay coo! EDIT: the new Windows binary for the TNFS server works a treat. 5 Quote Link to comment Share on other sites More sharing options...
+selgus Posted July 28, 2020 Share Posted July 28, 2020 Received my FujiNet device today, in it's nice XE-style case.. along with a cool FujiNet pin! Thanks! Now I need to find some time to play around with it, and make sure my BIOS plays nicely with the device. 3 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 28, 2020 Share Posted July 28, 2020 We had a tester mention that the DOS 2.0 disk image provided for the local SD flash test: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Testing-local-SD-Card-Storage was corrupted. This has been verified, and a replacement DOS 2.0S image has been placed inside the ZIP and tested, and noted on the test page. Thanks! 2 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 4, 2020 Author Share Posted August 4, 2020 Here is a quick run down of the issue regarding FujiNet and the 1088XEL system originally described in the FujiNet Troubleshooting thread. FujiNet fails to boot properly on the 1088XEL due to the internal SIO2PC/Sparkfun FTDI FT232R that resides on the SIO bus which has no open collector buffer or diode on the DATAIN line. @mytek explains it well: Quote It isn't a fully isolated device apparently, and seems to be exhibiting some pullup of the SIO signal lines it connects to. This isn't a problem with most other Atari SIO peripherals which have a strong ability to sink their signals to ground. However devices that use a diode to achieve an open collector output such as FujiNet will struggle to pull the signal low enough to look like a proper communication is being sent. One way to fix the issue is by adding a Schottky diode to the Sparkfun board by cutting the TX trace and soldering a SMD diode in place like @Mr Robot has done. A diode with a low forward voltage is recommended (PMEG2010ER, BAT60AE6327HTSA1, MBR120VLSFT3G). I realize this is not an option for everyone so I will investigate using an open drain buffer on the next batch of FujiNets instead of the currently used diode. This should remedy the issue without needing to modify the 1088XEL. In addition to this, there have been reports of FujiNet not working with the Lotharek SIO Splitter/Hub which I suspect is a similar issue. @DrVenkman or @Mr Robot do you happen to have one of those? 1 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 4, 2020 Share Posted August 4, 2020 1 minute ago, mozzwald said: In addition to this, there have been reports of FujiNet not working with the Lotharek SIO Splitter/Hub which I suspect is a similar issue. @DrVenkman or @Mr Robot do you happen to have one of those? I do not, I'm afraid. Sorry! Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted August 4, 2020 Share Posted August 4, 2020 Sorry no I don't Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 5, 2020 Share Posted August 5, 2020 (edited) f*ck, select during power on/reset get's the MIO config screen... grrrrr. why does every device these days use already used and established console/hot keys... there are so many other combos to choose from... maybe it's time for a 'commonly in use' hot key chart... Edited August 5, 2020 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
tschak909 Posted August 5, 2020 Share Posted August 5, 2020 wait a moment before pressing select, as it's checked when the config program starts. -Thom Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 5, 2020 Share Posted August 5, 2020 That'll work, notation added. Quote Link to comment Share on other sites More sharing options...
Fierodoug5 Posted August 5, 2020 Share Posted August 5, 2020 20 hours ago, mozzwald said: In addition to this, there have been reports of FujiNet not working with the Lotharek SIO Splitter/Hub which I suspect is a similar issue. @DrVenkman or @Mr Robot do you happen to have one of those? On my wroom unit, the splitter/hub works fine on my 800xl.(that's the way I have had it hooked up since I built fujinet) Fujinet will NOT boot with a 800 and splitter/hub, even if it is the only sio device plugged in. 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 5, 2020 Author Share Posted August 5, 2020 5 minutes ago, Fierodoug5 said: On my wroom unit, the splitter/hub works fine on my 800xl.(that's the way I have had it hooked up since I built fujinet) Fujinet will NOT boot with a 800 and splitter/hub, even if it is the only sio device plugged in. Plot thickens. Any way you could add a buffer chip in the mix to see if it fixes the issue with the 800? I ordered some some today and will do some testing soon. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 5, 2020 Share Posted August 5, 2020 If the device works on the 800 all by itself and with other Atari peripherals... but will not with that particular splitter... I'd blame the splitter... it's modifying something not according to standard... People have reported that the splitter helped them achieve divisor zero on machines that still have filter caps on them (XL/XE) when it won't reach that divisor without the splitter... that indicates slew/rise/fall are modified in some way... anyone looked at the splitter and see what it's made of? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 9, 2020 Author Share Posted August 9, 2020 I received some line buffers today in the mail and whipped up a fugly bodgeriffic FujiNet using a little breakout board, resistors, wire and a SN74LVC2G07. It works fine on my 800XL. Just need a 1088XEL to test it on.... 4 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 9, 2020 Share Posted August 9, 2020 That first pic reminds me of something ... Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 9, 2020 Author Share Posted August 9, 2020 11 minutes ago, DrVenkman said: That first pic reminds me of something ... Yes, I had similar thoughts... 1 4 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 11, 2020 Author Share Posted August 11, 2020 As promised, I have released all the design file for the FujiNet 1.0 hardware, released under the CERN 2.0 Open Hardware License. https://github.com/FujiNetWIFI/fujinet-hardware 10 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted August 12, 2020 Share Posted August 12, 2020 Are SIO transfers ever faster than floating point calculations? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted August 14, 2020 Share Posted August 14, 2020 #FujiNet is now certified by OSHWA as Open Source Hardware! Congratulations @mozzwald! https://certification.oshwa.org/us000651.html -Thom 9 Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted August 16, 2020 Share Posted August 16, 2020 On 8/8/2020 at 8:38 PM, mozzwald said: I received some line buffers today in the mail and whipped up a fugly bodgeriffic FujiNet using a little breakout board, resistors, wire and a SN74LVC2G07. It works fine on my 800XL. Just need a 1088XEL to test it on.... Do you have a schematic that I can use to test with? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 16, 2020 Author Share Posted August 16, 2020 20 minutes ago, Dropcheck said: Do you have a schematic that I can use to test with? I'm still working on the next revision based on feedback from the first batch. The below image shows the fix used in that abomination. Other changes being worked on: push/push uSD socket instead of push/pull Replace hard RESET button with another GPIO based button for safe reset 3 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 16, 2020 Author Share Posted August 16, 2020 On 8/14/2020 at 2:46 PM, tschak909 said: #FujiNet is now certified by OSHWA as Open Source Hardware! Congratulations @mozzwald! https://certification.oshwa.org/us000651.html -Thom Indeed it is. I have added the certification mark and logo to the PCB design at https://github.com/FujiNetWIFI/fujinet-hardware 4 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 16, 2020 Share Posted August 16, 2020 3 minutes ago, mozzwald said: Indeed it is. I have added the certification mark and logo to the PCB design at https://github.com/FujiNetWIFI/fujinet-hardware Nice! I just built a pair of these Retroshields yesterday from 8BitForce and noticed the same mark on the PCBs. 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 28, 2020 Author Share Posted August 28, 2020 I got the v1.1 boards and built one unit. All is well in my testing so far. A 1088XEL user is already lined up to get one and give it a full test. I still need to add support for the new gpio button in the firmware. This button is in place of hard reset and will be used for "safe reset" by unmounting the uSD card before doing a soft reset. Code will be able to detect new button due to it being pulled up so the same firmware will work for 1.0 and 1.1 boards. Hard reset has been moved to a snap dome pad on the front near the SIO LED. I likely wont populate it in production as you can power off/on the FujiNet to get the same functionality. I did not change the uSD socket to a push/push style. I could not find a socket small enough to fit in the same spot as the current one. This upgrade will require putting the socket on the opposite side and a case modification. 10 Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted August 28, 2020 Share Posted August 28, 2020 unbelievable cool!!!! 1 Quote Link to comment Share on other sites More sharing options...
