_The Doctor__ Posted August 30, 2021 Share Posted August 30, 2021 (edited) You can not plug both svideo and composite at the same time on the same cables. choose one or the other. Are you sure the svideo cable is using only luma and chroma? Edited August 30, 2021 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 30, 2021 Share Posted August 30, 2021 Ok - only one plug, but when I connect only S-VIDEO on stock setting (no uav), screen is also blurred - when switch to UAV + S-VIDEO - all is OK. I use cable from Lotharek and work fine on S-VIDEO on my other two Atari 65XE. Another question, how work battery backup? I load some game, toggle power off / on and nothing was restored xkabel.PNG.pagespeed.ic.ghl5-8ANfu.webp Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 30, 2021 Share Posted August 30, 2021 (edited) check the standard video circuit for correctness etc (smoothing caps etc.) on the main/motherboard of the Atari... also the lotherik s-video cable is poor... try one from hercules workshop.... much better. the UAV puts out a much better signal and handles noise/interference/reflections much better than the built in Atari circuits. some quick pictures of those areas would help Edited August 30, 2021 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 30, 2021 Share Posted August 30, 2021 (edited) you can tell me which block it contains standard video circuit with smoothing caps? i also think about battery backup, why not work Edited August 30, 2021 by Santyago Quote Link to comment Share on other sites More sharing options...
santosp Posted August 30, 2021 Author Share Posted August 30, 2021 @Santyago The UAV add are there to give you the better video signal. Why dont forget the old one from Atari, and remain with this? I think that the battery is to preserve data in the extended ram, but not in the base one. So isn't possible to boot your Atari with a game loaded. Please take a look here. Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 30, 2021 Share Posted August 30, 2021 @santosp yes, i know uav is better, but nice to have full working pcb Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 31, 2021 Share Posted August 31, 2021 (edited) No Sophia2 compatibility connector to DVI? Original board with DVI connector from Sophia2 has different connections instead on PCB Edited August 31, 2021 by Santyago Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 31, 2021 Share Posted August 31, 2021 (edited) I redraw DVI circuit form main board and compare with original DVI board from Sophia 2 * missing TMDS Data Shield 0,1,2 (DVI pins 3, 11 & 19) - on original board is connected to GND * missing TMDS Clock Shield (DVI pin 22) - on original board is connected to GND * missing hot plug detect (DVI pin 16) - on original board is connected to +5V like pin 14 without this I have issue with detect video mode on iiyama prolite E2271HDS Edited August 31, 2021 by Santyago 1 Quote Link to comment Share on other sites More sharing options...
santosp Posted August 31, 2021 Author Share Posted August 31, 2021 3 hours ago, Santyago said: No Sophia2 compatibility connector to DVI? Original board with DVI connector from Sophia2 has different connections instead on PCB I use for the design what I found as connection between the two connectors in this file! There it describe what is included generally in a DVI connector, and which from these signals must be connected between the two connectors. I follow exact this. ? Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 31, 2021 Share Posted August 31, 2021 no problem, easy to fix by wire connect on dvi pins 1 Quote Link to comment Share on other sites More sharing options...
Santyago Posted August 31, 2021 Share Posted August 31, 2021 Here is my fix for shield and hot plug detect Quote Link to comment Share on other sites More sharing options...
Santyago Posted September 1, 2021 Share Posted September 1, 2021 U1mb will work if sram extension has been disabled on switches? Quote Link to comment Share on other sites More sharing options...
adam242 Posted September 2, 2021 Share Posted September 2, 2021 (edited) Progress! I suspected a bad FREDDIE since this was the only donor chip I could not test. A replacement from Best Electronics was ordered and my board now boots up as it should! My stock video is quite blurry, similar to what @Santyago is experiencing, but UAV is nice and crisp, so I'm not going to worry about it. After testing with jumpers in U34 socket at first, I have now flashed my GAL and installed the memory expansion. All is still happy. Edited September 2, 2021 by adam242 more progress 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 2, 2021 Share Posted September 2, 2021 are we using darlington transistors in the video circuit... if not please see myteks explanations of what he discovered when making his pcbs and upgraded video circuits etc.. Quote Link to comment Share on other sites More sharing options...
Crc_Error Posted September 2, 2021 Share Posted September 2, 2021 Sorry if I don't understand this great project. Is this an updated version of the 130XE with the latest addons one can build? I tried reading the whole thread but got overwhelmed. This remake board fits in a 130XE or 65XE case with the ECI port? Also is there a website where one can buy this board? Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 2, 2021 Share Posted September 2, 2021 The board is a 130XE remake, that is mostly just a duplication, but also UAV has been added on board, as well as a 512k Ram upgrade, also a TK-II interface is available (not mandatory), which allows you to hook up a PS/2 Keyboard. Technically it's remake of the 65XE, because it only has 64k Dram, if you don't use the 512k upgrade. It does need a case with an ECI port. Santosp only made a few runs of the board, supposedly some are also available through ABBUC, but I hadn't heard any info other than that. Quote Link to comment Share on other sites More sharing options...
Crc_Error Posted September 3, 2021 Share Posted September 3, 2021 Thank you so much for your reply. Absolutely great project. Will look around to see if its still available. But then if I do find it I'll need a case..... Quote Link to comment Share on other sites More sharing options...
+skr Posted September 4, 2021 Share Posted September 4, 2021 On 9/3/2021 at 4:20 AM, Crc_Error said: Thank you so much for your reply. Absolutely great project. Will look around to see if its still available. But then if I do find it I'll need a case..... And you need all the Atari Chips (Sally, ANTIC, POKEY etc.). Panos batch is sold out, only official way of getting one is through ABBUC. If interested, check with @Yellow_Man, who runs the shop, if they´re still available. When they´re gone, the only way to get one would be "second hand" via eBay etc. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 5, 2021 Share Posted September 5, 2021 2 hours ago, skr said: When they´re gone, the only way to get one would be "second hand" via eBay etc. At that time, I'll be selling the two that I have for $2,000 each. Haha... Quote Link to comment Share on other sites More sharing options...
adam242 Posted September 5, 2021 Share Posted September 5, 2021 After purchasing a TL866ii just for this project and successfully flashing the memory GAL and BASIC ROM, I was very disappointed to find this device won't program the PIC for the TransKey II expansion. If anyone here is able and willing to program this chip for me (I'll gladly pay for your time and return postage), please PM me. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted September 5, 2021 Share Posted September 5, 2021 15 minutes ago, adam242 said: After purchasing a TL866ii just for this project and successfully flashing the memory GAL and BASIC ROM, I was very disappointed to find this device won't program the PIC for the TransKey II expansion. If anyone here is able and willing to program this chip for me (I'll gladly pay for your time and return postage), please PM me. PM sent 1 Quote Link to comment Share on other sites More sharing options...
+LarryL Posted September 6, 2021 Share Posted September 6, 2021 On 8/27/2021 at 11:56 PM, santosp said: @Krenath 3. Remove the unnecessary components from PAL clock feed area. https://atariage.com/forums/topic/319881-atari-xe-remake-pre-order-thread/?do=findComment&comment=4846113 Hi, I am preparing to populate the board (during next 4 weeks) as PAL set-up Is there an overview existing, which components are unnecessary for PAL? I have only seen the "unnecessary for NTSC" list inside this thread cheers Michael Quote Link to comment Share on other sites More sharing options...
santosp Posted September 6, 2021 Author Share Posted September 6, 2021 @LarryL Only a zero ohm resistor, which mark as "'NTSC only". Quote Link to comment Share on other sites More sharing options...
+LarryL Posted September 6, 2021 Share Posted September 6, 2021 36 minutes ago, santosp said: @LarryL Only a zero ohm resistor, which mark as "'NTSC only". Excellent, that’s really easy ? thanks @santosp Quote Link to comment Share on other sites More sharing options...
Santyago Posted September 7, 2021 Share Posted September 7, 2021 Hint. U1MB works great 1 Quote Link to comment Share on other sites More sharing options...
