+DjayBee Posted April 5, 2023 Share Posted April 5, 2023 On 4/4/2023 at 4:17 PM, SoulBuster said: Requires OS-B. I did not figure out how to run. if you do, please post back. It needs BASIC Rev.A. Then you have an additional command RENUMBER. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 5, 2023 Author Share Posted April 5, 2023 Tricky Tutorial #01 Display Lists (1981)(Educational Software)(US)[BASIC][cassette] Clean recording of side B. I could not get side A. Tricky Tutorial #01 Display Lists (1981)(Educational Software)(US)[BASIC][cassette].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 5, 2023 Author Share Posted April 5, 2023 APX 20086 - Ultimate Renumber Utility (1981)(APX)(US)[OS-B][BASIC Rev. A][disk] APX 20086 - Ultimate Renumber Utility (1981)(APX)(US)[OS-B][BASIC Rev. A][disk] Set #2 The above has been updated with the correct instructions to load. Thanks @DjayBee 2 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted April 5, 2023 Share Posted April 5, 2023 On 4/4/2023 at 4:01 PM, SoulBuster said: Requires BASIC. I do not know how to configure Altirra to boot it. Please reply with your configuration if you can get it to boot. This is the Atari release which has copy protection. Did your dump have a bad sector 367 (track 20, sector 7) which you "repaired"? Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted April 5, 2023 Share Posted April 5, 2023 On 4/3/2023 at 10:55 PM, SoulBuster said: APX 20042 - Financial Asset Management (1981)(APX)(US)[BASIC][disk] The ZIP contains only your "Financial Asset Management.txt" file. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 5, 2023 Author Share Posted April 5, 2023 36 minutes ago, DjayBee said: This is the Atari release which has copy protection. Did your dump have a bad sector 367 (track 20, sector 7) which you "repaired"? No. That is a clean recording. I did not do any repairs. I recorded it again just now and it comes out clean, no bad sectors. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 5, 2023 Author Share Posted April 5, 2023 21 minutes ago, DjayBee said: The ZIP contains only your "Financial Asset Management.txt" file. APX 20042 - Financial Asset Management (1981)(APX)(US)[BASIC][disk] The above has been updated to include all assets. There is probably more as I went through these very quickly. Thanks @DjayBee 2 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 6, 2023 Author Share Posted April 6, 2023 Analog #62 ANALOG Computing #62 (1988-07)(ANALOG Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 6, 2023 Author Share Posted April 6, 2023 Analog #63 has been updated. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 7, 2023 Author Share Posted April 7, 2023 Analog #64 has been updated. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 7, 2023 Author Share Posted April 7, 2023 Analog #65 has been updated. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 7, 2023 Author Share Posted April 7, 2023 POOF (1991-10)(Tim Naber & Barry Gordon)(US)[BASIC XE][disk] I am not sure if anyone is interested in a way to fill sectors of a disk with a character, but back in the day I needed one, so I wrote one. Barry Gordon helped me with the ML. It makes no sense to keep it to myself. It uses BXE with the extension disk. POOF (1991)(Tim Naber & Barry Gordon)(US)[BASIC XE][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 7, 2023 Author Share Posted April 7, 2023 Block Buster (1981)(APX)(US)[disk] Boot without BASIC. Requires OS-B. Block Buster (1981)(APX)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 7, 2023 Author Share Posted April 7, 2023 Home Accountant, The (1983)(Continental Software)(US)[Includes v1.1][BASIC][disk] Includes an additional disk labeled v1.1 Home Accountant, The (1983)(Continental Software)(US)[Includes v1.1][BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 8, 2023 Author Share Posted April 8, 2023 Analog #66 - (Disk 1 Sourced from A8SP) SLAVE2.BAS on disk 1 is the completed program. SLAVELNS.BAS on the additional disk creates lines 5820,5840,5860 and 5880 that are then entered into the base program SLAVE2.BAS, which is also on the additional disk. The listing in the magazine does not match what is on disk. There were several lines that were typed in with POKE 82,0 and are extra long. With the lines this way, you cannot verify the listing, so the publishers made changes to the listing to make them compatible with BASIC EDITOR II and you would be able to verify. I made a file called SLAVEMAG.BAS that matched the listing in the magazine. ANALOG Computing #66 (1988-11)(ANALOG Magazine Corp.)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 8, 2023 Author Share Posted April 8, 2023 Analog #67 has been updated. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 8, 2023 Author Share Posted April 8, 2023 APX 20263 - Burgers! (1983)(APX)(US)[disk] - New package! Boot without BASIC. APX 200263 - Burgers! (1983)(APX)(US)[disk].zip Burgers! Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 9, 2023 Author Share Posted April 9, 2023 Crossword Magic (1985)(Mindscape)(US)[disk] - Includes untested C64 files. New Package. Boot without BASIC. Crossword Magic (1985)(Mindscape)(US)[disk].zip Crossword Magic Manual.pdf Crossword Magic Reference Card.pdf Crossword Magic Warranty.pdf Mindscape Catalog.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 9, 2023 Author Share Posted April 9, 2023 APX 20258 - Bellum 1.0 (1983)(APX)(US)[disk] - New Package. Boot without BASIC. APX 20258 - Bellum 1.0 (1983)(APX)(US)[disk].zip Bellum 1.0 Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 9, 2023 Author Share Posted April 9, 2023 APX 20272 - Bumpomov's Dogs 1.1 (1983)(APX)(US)[disk] - New Package Boot without BASIC. APX 20272 - Bumpomov's Dogs 1.1 (1983)(APX)(US)[disk].zip Bumpomov's Dogs 1.1 Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 10, 2023 Author Share Posted April 10, 2023 Analog #68 has been updated! 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 10, 2023 Author Share Posted April 10, 2023 Analog #69 has been updated! 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 10, 2023 Author Share Posted April 10, 2023 Analog #70 has been updated! 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 10, 2023 Author Share Posted April 10, 2023 Colossus Chess v4.0 (1987)(CDS Software)(GB)[cassette] - New Package. Autoboot cassette without BASIC. Colossus Chess v4.0 (1987)(CDS Software)(GB)[cassette].zip Colossus Chess 4.0 Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 11, 2023 Author Share Posted April 11, 2023 Analog #71 has been updated! 2 Quote Link to comment Share on other sites More sharing options...
