+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 Database Dialer (1981)(Santa Cruz Educational Software)(US)[cassette] Database Dialer (1981)(Santa Cruz Educational Software)(US)[cassette].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 Tricky Tutorial #15 - Fancy Fonts (1983)(Santa Cruz Educational Software)(US)[cassette] Tricky Tutorial #15 - Fancy Fonts (1983)(Santa Cruz Educational Software)(US)[cassette].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 Fonetone (198x)(Santa Cruz Educational Software)(US)[cassette] Fonetone (198x)(Santa Cruz Educational Software)(US)[cassette].zip 3 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted March 30, 2023 Share Posted March 30, 2023 Thanks, very happy to see these Educational Software programs finally archived! 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 31, 2023 Author Share Posted March 31, 2023 Tricky Tutorial #11 The Memory Map Tutorial (1983)(Santa Cruz Educational Software)(US)[cassette] After several attempts, lesson 4 always turns out bad on the 39th block of the data. There is no visual defect on the tape. Tricky Tutorial #11 The Memory Map Tutorial (1983)(Santa Cruz Educational Software)(US)[cassette].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 1, 2023 Author Share Posted April 1, 2023 Great Classics (1979)(Atari)(US)[cassette] These cassettes were in very bad shape. After a lot of cleaning, physically repairing and re-recording, this is the best I could get out of them. Lesson 1 - 7:40 glitch Lesson 2 glitch 15:40 Lesson 2 glitch 16:42 Lesson 2 glitch 18:38 Lesson 2 glitch 21:18 Lesson 2 glitch 22:20 Lesson 3 glitch 8:17 Lesson 4 glitch 16:25 Lesson 5 glitch 10:54 Lesson 14 glitch 17:55 Lesson 15 glitch 2:01 Lesson 15 glitch 5:42 Lesson 15 glitch 5:48 Lesson 16 glitch 11:40 Great Classics Cassette A.zip Great Classics Cassette B.zip Great Classics Cassette C.zip Great Classics Cassette D.zip Great Classics All Other Assets.zip Great Classics Catalog Rev. 4.pdf Great Classics Warranty.pdf 4 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 1, 2023 Share Posted April 1, 2023 (edited) I can't understand how all of these are full of glitches, I don't remember so much BITD, a rarity. I'd suppose the only way to fix is to correct what's wrong and remaster them. So odd. edit ** oh I see some of them had extensive cleaning needed and other issues. I sure hope your endeavor succeeds. Edited April 1, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 1, 2023 Author Share Posted April 1, 2023 1 hour ago, _The Doctor__ said: I can't understand how all of these are full of glitches, I don't remember so much BITD, a rarity. I'd suppose the only way to fix is to correct what's wrong and remaster them. So odd. When the source of a cassette or disk is eBay and since these are 40 years old +-, here is the kind of damage you run into: Sun warped or stretched. Dust has collected. Something spilled on it. A magnet erased it. Starts to disintegrate. Actual physical damage applied. I try to save every single one. Sometimes it does not work and sometimes I get a partial that could help verify another recording. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 2, 2023 Author Share Posted April 2, 2023 Analog #58 CASTAWY1.BAS is the game of Castaway. CASTAWY2.BAS is the program to setup the different rooms. An ATR has been setup with the game and is included. The Wizard is an adventure creator program. It is split between issue #58 and #59. I made an attempt to set it up, but when I was typing in the commands it stated that the command was in use. For now, I am including the files as they are shown in the magazine. At a later date I will try to get it all setup and provide an ATR. All the files for Troll War are on the disk for issue #57, including the compiled game. I left TROLL16.M65 on this disk as it was that way when issued, even though this is a non-original disk. ANALOG Computing #58 (1987-10)(ANALOG Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted April 2, 2023 Share Posted April 2, 2023 On 3/27/2023 at 8:59 PM, SoulBuster said: BackTalk 1.2 (1986)(Antic Software)(US)[disk] I recorded it 3 times. Each time the bad sectors are the same. The -p option does nothing. Did Antic use copy protection? Yes, they did in some cases but not here. (Actually the disk contains only one bad sector.) Data of your dump is identical to Atarimania's dump which I used to fix your ATX: Backtalk v1.0 (1985)(Antic Software)(US)(Side A)[f].atx Backtalk v1.0 (1985)(Antic Software)(US)(Side A)[f].atr But having said that: Track 30 misses sector 18 (=578) but contains two identical instances of sector 16 (=576). The second instance of 16 is in the exact position where sector 18 should be (and also where I would expect a second instance for copy protection). But the missing sector 578 is part of AUTORUN.SYS and therefore may not be bad! Your disk might be a mastering error. Accidentally overwriting a sector is easy and common place but changing a sector's header definitely is not, much less doing it in a way which leads to a good sector. Perhaps @ijor can have a look at the SCP file contained in your inital posting. 2 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 2, 2023 Author Share Posted April 2, 2023 I updated the original zip with the new files. Thanks @DjayBee. BackTalk 1.2 (1986)(Antic Software)(US)[disk] 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 Analog #59 STRPATCH.BAS from Reader's Comments is a patch for Streamliner from issue #56. CWLIST7.LST is a fix for listing #7 of Checkwriter from Issues 27 and 28 and other fixes from issue #53. WIZFRAME.BAS and WIZCOMP.BAS are part of The Wizard adventure creator. These files are as typed, but it has problems. Leaving for now as they match the listing in the Magazine. I will set up a proper ATR at a later date when I have time to figure the system out. PRESENT1.BAS does not include the lines that are created PRESLINE.BAS. PRESENT2.BAS includes the lines of code generated by PRESLINE.BAS. ANALOG Computing #59 (1988-04)(ANALOG Magazine Corp.)(US)[BASIC].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 Analog #60 NFL.LST from Reader's Comments is a correction to NFL Game Analyzer from issue #57 QSMENU.BAS creates the file QSMENU.PGE. QSSTRING.BAS creates SQUEEZE.DAT. SQUEEZE.DAT is entered into QUICK.BAS to add the ML lines. QUICK.BAS matches the magazine listing and QUICKSCR.BAS is the completed program. ANALOG Computing #60 (1988-05)(ANALOG Magazine Corp.)(US)[BASIC].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20002 - Text Formatter (FORMS)(1981)(APX)(US)[BASIC][disk] Set #2 RUN"D:FORMS" Text Formatter (FORMS) Set #2.zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20004 - Outlaw/Howitzer (1979)(APX)(US)[disk] Boot into Atari DOS 2.5 without BASIC and load with the "L" command. APX 20004 - OutlawHowitzer (1979)(APX)(US)[disk].zip 4 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20006 - Preschool Games (1981)(APX)(US)[BASIC][disk] Has three bad sectors in non-critical areas. -p does not correct. Load programs from BASIC APX 20006 - Preschool Games (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20008 - BASIC Program Compressor (MASHER) (1981)(APX)(US)[BASIC][disk] RUN"D:MASHER APX 20008 - BASIC Program Compressor (MASHER) (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20009 - BASIC Cross-Reference Utility (XREF)(1981)(APX)[BASIC][disk] RUN"D:XREF or RUN"D:XREF.PRT APX 20009 - BASIC Cross-Reference Utility (XREF)(1981)(APX)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20010 - Disk Fixer (FIX)(1981)(APX)(US) Boot without BASIC, use the "L" command to load FIXDMP APX 20010 - Disk Fixer (FIX)(1981)(APX)(US).zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20012 - Variable Changer (1981)(APX)(US)[BASIC][disk] RUN"D:VARCNR.APX" APX 20012 - Variable Changer (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20013 - Newspaper Route Management (1981)(APX)(US)[BASIC][disk] RUN"D:PAPER.APX APX 20013 - Newspaper Route Management (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20014 - Computerized Card File (1982)(APX)(US)[BASIC][disk] Set #2 RUN"D:CCF" APX 20014 - Computerized Card File (1982)(APX)(US)[BASIC][disk] Set #2.zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20015 - Space Trek (1981)(APX)(US)[BASIC][disk] RUN"D:SPACTREK APX 20015 - Space Trek (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20036 - BASIC Utilities Diskette (1981)(APX)(US)[BASIC][disk] RUN programs from BASIC. APX 20036 - BASIC Utilities Diskette (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 3, 2023 Author Share Posted April 3, 2023 APX 20037 - Load 'N Go (1981)(APX)(US)[BASIC][disk] RUN"D:LOADGO APX 20037 - Load 'N Go (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
