+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Text Formatter (FORMS)(1981)(APX)(US)[BASIC][disk] RUN"D:FORMS" Text Formatter (FORMS)(1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Keypad Controller (1982)(APX)(US)[OS-B][BASIC][disk] Autoboots driver? and needs OS-B for it to load. RUN"D:CHANGE.BAS" Keypad Controller (1982)(APX)(US)[OS-B][BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Letterman (1981)(APX)(US)[BASIC][disk] RUN"D:LTTRMAN" Letterman (1981)(APX)(US)[BASIC][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Midas Touch, The (1982-06)(APX)(US)[BASIC][disk] Midas Touch, The (1982-06)(APX)(US)[BASIC][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Musical Computer (1981)(APX)(US)[BASIC][disk] RUN"D:MUSCOM1" or RUN"D:MUSCOM2" Musical Computer (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Renumber Utility (1981)(APX)(US)[BASIC][disk] RUN"D:RENUMBER" Renumber Utility (1981)(APX)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 RPN Calculator Simulator (1982)(APX)(US)[BASIC][disk] RPN Calculator Simulator.zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 Chameleon CRT Terminal Emulator (1981)(APX)(US) RUN"D:LIZARD" Chameleon CRT Terminal Emulator (1981)(APX)(US).zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 24, 2023 Author Share Posted March 24, 2023 APX 20086 - Ultimate Renumber Utility (1981)(APX)(US)[OS-B][BASIC Rev. A][disk] Requires OS-B and BASIC Rev. A, then type RENUMBER. APX 20086 - Ultimate Renumber Utility (1981)(APX)(US)[OS-B][BASIC Rev. A][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted March 25, 2023 Share Posted March 25, 2023 On 3/21/2023 at 3:27 AM, SoulBuster said: Three-R-Math System 20133 (pt 1) Three-R-Math.Student Disk (1982)(APX)(US)[disk] I recorded this a couple of times and came up with the same, unalterable errors. Even the option for -p does not change them. The disk loads and seems to work correctly. So here we are. Data goes only from track 0-18 plus the directory on track 19. The unformatted tracks are 25-39. This is probably only a mastering error or bit-rot. APX usually did format all tracks on their disks contrary to some other publishers which quite often formatted only the needed tracks on their disks. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 25, 2023 Author Share Posted March 25, 2023 Analog #50 MAGIC1.BAS from Reader's Comments modifies Magic Spell from issue #46 for faster loading of spelling words. MAGIC2.BAS and MAGIC3.BAS From Reader's Comments modifies Magic Spell from issue #46 for XL/XE compatibility. ADBFIX.BAS from Reader's Comments is an enhancement for the Analog Computing Database program from issue #47 KRAZYKAT.BAS holds the ML for the game Krazy Katerpillars. KRAZYCAS.LST is entered into KRAZYKAT.BAS to create the cassette version of the game. A CAS and an ATR from that CAS are included. The MAC/65 assembly listing compiles into a complete and working game. ANALOG Computing #50 (1987-01)(ANALOG Magazine Corp.)(US)[BASIC].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 25, 2023 Author Share Posted March 25, 2023 RealSports Football (1987)(Atari)(US)[cartridge] From a freshly opened, shrink-wrapped box. RealSports Football (1987)(Atari)(US)[cartridge].zip RealSports Football Manual.pdf RealSports Football Play Card.pdf RealSports Football Warranty.pdf 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 26, 2023 Author Share Posted March 26, 2023 Analog #51 TABLETY1.BAS is missing the last line shown in the magazine. The line does look erroneous for the simple fact that it does not have a line number. The 4 MAC/65 files for Slither compile into a complete and working game. If you compile under SDX, you will end up with a garbage disk, so only compile under Atari DOS. It does not load under SDX using the "X" command, but it does load under the Atari DOS "L" command and it also loads using a 3 sector boot disk. The 5 MAC/65 files for BBKMON compile into a complete and working program. It does not load under SDX, but does under the Atari "L" command. ANALOG Computing #51 (1987-02)(ANALOG Magazine Corp.)(US)[BASIC].zip 3 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 26, 2023 Author Share Posted March 26, 2023 Analog #52 FORTUNE.LST from Reader's Comments is an enhancement to the Fortune Wheel game from issue #49. RAMBUG.M65 does not compile. It requires SHOW.M65 and I cannot find it in the magazine. I found a working OBJ and it is included. EOLCNVRT.BAS converts the ASCII CR/LF to an ATASCII 155 while printing to a printer. It was in the Delphi Article. ANALOG Computing #52 (1987-03)(ANALOG Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 26, 2023 Author Share Posted March 26, 2023 Analog Issue #53 has been updated 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 27, 2023 Author Share Posted March 27, 2023 Analog #54 has been updated 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 27, 2023 Author Share Posted March 27, 2023 BackTalk 1.2 (1986)(Antic Software)(US)[disk] I recorded it 3 times. Each time the bad sectors are the same. The -p option does nothing. Did Antic use copy protection? BackTalk 1.2 (1986)(Antic Software)(US)[disk].zip BackTalk 1.2 Order Form.pdf BackTalk 1.2 Warranty.pdf 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 27, 2023 Author Share Posted March 27, 2023 Caverns of Mars (1981)(APX)(US)[cassette] Caverns of Mars (1981)(APX)(US)[cassette].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 28, 2023 Author Share Posted March 28, 2023 Analog #55 CHCKWRT1.LST from Reader's Comments is a modification to Check Writer from issue #53. CHCKWRT2.LST from Reader's Comments is a modification to Check Writer from issue #53. FASTSETS.BAS is the complete program. FASTSETL.BAS is the program that adds lines 5030 and 32010-32050. These lines are already in the FASTSETS.BAS. FASTLIF1.M65 and FASTLIF2.M65 (rename FASTLIF2.M65 to FLIFE2.M65 before compiling) compile into a complete and working game of Life in the Fast Lane. TABLETYP.LST from the Delphi Article is a modification to Tablet Typist from issue #51. It makes the program Sparta DOS compatible. ANALOG Computing #55 (1987-06)(ANALOG Magazine Corp.)(US)[BASIC].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 29, 2023 Author Share Posted March 29, 2023 Analog #56 has been updated. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 29, 2023 Author Share Posted March 29, 2023 Analog #57 CHECKBOO.LST from Reader's Comments is a correction for the Checkbook module of Micro Check from issue #27 REPORT3.LST from Reader's Comments is a correction for listing 3 of the Report program for Micro Check from issue #53. REPORT5.LST from Reader's Comments is a correction for listing 5 of the report program for Micro Check from issue #53. HTDEMOPML.BAS from Reader's Comments creates the machine language lines that is entered into HTPKRDMO.BAS to make a complete program INTBASIC.BAS from Reader's Comments fixes an error with programs on the 8-bit Extra disks. The MAC/65 listing for Troll War II is missing TROLL16.M65 to complete the program. This section of the assembly listing is in the next issue. Since this disk is non-original, I brought that last part over to this issue and compiled it into a complete and working game. As a result of all the files being together, the second disk is not a boot disk and only has the Troll War II files on it. ANALOG Computing #57 (1987-09)(ANALOG Magazine Corp.)(US)[BASIC].zip 5 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted March 30, 2023 Share Posted March 30, 2023 On 2/2/2023 at 8:05 PM, SoulBuster said: Issue #35 (Disk 1 Sourced from A8SP) BONK.BAS creates a file or a cassette version of the game. The CAS and an ATR from that CAS are included. The Mac/65 listing compiles into a working game. The source code seems to assemble into an only partially working game. @tsom fixed it here. Perhaps you can update your disk image above. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 I just compiled BONK.M65 from the Analog disk image I posted using MAC/65 v1.02 and it does compile into a complete and working game, including wall and monster collisions. Maybe not using MAC/65 is causing the problems you are seeing. Or maybe it is the DOS that is the culprit. Here is an ATR with the MAC/65 file and the obj I just compiled. Boot it without basic and use the Atari DOS 2.5 "L" command. Blank Temp.atr 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 US Government (1979)(Atari)(US)[cassette] Lesson 7 7:45 glitch Lesson 13 9:43 glitch US Government Cassette A.zip US Government Cassette B.zip US Government Cassette C.zip US Government Cassette D.zip US Government All Other Assets.zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted March 30, 2023 Author Share Posted March 30, 2023 Bob's Business (1981)(Santa Cruz Software)(US)[cassette] Side 1 recorded clean, but I was not able to get a clean recording of the "backup copy". I have included two failed attempts. Bob's Business (1981)(Santa Cruz Software)(US)[cassette].zip Bob's Business (not working X2).zip 4 Quote Link to comment Share on other sites More sharing options...
