Grizzards — turn-based RPG (completed)
I wasn't sure if I'd missed something. Unfortunately the source code is “just’ conditionalized on the TV standard — so there would be quite a bit of work to isolate the bits relevant to the sound or colors vs. the timing.
(Incidentally, we're amidst moving house, so I won't likely have time to do much of anything but that for a few weeks.)
49 minutes ago, Bruce-Robert Pocock said:
There is a PAL 50Hz version available (as well as SECAM 50Hz) available; is that not commonly supported now?
Yes, every PAL TV supports PAL50.
Nowadays many developers (for example Champ Games and many others on AtariAge store) use PAL60 because it has the same speed of NTSC and the conversion is easy, only colors need to be adjusted.
At the time PAL games (PAL50) where slower than NTSC games and Europeans didn't like it.
Therefore today they like PAL60.
On the other hand, to maintain NTSC speed, a PAL50 conversion is not easy, code must changed and tests are needed (for example PAL50 version of Circus Convoy has a little bug).
But your game's PAL50 speed is OK, therefore in fact there's no need of a PAL60 version.
Think about it for your next game!
This is the main reason we don't see a lot of PAL50 releases.
 ..Al
  • 1 month later...
Indeed, congrats!   I was thinking about text in Atari games and your's obviously came to mind, Bruce.  How big do you think the game would be without the voice for the 2600?  I'm curious what your thoughts are on an ultra simplfied RPG conversation system for the 2600 using the equivalent of modern day emoji's.
Let me run some figures and I can tell you about the size precisely, but in general, the speech phonemes I think are similar in size to the visible text.
I did a thing like that once upon a time (Orpheus for PC-DOS), but later saw it done well — in Mass Effect. The player chooses the “attitude” of their response rather than specific text …
Thanks.  I'm curious how much of the 64k filesize was all the text you used.  Mass Effect did have something like that in Andromeda I believe but the NPCs still obviously responded to you in full speech.  I was actually referring to the NPCs conveying info in emoji-style form and you responding with a simple "yes"/up or "no"/down response.  So for example, you come up to an NPC and they have the stereotypical exclamation point above their head so you click to "talk" to them; they respond with a sword icon and an enemy sprite and you respond either up or down on the joystiq.  Basically, they're asking you to fight/kill that enemy as a quest and you either accept or decline it.   It's obviously MUCH more limited than the full on text you used but I figured I'd ask what you thought.
It looks like the total data for phonemes runs about 8,120 bytes (give or take a few), and there's a little bit of code that goes with it — the printed text totals around 6,461 or so bytes itself. (The text panels are lightly “compressed” in that each character takes only 6 bits, so there are actually about 8,172 characters plus some control codes like colors and scripting.)
Overall, with the scripting engine code (replicated in each bank) there are 6 banks of text and speech data × 4 kiB each — one of which is also used for some end-of-game graphics and such as well. That's a total footprint of about 24kiB for text, speech, and drivers; removing the speech portion would probably remove not only 8,120 bytes of speech, but also compact the number of banks needed for the text, so it could get maybe packed in to about 3 banks (12k), freeing up 12k for whatever else might be interesting.
For the utterly curious, memory banks assignments are about like:
  • Bank 0: Cold Start/title, EEPROM (SaveKey/on-cart) access
  • Bank 1: Map mode services and the Failure screen
  • Bank 2: Text services
  • Bank 3: Province 1 maps (Port Lion) and music
  • Bank 4: Province 0 maps (Treble Village, Anchor, Spiral Woods, &c) and music
  • Bank 5: Province 2 maps (underground areas) and music
  • Bank 6: Combat
  • Bank 7: Sound effects, speech, and music drivers, and title music
  • Bank 8-12: Text, scripting, and speech
  • Bank 12 (also): End of game
  • Bank 13: Lots of random bits stuffed in at the last minute
  • Bank 14: Monsters (stats, graphics, names)
  • Bank 15: Animation services, combat services, and game finale code
As far as the “glyph based” communications system, maybe take a little peek at the games Dungeon and Dungeon II here on AtariAge, they use a not-entirely-different system…
That's an impressive amount of text and speech especially for a classic format/platform like this!   I'm relatively new to the Atari homebrew scene (a bit over a year of regular visits) but I can't think of anything whether homebrew or official that comes close to that.  Thanks for looking that up.  Would that 12k be enough to add another map area to explore for example?  From your detailed breakdown, aspects like text and enemies are segmented into different banks so I understand that those might not get increased.
I appreciate the info as I'm unfamiliar with the game.  I'll take a look right now!
Each of the areas has its own 4k bank, with 50-75 screens and its own musical theme. So, in theory, that could add another 3 maps — but, realistically, one additional 4k region + 8k for additional text/scripting perhaps.
  • 1 month later...
I'm sorry, it's been six months since PRGE and I've been lax in getting a proper v1.2 build of Grizzards up for those who just want to play on emulators or multicarts. Fear not, I have not forgotten, and I will attempt to polish up such a release “soon.”
I'd also like the link to this interesting review, which unfortunately I don't speak enough German to follow completely, but perhaps should mention as @H.Fraenkel has clearly put a lot of work into it, and also is one of the very few who have defeated the final boss.
And, while I'm sharing reviews, I'm thrilled about this lovely mention, as well… https://youtube.com/clip/UgkxHmMjC8r0jmVxRwf-fV8Pe6drJELtDIwE
1 hour ago, LatchKeyKid said:
Looking forward to it!  I tried playing it when it came out and read the pdf instructions but couldn't even get past the intro/character screens.  :(
If you were trying in Stella, make sure you selected the left controller as joystick — it may detect as keyboard controller, meaning the Atari 12-key controller, not your PC keyboard. The .pro file will do this, if it's in the same folder as the .a26 ROM file, or you can select it from the Tab menu — or “second key from the top” menu if that isn't Tab on your keyboard. It'll be under Game Properties / Controllers / Left Port and you most likely want to pick Sega Genesis but joystick works fine as well.
image.png.a4c5752214712f2ab27f24860b30ea28.png← this is the auto-detect thinking it should be Keyboard controller, which does not work
If you were getting some kind of “sad face” error code, please do let me know which one …
Thanks.  I'll take a look tonight.  It was with Stella but I was using an xbox/windows controller as well as pecking at the keyboard to see if any of those buttons worked.  It's been a few months but I was stuck at I think entering in my name.
Hello! I just got the cartridge version in the mail today. Unfortunately, I seem to be unable to play it. After entering my name and selecting a grizzard and selecting Begin, the game will either crash with a rolling screen or give the error code 0DF7FB. I have tried with both 2600 and 7800 consoles and different controllers.
  • Sad 1
  • 2 weeks later...
the cartridge is saving data without my atarivox plugged in.   I get in the lost mine and can't find the way through and most of my creatures are dead with no potions to heal them.  How do I get potions?
