PeterG Posted February 7, 2022 Share Posted February 7, 2022 It runs on the GD for me, on Phoenix emulator it only shows the title, the bars and the letters on top. I agree with AlucardX, don't know about the best slideshow, but despite the speed issue it made me smile seeing this running on my Jag. Nice experiment. It brought back memories from playing it on a friends PSX and knowing that it would never be released on the Jag although in the FAQ it was announced as unreleased game "Lara Cruz: Tomb Raider" or something like that. So in that regard it is kinda nice to finally see it in a way on the Jag. ? 2 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 7, 2022 Share Posted February 7, 2022 I can't wait to see how this game starts to run as code is moved over to the RISCs where things can begin to be done efficiently. 1 Quote Link to comment Share on other sites More sharing options...
JagChris Posted February 7, 2022 Share Posted February 7, 2022 (edited) 8 hours ago, Chilly Willy said: Latest works here. Very nice for a slide show. ? I can actually run around as long as I'm patient. Seems stable, and the rendering looks good. It looks like @XProger is gearing up for N64 and 32X versions. Edited February 7, 2022 by JagChris 2 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 7, 2022 Share Posted February 7, 2022 17 minutes ago, JagChris said: It looks like @XProger us gearing up for N64 and 32X versions. Maybe we'll see a SuperFX2 version? (j/k) 1 Quote Link to comment Share on other sites More sharing options...
dilinger Posted February 7, 2022 Share Posted February 7, 2022 9 hours ago, 42bs said: I checked an old GCC (Sourcery G++ Lite 4.4-52) and it does know about. Where can we find this Sourcery G++ compiler? 12 hours ago, swapd0 said: I want to have two build versions, one with skunk debug code, the other one "naked" Out of curiosity, does the OpenLara source code uses a lot of float/double operations? Quote Link to comment Share on other sites More sharing options...
swapd0 Posted February 7, 2022 Share Posted February 7, 2022 10 minutes ago, dilinger said: Where can we find this Sourcery G++ compiler? Out of curiosity, does the OpenLara source code uses a lot of float/double operations? No, there's a directory named fixed with some classes and functions implemented in fixed point, although in the main src directory the same classes uses floating point. 1 Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted February 8, 2022 Share Posted February 8, 2022 2 hours ago, JagChris said: It looks like @XProger is gearing up for N64 and 32X versions. Given the speed on the GBA, an N64 version should run rather nicely, even with software rendering. A 32X version using one SH2 and plain C should be slow, but not a slideshow - it's basically how my yeti3d demo on the 32X works. If you made the same kind of optimizations to the 32X version as the GBA version, it should should be at least as fast, and faster if you can pull some dual processor stunts like Vic did for D32XR. The main thing going for the 32X version is you can have all the game logic and everything running on the SH2 rather than the 68000. The SH2 has a mature and stable C/C++ compiler, unlike the JRISC, so acting like the main SH2 is the only processor, and all the MD stuff is just a support chip to be initialized and forgotten about is a valid way of programming on it. So I wouldn't be surprised if an initial build on the 32X ran better than the current build on the Jaguar. In the end, the Jaguar version should be better, but it will take more work to get there. 4 Quote Link to comment Share on other sites More sharing options...
42bs Posted February 8, 2022 Share Posted February 8, 2022 (edited) 6 hours ago, dilinger said: Where can we find this Sourcery G++ compiler? Here: https://www.sciopta.de/ftp/freescale-coldfire-4.4-52.7z It`s no installer (anymore). I used to have it installed in "c:\compiler\gcc" and it may rely on this path. Edited February 8, 2022 by 42bs Quote Link to comment Share on other sites More sharing options...
dilinger Posted February 8, 2022 Share Posted February 8, 2022 1 hour ago, 42bs said: Here: https://www.sciopta.de/ftp/freescale-coldfire-4.4-52.7z It`s no installer (anymore). I used to have it installed in "c:\compiler\gcc" and it may rely on this path. Thank you. I have also heard from various Amiga developer about the gcc 2.95.3, which is considered to have the best 68K support. I have tried to get it but am out of luck so far. Quote Link to comment Share on other sites More sharing options...
42bs Posted February 8, 2022 Share Posted February 8, 2022 Not 100% sure about 68k support as I mainly used it for Coldfire. But from what I have seen so far, the code quality is good. The problem is the parameter passing via stack (the ABI). The old MetroWerks compilers used registers which resulted in even better code. Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 13 minutes ago, dilinger said: Thank you. I have also heard from various Amiga developer about the gcc 2.95.3, which is considered to have the best 68K support. I have tried to get it but am out of luck so far. 1 minute ago, 42bs said: Not 100% sure about 68k support as I mainly used it for Coldfire. But from what I have seen so far, the code quality is good. The problem is the parameter passing via stack (the ABI). The old MetroWerks compilers used registers which resulted in even better code. Are these changes that were made to GCC upstream and then removed or are these changes that were made by someone else. If they were made by someone else, were the binaries distributed? If that is true then it is my understanding that they would be required to share the source code to their changes to GCC according the the terms of the GPL. Quote Link to comment Share on other sites More sharing options...
42bs Posted February 8, 2022 Share Posted February 8, 2022 CodeSourcery was aquired by MentorGraphics which is now Siemens. Back in time, they did provide the sources. The product was CodeBench, but I doubt that Siemes has the old source archives. 1 Quote Link to comment Share on other sites More sharing options...
ArneCRosenfeldt Posted February 8, 2022 Share Posted February 8, 2022 11 hours ago, alucardX said: I can't wait to see how this game starts to run as code is moved over to the RISCs where things can begin to be done efficiently. It is portable C code. People told me that you can compile to JRISC like you can compile to 68k, yet the only (software) cache is in some game released back then an the source lost. It is great that Doom aparently had the better colors on the Jag thanks to some decisions for CRY totally not related to the JRISC assembly code which was just a necessity. Also this overflow flag: Even the 6502 has it and uses it for SBC (and why do people miss overflow in CMP? As an exception?). The Jag instead has > < >= <= == <> .. all the combinations. Why would 32 bit overflow anyway? You can check for sign in combination with carry, but somehow this is not identical to overflow: negative + positive cannot overflow. The sign is from the larger absolute value. Carry is set if we add a positive value to a small negative value to pull up into positive range: Carry != sign => no overflow negativ + negative can overflow. If everything is okay, sign stays negative and carry is sign extended to be set. If 0 bubble into sign, we have overflown. carry is set and sign is set. => no overflow positive+positive. sign needs to be clear and carry is clear. So how can you use sign and carry to detect overflow? Why did they even care for that combination? For speedy JRISC code you will want to convert everything to unsigned. I mean, the integer parts to index into a texture need to wrap around much earlier. Carry may be used for the fractional parts in the texture mapping. 1 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 8, 2022 Share Posted February 8, 2022 One more thread infected..... 3 1 3 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 7 hours ago, 42bs said: CodeSourcery was aquired by MentorGraphics which is now Siemens. Back in time, they did provide the sources. The product was CodeBench, but I doubt that Siemes has the old source archives. If at some point someone finds the code OR modifies modern gcc for this, I would suggest submitting it to upstream maintainers. Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 7 hours ago, CyranoJ said: One more thread infected..... Or assimilated? 1 Quote Link to comment Share on other sites More sharing options...
leech Posted February 8, 2022 Share Posted February 8, 2022 (edited) https://www.phoronix.com/scan.php?page=news_item&px=GCC-11-m68k-Is-Safe Normal gcc should be able to compile for m68k, is there any particular reason to use an ancient version? Edited February 8, 2022 by leech Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted February 8, 2022 Share Posted February 8, 2022 From what I understand, 68000 support has been going downhill in GCC for a long time -- it still works, but the quality of the generated code is worse that it used to be, as it's no longer actively maintained. Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 7 minutes ago, Zerosquare said: From what I understand, 68000 support has been going downhill in GCC for a long time -- it still works, but the quality of the generated code is worse that it used to be, as it's no longer actively maintained. What would make it worse? Is it due to the code for the 68K portion not being brought up to date with newer libraries or something like that? Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted February 8, 2022 Share Posted February 8, 2022 GCC architecture is complex and I don't know enough about it to answer for sure. 1 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 Just now, Zerosquare said: GCC architecture is complex and I don't know enough about it to answer for sure. That is fair. If it is something that would be helpful to the Jaguar community maybe there is a way to find out the status and see what is not working and how to fix it. If it is a net gain for gcc I see no reason why the upstream maintainers wouldn't include it in the official releases. Quote Link to comment Share on other sites More sharing options...
K3V Posted February 8, 2022 Share Posted February 8, 2022 With this link it works. https://mega.nz/folder/FUcEWRTK#BqLluo_3JArKAarrxlLSVQ This is working on the Game Drive for me. 5 Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted February 8, 2022 Share Posted February 8, 2022 6 hours ago, alucardX said: What would make it worse? Is it due to the code for the 68K portion not being brought up to date with newer libraries or something like that? It think it's more that the newer 68k code generation is geared towards 32-bit chips, particularly the ColdFire cores. The older gcc when targeting the 68000 would produce faster code as it concentrated on keeping as much of the code as possible using 16-bit constants and offsets and such. The newer compilers produce better code, but not faster as it barely pays any concern to the faster speed word size of the 68000. There's a lot more about this over at SpritesMind since the Genesis/MD used the 68000. People benchmarked the old gcc verses newer versions. I don't think anyone has benchmarked it against anything really new, like 10.x or 11.x. 1 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 8, 2022 Share Posted February 8, 2022 2 minutes ago, Chilly Willy said: It think it's more that the newer 68k code generation is geared towards 32-bit chips, particularly the ColdFire cores. The older gcc when targeting the 68000 would produce faster code as it concentrated on keeping as much of the code as possible using 16-bit constants and offsets and such. The newer compilers produce better code, but not faster as it barely pays any concern to the faster speed word size of the 68000. There's a lot more about this over at SpritesMind since the Genesis/MD used the 68000. People benchmarked the old gcc verses newer versions. I don't think anyone has benchmarked it against anything really new, like 10.x or 11.x. This is a question born of my own ignorance, but are there any compiler flags to deal with that situation? Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 9, 2022 Share Posted February 9, 2022 45 minutes ago, alucardX said: This is a question born of my own ignorance, but are there any compiler flags to deal with that situation? I found some info for the 68k family of cpus. Is it helpful to select the 68000 in this way? These are the ‘-m’ options defined for M680x0 and ColdFire processors. The default settings depend on which architecture was selected when the compiler was configured; the defaults for the most common choices are given below. -march=arch Generate code for a specific M680x0 or ColdFire instruction set architecture. Permissible values of arch for M680x0 architectures are: ‘68000’, ‘68010’, ‘68020’, ‘68030’, ‘68040’, ‘68060’ and ‘cpu32’. ColdFire architectures are selected according to Freescale’s ISA classification and the permissible values are: ‘isaa’, ‘isaaplus’, ‘isab’ and ‘isac’. GCC defines a macro __mcfarch__ whenever it is generating code for a ColdFire target. The arch in this macro is one of the -march arguments given above. When used together, -march and -mtune select code that runs on a family of similar processors but that is optimized for a particular microarchitecture. -mcpu=cpu Generate code for a specific M680x0 or ColdFire processor. The M680x0 cpus are: ‘68000’, ‘68010’, ‘68020’, ‘68030’, ‘68040’, ‘68060’, ‘68302’, ‘68332’ and ‘cpu32’. The ColdFire cpus are given by the table below, which also classifies the CPUs into families: Quote Link to comment Share on other sites More sharing options...
