Sizecoding reaches Jaggy
42bs
Can't get the GPU one to run from .cof or .j64 on a Skunkboard. Tried 50Hz and 60Hz. The .j64 works fine on a Gamedrive (I.e., a regular full BIOS boot), but the .cof does not (Gamedrive just hangs on menu screen, presumably after loading the tiny file and trying  to run it).
How are you testing these? BJL?
This code relies on the BIOS setting up the video, therefore it does not run from SKUNK and likely not BJL.
Updated it, now it runs fullspeed in internal RAM.
3 minutes ago, SlidellMan said:
Wow, that is an excellent use of the Jaguar's particle capabilities.
I am not sure what you mean, but this is pure old-school frame buffer manipulation:
for all x,y do
  plot x,y, MIX(color(x+1,y+1)+color(x,y+1))
Prototype in Processing:
int [][] frame = new int[103][160];
int [] r = new int[256];
int [] g = new int[256];
int [] b = new int[256];
void plot(int x, int y, int col)
  int _r,_g,_b;
  _r = r[col];
  _g = g[col];
  _b = b[col];
  _r*=6;
  _g*=6;
  _b*=6;
  fill(_r,_g,_b);
  stroke(_r,_g,_b);
  rect(x*4,y*4,4,4);
void setup() {
  size(640,408);
  noSmooth();
  rectMode(CORNER);
  surface.setLocation(1800,100);
  frameRate(60);
  for(int y = 0; y < 102; ++y){
    for(int x = 0; x < 160; ++x){
      frame[y][x] = 0;
  int _r = 0;
  int _g = 0;
  int _b = 0;
  for(int col = 0; col < 256; ++col){
    r[col] = _r;
    g[col] = _g;
    b[col] = _b;
    if ( col < 16 ) {
      _b = col;
    } else {
      _b = 0;
    if ( (col & 32) == 0 ){
      ++_r;
    } else {
      ++_g;
void draw()
  int x,y,s;
  s = 0;
  for(y = 0; y < 102; ++y){
    for(x = 0; x < 160; ++x) {
      int rp;
      int lp;
      if ( x < 159 )
        rp = frame[y+1][x+1];
      else
        rp = frame[y+1][0];
      lp = frame[y+1][x];
      s = (rp + lp) & 255;
      s = (s + lp) & 255;
      s ^= lp;
      s = (s+frame[y][x]) & 255;
      s ^= frame[y][x];
      s /= 4;
      frame[y][x] = s & 255;
      plot(x,y,s);
  for(x = 0; x < 160; x+=2){
    s = s+int(random(65536));
    frame[102][x] = s & 255;
    frame[102][x+1] = (s >> 8)& 255;
1 hour ago, 42bs said:
Nicely done!
In line 56 with a bit of re-jigging you should be able to move the 7ec8 part of the constant right before "brush" and load both high and low parts using a move.l (a1)+,d7. Then move that "move.w (a1)+,d7" below the inner loop so you can consume the next part of the seed then. This should save you a whopping 2 bytes :). More info about this madness (and more!) here http://beyondbrown.mooo.com/post/mona/
1 minute ago, ggn said:
Nicely done!
Cool! Thanks. But I fear, the 256byte goal is still unreachable.
6 minutes ago, ggn said:
Nicely done!
Not sure, as I do
move.b (a1),d1
for the Y. But I need to think ...
Yes, the two implementations have structured the code a bit differently. So it's quite possible that it's not feasible in your case - after all I just took a quick look. And sure, SMC is completely out of the question, I did notice that :).
I see from the .rom file that the binary size is 304 bytes. So who knows, maybe 256 is reachable with lots of rewrites and exploits, maybe not! But at least my -2 bytes is a start ;)
Actually it is 314 bytes. But I am already doing a lot of dirty stuff. Tried the trick, but adding the "lsr.w #8" will eat up the gain.
I have to try to get rid of the VBL interrupt and rather check the HBL counter to for the OBL reload.
*hmp* rmac/rln seem to align the output to 16bytes :(
Ok, found it: -rw => Word alignment.
Edited by 42bs
