+Larry Posted March 11, 2022 Share Posted March 11, 2022 Does the 800 (NTSC) use the same PIA and POKEY as the XL and XE series? Thanks. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted March 11, 2022 Share Posted March 11, 2022 I've successfully used and tested both PIA and POKEY from a 600XL in an 800. Looks like Pokey is the same: https://forums.arcade-museum.com/threads/atari-pokey-chip-replacements-and-possible-fix.464086/ PIA chips are functionally the same: https://atariage.com/forums/topic/264911-question-about-to-pia-chips/ I've also successfully used the motorolla MC6821P in place of the PIA chip. 1 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted March 11, 2022 Share Posted March 11, 2022 2 hours ago, Larry said: Does the 800 (NTSC) use the same PIA and POKEY as the XL and XE series? That's only one question. Where are the other 799 Questions? 9 Quote Link to comment Share on other sites More sharing options...
cwilbar Posted March 11, 2022 Share Posted March 11, 2022 4 hours ago, Larry said: Does the 800 (NTSC) use the same PIA and POKEY as the XL and XE series? Thanks. PIA and POKEY are the same. Diffs would be 400/800s could have a CTIA vs GTIA, 400/800 could use a 6502 or a Sally depending on the CPU card, ANTIC has 2 versions and I believe both will work in a 400/800, some XLs can run both as well, and some XLs require the newer (depends on the RAM chips IIRC). I believe all GTIAs are interchangeable. This of course doesn't touch on NTSC vs PAL vs SECAM. 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted March 12, 2022 Share Posted March 12, 2022 When there is a 100% failure of the keyboard, what are some of the things to check other than Pokey, PIA, 4051? Quote Link to comment Share on other sites More sharing options...
