Krull - Recreation of Arcade Game
saxmeister
I had posted some test work on this before, but I started getting a little more serious with this. A test started coming together rather nicely, so I'm going to attempt to recreate the arcade version of Krull on the 7800 as closely as possible.
This is my first "big" game, so it will take some time. I'm learning with each step, so it will come slowly. I'm learning how to properly structure the game and learning things such as collision detection and bank management. It's a lot to learn at once, but if I can do it, many of you can as well. The 7800basic environment is amazing! I can't thank the devs enough for this tool.
I don't have the original source code to work from, so I'm winging it here.
  • Ripped the graphics from the arcade
  • Ripped the font from the arcade
  • Recreated the title screen with the limitations of the 7800
  • Recreated the first level and I'm working on the AI of the rolling boulders
  • Got the movement of the lead character "Colwyn" working with all frames of animation ripped from the arcade machine
  • First collision detection of the shards of the glaive and added scoring for this
FIRST TESTS
Link to JS7800: https://raz0red.github.io/js7800/?cart=https://atariage.com/forums/applications/core/interface/file/attachment.php?id=919271
VERSION 0.4
Link to JS7800: https://raz0red.github.io/js7800/?cart=https://atariage.com/forums/applications/core/interface/file/attachment.php?id=926309
Edited by saxmeister
  • Like 16
1 hour ago, Muddyfunster said:
I love the lettering / runes on the title screen. Nice progress, looking forward to seeing how this develops!
I ripped that font and the runes directly from the arcade version myself. The only thing missing on that title page is the glowing runes. The hardware for the arcade version could do more colors per pixel than 320A mode can so making them glow would require making the runes as graphics, placing them in the exact spot, and then color cycling reds. I may try that if I find time. It would look really cool.
A few updates this evening.
  • Sprite collision with the glaive shards, boulders, and bushes
  • Colwyn now slows down when running through the bushes
  • Better music for the glaive pickup (and added random pitch changes to each one)
  • Added some version of the boulder rumble (I wish I had the original hardware for that beautiful distortion)
  • Started ripping the graphics for the next level while taking a break from coding
Still to fix:
  • Colwyn remains at slow speed even after leaving the bushes until the joystick is completely let go of
  • Better collision detection
  • Fixes to the boulders and the randomness - the way they do it on the arcade game is weird but very cool
  • Needs much better random numbers - every time I start the game the random items are in the same place
  • Visual glitches
  • Better music/sfx
  • ALL OTHER LEVELS
JS7800 Link: https://raz0red.github.io/js7800/?cart=https://atariage.com/forums/applications/core/interface/file/attachment.php?id=926821
krull_06.bas.bin krull_06.bas.a78
  • Like 8
On 3/20/2022 at 1:50 AM, saxmeister said:
I thought about trying to do the Robotron thing with two joysticks, but that isn't as common as I would like. So I will stick with one stick for moving and aiming.
Hopefully you'll be able to make it an option for those who have twin stick setups. ?
- James
  • Like 5
I saw the same graphic issues in that video when using A7800 emulation as well. I also had it lock up once with just the yellow screen between levels at one point. It will also start to register being hit by a boulder if you start to walk into the graphic corruption areas I've found. Still, looking good!
