Popular Post ijor Posted April 10, 2023 Popular Post Share Posted April 10, 2023 Introducing FX ANTIC FX Antic is a cycle exact FPGA core that can replace the original ANTIC chip on an Atari 8-bit computer. The core is configurable as PAL or NTSC. Before elaborating, please note that this is not a product that is available to purchase. It is an open development but I don't build or sell the hardware, and currently nobody else does. The hardware is based on a small plug-in board designed by Mark Watson, the same platform used for his early Pokey Max product. The boards plug-in in the ANTIC socket and replaces the chip completely. An ANTIC chip is not needed at all. After implementing and testing the core though, it seemed that the FPGA could do much more than “just” ANTIC. First thing to came to mind was producing a digital video output. Then GTIA “functionality” was added that would produce a direct HDMI video output: The first time I saw this, I must admit I was honestly impressed by the video crispness. I never saw before the Atari producing a direct digital video output. I of course have seen the output on an LCD monitor but either using an analog connection, or some kind of converter. Not nearly the same as a direct digital output. Btw, I consider the term emulation a misnomer here, it is not actually emulation. It is more a clone, or a replica. But since the term is commonly used in this context, so you may say if you want, that GTIA “emulation” was implemented. But then, watching MULE without the sound track is almost heresy. Getting the sound through a separate cable or speaker, seems rather awkward when HDMI was designed to include audio as well. Obviously, adding POKEY sound “emulation” was mandatory here, and let there be sound: Mule.mp4 Kenenedy.mp4 Pretty nice to have both full digital audio and video output from our Atari, don't you agree? But even at this point, the FPGA’s power still seemed mostly wasted. So why not let’s throw at it a quick VBXE implementation just for fun ... Gorgeous 1024 colors image by Stephen: Scaled to full screen by the FPGA: Impressive scrollers, also by Stephen: Purple.MOV Kg.mp4 Awesome blitting effects by Candle: Scroller-BlitterSample.mp4 I was going to add high quality digital audio, but I run out of time and motivation Again, this is not a product available to purchase. I did this mostly just for the fun of it, but also, I felt it was important because an ANTIC replacement was not available and sooner or later it will be needed. I am releasing the FX Antic sources. May be somebody will build the hardware at some point. Currently, due to the chip shortage, these FPGA chips are almost impossible to get at reasonable price, unfortunately. The basic core, ANTIC+GTIA+POKEY fits in a very small FPGA. Btw, please bear with me for the defects on the videos. I don't have high quality HDMI capture hardware. 45 8 Quote Link to comment Share on other sites More sharing options...
ijor Posted April 10, 2023 Author Share Posted April 10, 2023 (edited) Some technical considerations The core doesn't operate fully synchronously to the system. The computer's clock signals, at least in the computers I tried, are too glitchy for a modern device and can't reliably clock the FPGA logic directly. Being much faster than the system, the FPGA can operate in its own clock domain in a semi synchronous way. I will elaborate the details if it's interesting. It might be possible to condition the computer clock signals somehow, though. I didn't try that. The FPGA needs a faster core anyway. In other similar cases the FPGA can just multiply the system clock. These modern FPGA devices have a very powerful PLL built-in. But in this case, it is not possible because the system clock is lower than the minimum spec required by the PLL. The GTIA and POKEY functionality is obviously “write only” and implemented by snooping the CPU bus. The core doesn't respond to read cycles from these devices. Both chips are still needed. The POKEY sound implementation misses the exact sound characteristic related to the SIO port. The characteristic SIO sound when reading from a device depends on the actual external SIO activity, which the core doesn't have access. And the tape audio channel is of course, also missing. By watching POKEY and CPU activity, something we can do since we have access to the full CPU bus, it might be possible to infer indirectly the SIO activity and produce a reasonably accurate SIO sound track. While that might be and interesting idea, it's something I didn't attempt to implement. Reproducing the tape audio channel would require hooking to the system audio logic in any case. Having a powerful FPGA controlling the ANTIC interface brings a lot of new and exciting possibilities. Some ideas that come to mind are, e.g., all sort of improvements to the DMA system. It is possible to implement digitized sound DMA, DMA to the internal memory that would increase the bandwidth from the CPU significantly, caching ANTIC display data, etc. But most of these features would require special software that I was too lazy to implement, and not motivated enough when I'm not sure this will ever be used by anyone else besides me. Maybe I'll continue the development at some point, may be somebody else, don't know. Edited April 10, 2023 by ijor 9 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted April 10, 2023 Share Posted April 10, 2023 Wow, great news. I'll read more later but great to have this even if it's not something being actively produced/available to purchase. Every time I lose an antic chip it's harder to source a replacement. Especially PAL. At least with Sophia 2 we have a great alternative to Gtia. Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 10, 2023 Share Posted April 10, 2023 Looks good. Another improvement I'd like to see would be higher bandwidth graphics modes, ie bitmap modes that utilize 80 DMA cycles of graphics per scanline. Though of course such a thing would add another non-legacy compatible improvement to the architecture that only a few could use. But insofar as preservation of original hardware - it would be great to have a plugin board that could handle all the chipset functions. 3 Quote Link to comment Share on other sites More sharing options...
foft Posted April 10, 2023 Share Posted April 10, 2023 Wow, amazing work @ijor. Impressive to fit all that in a 10M02 too! Quote Link to comment Share on other sites More sharing options...
foft Posted April 11, 2023 Share Posted April 11, 2023 So for digital video+audio and vbxe did you change anything on the board @ijor? I’d have thought hdmi would need a real clock rather than the internal oscillator. For vbxe I’d have thought you’d need external ram + maybe a larger fpga. Here is a picture of my 600xl with these boards in, I took it to silly venture in 2018 with the plan of showing it replacing all the custom chips. I never completed the antic port, my fpga core timing is such that it couldn’t trivially fit on the real bus. 6 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 11, 2023 Share Posted April 11, 2023 3 hours ago, foft said: vbxe Don't think vbxe was mentioned? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 11, 2023 Share Posted April 11, 2023 It's in there, last parts of the first post. What FPGA is in use though? I don't think it could be the Intel 10M02 - the description I found for that mentions only 2,000 logic elements. I imagine to do what's going on here would need multiples of that at least. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 11, 2023 Share Posted April 11, 2023 Looks like a 10M02 in the photo - remarkable if so. Quote Link to comment Share on other sites More sharing options...
ijor Posted April 11, 2023 Author Share Posted April 11, 2023 (edited) On 4/10/2023 at 8:36 AM, foft said: Impressive to fit all that in a 10M02 too! As I said, the "basic" core fits comfortably in a 10M02. I don't have a core compiled without any debug stuff, but a "clean" core shouldn't take more than 60% utilization. Remember than only ANTIC is fully replaced. Both the original GTIA and POKEY chips are still there. Then we don't need to implement logic for SIO, Keyboard scanning, Paddles, Collision, etc; because all that stuff is still handled by the original chips. The HDMI interface consumption depends on which type of hardware do you use. I used an HDMI transmitter that requires very little logic at the FPGA. Without an HDMI transmitter, or driving the HDMI interface directly as you do in the Eclaire XL, will likely require more FPGA resources. I assume an 10M04 would be required in the worst case. VBXE functionality requires, of course, not only a bigger FPGA but also external RAM, or otherwise an FPGA big enough to fit the required RAM internally. A full featured video scaler with its own frame buffer also requires a bigger FPGA and/or external RAM. That was one of the reasons I added VBXE functionality. It made sense since both features had similar hardware requirements. In my tests I used a proxy board since the the original board doesn't have any kind of HDMI interface. Even if I wanted to connect an HDMI transmitter directly, I wouldn't have enough pins exposed. So I am sending the HDMI data multiplexed over a a few wires and then de-multiplexing the data at the proxy board that has its own logic. These are just details of my particular implementation due to the limitations of the specific board I was using. Functionally it would be the same as if it was all integrated in just one board. I guess that if the hardware would be produced, it would make sense to have at least two different versions. A "basic" version that would fit in a very small FPGA and should be very cheap. And another one using a more expensive FPGA and extra RAM. Regarding the clock. You probably want to include an external oscillator in any case. Shouldn't add too much to the cost and it is recommended for reliability. The ANTIC timing is much more critical than POKEY or GTIA. ANTIC is a bus master and must drive the address bus and the DMA signals quite precisely. Edited April 11, 2023 by ijor 6 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted April 11, 2023 Share Posted April 11, 2023 This is an amazing project. The day will come when a working ANTIC chip is impossible to find. It appears this FPGA board can be used to replace the other LSI chips as well, too. It looks like the same board could be used to replicate a POKEY, as well. Is there any thought to having a 1-1 replacement project, using this board (or something similar), that could be programmed to emulate only the chip it is intended to replace? Also, would this be sold or made available for others to replicate? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 11, 2023 Share Posted April 11, 2023 Would the basic core version therefore work with an existing VBXE board? Quote Link to comment Share on other sites More sharing options...
invisible kid Posted April 11, 2023 Share Posted April 11, 2023 (edited) 1 hour ago, reifsnyderb said: Is there any thought to having a 1-1 replacement project, using this board (or something similar), that could be programmed to emulate only the chip it is intended to replace? Also, would this be sold or made available for others to replicate? So I just got a DE10 Nano for reasons in line with your Antic observation. I might be able to answer some of your questions. I would also like a 1-1 replacement, but not sure if it will come with extraneous hardware emulations that will sit unused. Originally the project was using a board from Lotharek, but the DE10-Nano came along and had a couple of advantages/disadvantages: 1. Cores may be more advanced/stable on Lotharek's board(but that can change). 2. DE10 Nano is subsidized for educational purposes, so some costs are covered and 3. It will have a very wide user base because of 2, and sometimes you go where the support is. I don't know the chronology, but other folks started developing cores for nes, gb, genesis, snes, etc. There is a project that will load up and keep those cores updated. Here is a good starting link on MiSTer in general with other links: https://www.retrorgb.com/mister.html So you just need to buy the de10-nano for a couple hundred bucks from Taiwan. Like a lot of things, you only need ~$250 for a basic setup, but will probably want/need to get expanded memory, premade expansion units, usb hub, wifi or bluetooth dongles, etc. The supporting software is free. There is an atariage thread with a lot of input from atariage user foft when the atari 800 core was being created, but I can't find it at the moment. Apologies for any misinfo. Hope this helps a bit! ETA: I don't know about chip-by-chip replacement, which is what your original question was. I got this to do whole systems. As a non-hardware guy, maybe there are micro fpga boards that are small enough. Edited April 11, 2023 by invisible kid 1 Quote Link to comment Share on other sites More sharing options...
ijor Posted April 11, 2023 Author Share Posted April 11, 2023 3 hours ago, reifsnyderb said: The day will come when a working ANTIC chip is impossible to find. Absolutely. That was my main motivation for the project in the first place. 3 hours ago, reifsnyderb said: It appears this FPGA board can be used to replace the other LSI chips as well, too. It looks like the same board could be used to replicate a POKEY, as well. Is there any thought to having a 1-1 replacement project, using this board (or something similar), that could be programmed to emulate only the chip it is intended to replace? Also, would this be sold or made available for others to replicate? The board was designed by Mark, aka @foft. I would better let him elaborate 3 hours ago, Wrathchild said: Would the basic core version therefore work with an existing VBXE board? I'm not very familiar with the VBXE hardware, but yes, I suppose it should work. When I mentioned a basic version I was thinking in one that perhaps would still include HDMI output, except that instead of using a full scaler, it would use a "simpler" scan doubler. When using a separate VBXE board you would need to use the VBXE video output though. The truth is that you can get a much more powerful device if you combine and integrate both cores. But again, this would require developing specific software. 5 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 11, 2023 Share Posted April 11, 2023 (edited) double line, skip single, double line, skip skip single... might be a nice thing restoring slight crt looks but will it stretch to maintain aspect? Edited April 11, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
invisible kid Posted April 11, 2023 Share Posted April 11, 2023 (edited) Oops! Deleted. Edited April 11, 2023 by invisible kid Quote Link to comment Share on other sites More sharing options...
as... Posted April 11, 2023 Share Posted April 11, 2023 Vbxe with Hdmi + stereo.. -amazing... But ... Lotharek/Candle/Electron? It is legal? Quote Link to comment Share on other sites More sharing options...
venom4728a Posted April 11, 2023 Share Posted April 11, 2023 1 step closer to having 1 machine that can switch between NTSC and PAL quickly and easily? 4 Quote Link to comment Share on other sites More sharing options...
HiassofT Posted April 11, 2023 Share Posted April 11, 2023 (edited) Big thumbs up from me for your awesome work @ijor and @foft, HDMI out with audio is a feature that I craved for for ages and which none of the other sophia / vbxe / ... upgrades supplied. IMHO it would be fine to stick to standard 720x576p50 / 720x480p60 scandoubled HDMI video output (current TVs provide really good upscalers) for the standard version and leave all other upscaler features for extended versions (with probably higher specced FPGAs and additional RAM). SD video output with sound is well enough for me. Again, thanks a lot for your amazing work! so long, Hias Edited April 11, 2023 by HiassofT 1 Quote Link to comment Share on other sites More sharing options...
adam242 Posted April 12, 2023 Share Posted April 12, 2023 1 hour ago, venom4728a said: 1 step closer to having 1 machine that can switch between NTSC and PAL quickly and easily? Fingers crossed for that! 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 12, 2023 Share Posted April 12, 2023 Overall amazing project, and I am beyond flattered to see some of my seemingly "simple" VBXE demos, being used by some real Atari heavyweights the past few weeks! 1 Quote Link to comment Share on other sites More sharing options...
Cyprian Posted April 12, 2023 Share Posted April 12, 2023 @ijor @foft well done Quote Link to comment Share on other sites More sharing options...
lemiel Posted April 12, 2023 Share Posted April 12, 2023 0. Very, very nice! Thank you! 1. HDMI license fee? So nobody's shop will sell it. 2. DMA was mentioned here and somewhere else with reference to eg. Rapidus and connection with it. Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted April 12, 2023 Share Posted April 12, 2023 1 hour ago, lemiel said: 1. HDMI license fee? So nobody's shop will sell it. The HDMI license is a problem on other platforms too. Just sell the hardware with official firmware that lacks audio and leak an enhanced firmware somewhere else. 5 Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted April 12, 2023 Share Posted April 12, 2023 just go with DVI and avoid the license issues. 2 Quote Link to comment Share on other sites More sharing options...
