Tillek Posted November 17, 2023 Share Posted November 17, 2023 Are you both going to be on the chat tonight? Might be a worthwhile group-think project! (Sending the late reminders out now). Link to comment Share on other sites More sharing options...
Pab Posted November 18, 2023 Share Posted November 18, 2023 Can you record what your machine is doing from first running LINK20X.bas until the AT loop you describe? Just cellphone footage would help. I can try to figure out exactly where the problem is happening and try to fix or work around it. Link to comment Share on other sites More sharing options...
Amis Posted November 19, 2023 Share Posted November 19, 2023 On 11/17/2023 at 6:41 AM, rickcollette said: I ran bobterm, ATZ give "OK", ATV0 gives "0" so.. testing with a completely different hardware setup... Rick - BobTerm has its own handler. Suggest the Sparta 3.3a RS232.COM handler or the Altirra handler which we know works. Curious also what OS you are using as my Altirra test was completed using SpartaDos 3.3a Link to comment Share on other sites More sharing options...
Pab Posted November 19, 2023 Share Posted November 19, 2023 Going through the code, looking for things that can be jettisoned and that need to be corrected.... Is there going to be anyone running this thing (virtually or on real hardware) with a single disk drive? Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 16 hours ago, Pab said: Going through the code, looking for things that can be jettisoned and that need to be corrected.... Is there going to be anyone running this thing (virtually or on real hardware) with a single disk drive? i plan to run on the following: 512k 800XL SpartaDOS/X (Current) IDE 2.0+ Rev H 850 Interface WiModem32 I am happy to change that config if it helps getting this going Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 (edited) On 11/19/2023 at 2:43 AM, Amis said: Rick - BobTerm has its own handler. Suggest the Sparta 3.3a RS232.COM handler or the Altirra handler which we know works. Curious also what OS you are using as my Altirra test was completed using SpartaDos 3.3a I tried terminals first: Bobterm and 850Express do work My OS is SpartaDOS/X current IceT I could not get to work properly Handlers I have tried: All I could find. prconn.hnd when I tried with PRConn 850hnd.com from the forem xep distribution rs232.com from spartaX The altirra handler Edited November 20, 2023 by rickcollette Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 50 minutes ago, rickcollette said: i plan to run on the following: 512k 800XL SpartaDOS/X (Current) IDE 2.0+ Rev H 850 Interface WiModem32 I am happy to change that config if it helps getting this going You're using a hard drive, not a single floppy configuration. My plans are to essentially do away with the concept of "work disk" and let the SysOp specify folders for text/info files, file catalogs, etc. I doubt anyone running a BBS in 2023 is going to rely on a single <360K floppy disk for everything. Just making sure. Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 Playing around with connecting through Altirra. What speeds are you connecting to the BBS at? I tried configuring Altirra to report a 9600 baud connection, and AtariLink didn't recognize the "Connect" message as having connected. Going down to 2400 and I was able to connect through Telnet correctly. Apparently "12" is the numeric response code equivalent of "CONNECT 9600." I never accounted for this because the fastest modems when I wrote the thing were at 2400. Looks like I've got some codes to start recognizing. Do you get to the "Waiting for a call" screen? Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 On 11/18/2023 at 8:39 AM, Pab said: Can you record what your machine is doing from first running LINK20X.bas until the AT loop you describe? Just cellphone footage would help. I can try to figure out exactly where the problem is happening and try to fix or work around it. i missed this - yep, ill get that sometime today or tomorrow. Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 before I go too much further - is there a current standard atr that you are working from you can share? Or is it the same one from the zoom meeting a couple of weeks ago? I want to make sure I am working with the same thing. There needs to be git for atari8... Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 And another question: which BASIC are you running? Atari BASIC C or Altirra BASIC? I've found that Altirra BASIC runs too fast for the modem to respond to the escape code sequence before trying to send a command. Working on that. Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 I used Atari BASIC C, but also tried Altirra BASIC.. Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 New build: 11/20/23 Adds support for speeds of 9600, 14400, 19.2K Removes all references to the printer and logging to printer Increased delay before and after sending modem escape codes, required for Altirra and other faster BASICs. link201x.bas Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 WOOOT! Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 No guarantee it will solve your problem yet, but it's a step in the right direction. I think it has to have something to do with not properly responding to codes from the modem. Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 @Pab are you using sparta bootable disk, or spartax for this? Link to comment Share on other sites More sharing options...
Pab Posted November 20, 2023 Share Posted November 20, 2023 Sparta X. I can try with SD 3.2. Link to comment Share on other sites More sharing options...
rickcollette Posted November 20, 2023 Author Share Posted November 20, 2023 im on spartaX as well - i just booted everything up in altirra - and it does now go to the wait for call screen. I have not done anything beyond that - but now I wanna try on hardware. See how it goes. Link to comment Share on other sites More sharing options...
Pab Posted November 22, 2023 Share Posted November 22, 2023 Weird question. I originally wrote this for the T: driver for the 830 and SX and have it doing an XIO 36 to adjust the transmission speed. With the R: driver(s), do I really need to adjust the transmission speed with each connection? Or could I just talk to the serial port/modem at 9600/19.2 and let the modem downshift the communication speed to whatever it needs? I'm finding difficulties taking incoming calls at 9600 and 14.4. The BBS keeps wanting to default down to 300 bps. Link to comment Share on other sites More sharing options...
Amis Posted November 25, 2023 Share Posted November 25, 2023 On 11/22/2023 at 2:13 PM, Pab said: Weird question. I originally wrote this for the T: driver for the 830 and SX and have it doing an XIO 36 to adjust the transmission speed. With the R: driver(s), do I really need to adjust the transmission speed with each connection? Or could I just talk to the serial port/modem at 9600/19.2 and let the modem downshift the communication speed to whatever it needs? I'm finding difficulties taking incoming calls at 9600 and 14.4. The BBS keeps wanting to default down to 300 bps. Simple and not a weird question at all- open the throttle - XIO 36,15,0 and remove the variable baud rate code as it’s a complexity which is unnecessary. Link to comment Share on other sites More sharing options...
Pab Posted November 25, 2023 Share Posted November 25, 2023 Wow. The things you forget after 30 years. Look at line 3231 of link20x.bas. I was starting work on networked E-mail! I'd forgotten all about that! Link to comment Share on other sites More sharing options...
Pab Posted November 29, 2023 Share Posted November 29, 2023 NEW BUILD: 231128 Alpha. Contains some major changes; suggest a reinstall if just playing around. Changes since last build: * Support for four file extenders for text files - ATASCII, ASCII, and up to two custom. * Initialization program now creates text files for each extender from cabinet files. No need to copy from “work disk” * Support for custom directory for E-mail base; no longer confined to D1: * Changing references to programs and CONFIG files to “D:” instead of “D1:” for DOS’s that default to current drive and path for "D:" * Message base sizes now defined in kilobytes, not sectors. * BBS now hangs up modem before waiting for call * All communication with serial port now at max speed * Path definitions for message bases and directories currently limited to 13 characters. Will expand that, but will take effort. * Delays in sending modem commands now timed by jiffy counter, to compensate for faster BASICs and hardware. * Renamed “AUTODOOR” to “MAINT” to better identify its purpose. * Expanded MAINT to allow more than one maintenance program to be run, the way it was originally intended. * Fixed bug preventing people from properly entering passwords or phone numbers, preveniting logins. Link201X-231128-alpha.atr Link to comment Share on other sites More sharing options...
rickcollette Posted November 29, 2023 Author Share Posted November 29, 2023 (edited) I started from scratch using the BUILD: 231128 Alpha Running on Atari800MacX Atari Basic ROM SpartaX Rom R: rs232.com from spartax Ran begin Reconfigured everything to be pretty minimal Ran the Main BBS program. When it tries to go into WFC mode I get error 12 on line 10020 I swear I am not trying to break this on purpose I really really want this to work Edited November 29, 2023 by rickcollette Link to comment Share on other sites More sharing options...
Pab Posted November 29, 2023 Share Posted November 29, 2023 The error 12 is because it doesn't know where to go after reporting the error. (The variable WH - for 'where' - hasn't been set by that point.) It calls the error handling routine, prints an error code, and then tries to go to the recovery line number - which doesn't exist, so error 12. Eventually the real error scrolls off the screen. Plug a STOP in before the GOTO WH. Then you can take that out once we know the "real" error and I can fix it. Hopefully. Link to comment Share on other sites More sharing options...
Pab Posted November 29, 2023 Share Posted November 29, 2023 But at least it's not working in a different way than it was not working before. Link to comment Share on other sites More sharing options...
