Shawn Jefferson Posted June 23, 2010 Share Posted June 23, 2010 Way back in the day when the MyIDE was first created, I remember an internal version of it that could plug into (or rather you had to solder it to) the BASIC ROM chip instead of the system ROM socket. That might be a way around it maybe. I suppose that you could also use the cartridge version of the MyIDE hardware with an internal SDX ROM, provided the driver can differentiate between internal and external MyIDE. I don't have an internal SDX myself, and use the Atarimax Flashcart version of SDX, so I'm ok. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 24, 2010 Share Posted June 24, 2010 Way back in the day when the MyIDE was first created, I remember an internal version of it that could plug into (or rather you had to solder it to) the BASIC ROM chip instead of the system ROM socket. That might be a way around it maybe. I suppose that you could also use the cartridge version of the MyIDE hardware with an internal SDX ROM, provided the driver can differentiate between internal and external MyIDE. I don't have an internal SDX myself, and use the Atarimax Flashcart version of SDX, so I'm ok. Someone was kind enough to donate me a cart version of MyIDE some months ago but since it was supplied with the ROM for the internal version I haven't done much with it. The external version might actually be more useful for my setup if I could work out some SDX drivers. I'll be looking into this in great detail when I get time. Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted June 25, 2010 Share Posted June 25, 2010 I might be interested in one of these as my last two 1050s are slowly adeteriorating and I have a couple of spare 2.5" HDDs Q1 How would I transfer files from PC to each of these storage devices (I have SIO2USB/APE) Q2 Can I easily boot basic /a turbo basic image and work as normal from my XE Q3 For games like Ultima III that support two drives, would this system allow this to work Q4 Would it work on an A800 (48K) Thanks Quote Link to comment Share on other sites More sharing options...
candle Posted June 25, 2010 Author Share Posted June 25, 2010 A1 Simplest and the fastest way is to use SD card for PC<->Atari transfers, as software on Atari side will read FAT32 formatted SD card as its own A2 its PBI device, so it is possible to use it with Basic A3 would not know, but i guess it would allow this as there will be support for ATR images as well as standard partitions A4 it would not - again, this is PBI device, so no PBI slot (XE or XL style - doesn't matter) - no fun hope it helps Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted June 25, 2010 Share Posted June 25, 2010 Thanks candle One more stupid question: To get files to the HDD you would copy them from the SD card using the atari [edit] I would also be interested in the solderless RAM upgrade for XL/XE (now that there are a few games that use more than 128K). Quote Link to comment Share on other sites More sharing options...
candle Posted June 25, 2010 Author Share Posted June 25, 2010 yup fastest way around Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted June 29, 2010 Share Posted June 29, 2010 I'm interested... Please finish it before I lose my job... Quote Link to comment Share on other sites More sharing options...
candle Posted June 29, 2010 Author Share Posted June 29, 2010 will certainly try to finnish it before i'll loose mine - it will be hard to finnish without software i use in my work Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 30, 2010 Share Posted June 30, 2010 This device will be worth waiting for, however long it takes. Quote Link to comment Share on other sites More sharing options...
Defender II Posted July 3, 2010 Share Posted July 3, 2010 Any idea on cost? Is there enough room inside the case for and actual 2.5 inch mechanical hard disk? Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted July 4, 2010 Share Posted July 4, 2010 Any idea on cost? Is there enough room inside the case for and actual 2.5 inch mechanical hard disk? Candle as far as I know does not have a set price in mind, but is looking to make it comparable or less than the SDrive NUXX... And yes there is room for a 2.5 laptop drive in the case. Quote Link to comment Share on other sites More sharing options...
Defender II Posted March 28, 2011 Share Posted March 28, 2011 Any idea on cost? Is there enough room inside the case for and actual 2.5 inch mechanical hard disk? Candle as far as I know does not have a set price in mind, but is looking to make it comparable or less than the SDrive NUXX... And yes there is room for a 2.5 laptop drive in the case. Thanks. I'd like one. Any updates on this? Quote Link to comment Share on other sites More sharing options...
candle Posted March 28, 2011 Author Share Posted March 28, 2011 unfortunatly no i'm a bit tired with hardware for a while - need to switch to software a bit hopefully all of us will gain on my switch Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 28, 2011 Share Posted March 28, 2011 i'm a bit tired with hardware for a while - need to switch to software a bit hopefully all of us will gain on my switch I'm still happy to self-assemble from scraps... Quote Link to comment Share on other sites More sharing options...
BillC Posted March 28, 2011 Share Posted March 28, 2011 i'm a bit tired with hardware for a while - need to switch to software a bit hopefully all of us will gain on my switch I'm still happy to self-assemble from scraps... I guess you want to take a break from programming and play with hardware then. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 28, 2011 Share Posted March 28, 2011 I guess you want to take a break from programming and play with hardware then. I'm doing both all the time. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 28, 2011 Share Posted March 28, 2011 Well boo... I was looking forward to this... How does this "switch" affect Ultimate 1MB? Quote Link to comment Share on other sites More sharing options...
