+HatNJ Posted July 25, 2013 Share Posted July 25, 2013 Yeah that was why I dropped off couldn't find a way to exit Quote Link to comment Share on other sites More sharing options...
Tillek Posted July 29, 2013 Share Posted July 29, 2013 Well... I replaced the flaky Falcon with the one I got off ebay a few months ago so we should be stable until I get space cleared to set up the Mega STE and give it the permanant home. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
Lord Cygnus Posted August 3, 2013 Share Posted August 3, 2013 (edited) Ok, here is my 'working' Lantronix UDS-1100 settings with my Atari 130XE and ICD P:R:Connection (RS232) when using 9600 baud terminals: BobTerm & ICE-T: On a PC log into the Lantronix UDS-1100 via 'Telnet Configuration' connection using their device installer utility to configure these settings: First, select '7 Defaults' and then, '9 Save and exit' to clear out any previous old settings. Next, select '1 Channel 1' and make these adjustments: *** Channel 1 Baudrate: 9600 I/F Mode: 4C Flow: 05 Port: 10003 Connect Mode: CE Send '+++' in Modem Mode: enabled Show IP addr after 'RING': enabled Auto increment source port: disabled Remote IP Adr: --- none ---, Port: 00000 Disconn Mode: 00 Flush Mode: 00 Example: UDS-1100 Settings by agpctech, on Flickr With this configuration and hardware combination, I'm able to flawlessly call 98% BBS'es without any problems such as double characters, ',j' characters, and interference. It works great for ATASCII / ASCII / ANSI! Took me a while to find the right combination and configuration between the UDS-1100, P:R:Connection, and Lantronix settings. I booted up SpartaDOS 2.3e and loaded the RS232 file first. Then, I either boot BobTerm or ICE-T terminals and it works! Enjoy, -=[Lord Cygnus]=- Edited August 3, 2013 by Lord Cygnus 2 Quote Link to comment Share on other sites More sharing options...
awace Posted August 25, 2013 Share Posted August 25, 2013 Can someone point me to Atari 8-bit related BBSs - telnet addresses - and if you run one please PM me with some background info etc. Bonus points for anyone running a BBS with real Atari hardware. Going to try Bobterm. telnet://thunderdome.homeip.net:471 Quote Link to comment Share on other sites More sharing options...
awace Posted August 25, 2013 Share Posted August 25, 2013 Ok, here is my 'working' Lantronix UDS-1100 settings with my Atari 130XE and ICD P:R:Connection (RS232) when using 9600 baud terminals: BobTerm & ICE-T: On a PC log into the Lantronix UDS-1100 via 'Telnet Configuration' connection using their device installer utility to configure these settings: First, select '7 Defaults' and then, '9 Save and exit' to clear out any previous old settings. Next, select '1 Channel 1' and make these adjustments: *** Channel 1 Baudrate: 9600 I/F Mode: 4C Flow: 05 Port: 10003 Connect Mode: CE Send '+++' in Modem Mode: enabled Show IP addr after 'RING': enabled Auto increment source port: disabled Remote IP Adr: --- none ---, Port: 00000 Disconn Mode: 00 Flush Mode: 00 Example: UDS-1100 Settings by agpctech, on Flickr With this configuration and hardware combination, I'm able to flawlessly call 98% BBS'es without any problems such as double characters, ',j' characters, and interference. It works great for ATASCII / ASCII / ANSI! Took me a while to find the right combination and configuration between the UDS-1100, P:R:Connection, and Lantronix settings. I booted up SpartaDOS 2.3e and loaded the RS232 file first. Then, I either boot BobTerm or ICE-T terminals and it works! Enjoy, -=[Lord Cygnus]=- if i remember the modem string is at &fe0x1 this might make the atari work on modem w out hanging up. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 5, 2013 Share Posted September 5, 2013 (edited) Don't forget ANG. Also Atari 8-bit. telnet://angbbs.dnsalias.com He is having some strange issues going on there but you can still login. Just trying out BBSs to make sure that I have all scheduled to call. I have noticed the Antic BBS is down. Anyone have an idea on that? This is what I got from this one: Last login: Thu Sep 5 07:13:20 on ttyp1 Welcome to Darwin! Clu$ telnet telnet> open (to) angbbs.dnsalias.com Trying 83.86.189.132... Connected to angbbs.dnsalias.com. Escape character is '^]'. A.P.E. Atari 8-bit Internet Modem http://www.atarimax.com/ Copyright 2011 Steven J Tucker The Atari is not ready to accept connections. Please try again later. Connection closed by foreign host. Edited September 5, 2013 by doctorclu Quote Link to comment Share on other sites More sharing options...
Joey Z Posted September 15, 2013 Share Posted September 15, 2013 (edited) Just trying out BBSs to make sure that I have all scheduled to call. I have noticed the Antic BBS is down. Anyone have an idea on that? yeah, I moved and haven't set it back up yet... in fact, none of my servers have been set back up yet. website is down too. Edited September 15, 2013 by Joey Z Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted October 14, 2013 Share Posted October 14, 2013 Hey Steve, last couple of times I've called your BBS I've been getting some kind of memory error message. I think other callers have seen it too. Just giving a "heads up". Here's a picture: Thanks! Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 14, 2013 Share Posted October 14, 2013 Hey Steve, last couple of times I've called your BBS I've been getting some kind of memory error message. I think other callers have seen it too. Just giving a "heads up". ... I saw it too and left him feedback about it. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted October 28, 2013 Share Posted October 28, 2013 Well ok, today I have been able to get on 8 bit Guild, Boot Factory, Dark Forces, Inside Atari, Starfleet Headquarters, The Grove, Thunderdome, YYZ Was not able to get on the Electric Cafe. Anyone I miss? Quote Link to comment Share on other sites More sharing options...
unrealprophet7 Posted October 29, 2013 Share Posted October 29, 2013 Hello All!!!I would like to start a Atari 8 bit BBS,running on one of my 8 bit systems,using a atari modem,and phone #.I have a bbs construction program,but having issues with it.Can I get ideas,suggestions,input??? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted October 31, 2013 Share Posted October 31, 2013 Well ok, today I have been able to get on 8 bit Guild, Boot Factory, Dark Forces, Inside Atari, Starfleet Headquarters, The Grove, Thunderdome, YYZ Was not able to get on the Electric Cafe. Anyone I miss? Hmm, it's 7:22am here, October the 31st, and I can't get on to the Electric Cafe either. Hopefully, DocRotCod will take care of the problem soon... Quote Link to comment Share on other sites More sharing options...
doctorclu Posted November 1, 2013 Share Posted November 1, 2013 Hello All!!!I would like to start a Atari 8 bit BBS,running on one of my 8 bit systems,using a atari modem,and phone #.I have a bbs construction program,but having issues with it.Can I get ideas,suggestions,input??? BTW I think this is great. I saw "BBS Contruction Set" and I said "DANNG!! Haven't heard of that in a while." That is so cool. Get with Abdul on Boot Factory and maybe he can help you in setting up the drivers for a connecting. He has managed to get quite a few BBS programs to work. 1 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted November 1, 2013 Share Posted November 1, 2013 So last few days I've been getting this message from YYZ, is all good there? If so, hope things get better soon. "YYZ BBS is offline or down for quick maintenance. Please call back shortly. " Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 1, 2013 Share Posted November 1, 2013 While BBCS was a really neat idea, it was not a very robust BBS and was riddled with problems. I was not able to get that one to work across the internet although I didn't spend a whole lot of time with it. I would recommend getting a copy of BBS:Express 850 and using that. You can download it off the internet. Or buy a copy of BBS:Express PRO from video 61 or the later version TCP/IP Express PRO from Steve Carden. Quote Link to comment Share on other sites More sharing options...
Lord Cygnus Posted November 2, 2013 Share Posted November 2, 2013 (edited) So last few days I've been getting this message from YYZ, is all good there? If so, hope things get better soon. "YYZ BBS is offline or down for quick maintenance. Please call back shortly. " YYZ BBS had a bad SIO cable I discovered. I replaced it and brought the BBS back online. Don't worry, I check the status of the board each day. Of course, sometimes the board may be down because I'm using the SIO2PC through APE to work on .atr images (which YYZ BBS runs on). I really need to buy an additional SIO2USB to do this with my other Atari 130XE instead of having to take the board down every so often. Ahhh, the life of a SysOp! -=[Lord Cygnus]=- Edited November 2, 2013 by Lord Cygnus Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 4, 2013 Share Posted November 4, 2013 Never ends, does it? Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted November 4, 2013 Share Posted November 4, 2013 Sorry guys.. BBS was hung on running jobs. Should be ok now. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 4, 2013 Share Posted November 4, 2013 Sorry guys.. BBS was hung on running jobs. Should be ok now. Hey, no problem Doc - us SysOps all have "down" times. Just glad to see you back up. I've grown quite fond of all the Atari BBS's we've got going now... Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 9, 2013 Share Posted November 9, 2013 Hmm, back to square one - couldn't get on this evening. Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted November 13, 2013 Share Posted November 13, 2013 Ok guys my BBS is sick. It was locked up again so I restarted and I noticed the time and data were flipping back and forth every half second between two different times/dates. So I pulled my rtime8 cart out and let it use the IDE+ 2.0 device time and that resolved that. I then proceeded to check the filesystem and had quite a few filesystem errors (mostly related to the online games, not the message bases or userlog). Now that I have cleaned up the filesystem, every time I check the drive, it runs for a bit then the a8 reboots. I'm thinking I might have a bad a8 power supply. I will work to get the BBS back online but that is what is going on and i'm not putting it back up until I know it's stable. I'd give it a few days. Thomas Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 14, 2013 Share Posted November 14, 2013 Hang in there Doc, you'll get it sorted out sooner or later. We all have those days. Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted November 14, 2013 Share Posted November 14, 2013 Ok it's back up! I straightened out the filesystem errors. I'll keep an eye on it, but no worse for wear as everything was backed up. Thomas 2 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 25, 2013 Share Posted November 25, 2013 (edited) (Fair warning - I am most certainly ! a programmer - I became familiar with the scripting Language in BBS Express! ST so that I could get the most I could out of my BBS. So I'm posting the scripts I wrote with full apologies in advance to those who truly can program, such as flashjazzcat and others here. I'm posting this here because I think the 8bit version of BBS express also includes a scripting language, and thought some of those SysOps might be familiar with this) A short time back, we hit the high message limit on our message bases. BBSExpress! ST only accepts up to 32000 messages. In fact, when we hit thatpoint, I wasn't even aware there was a limitation and got an error messagethat wouldn't allow the BBS software to start once triggered. Fortunately,among the archives from Rich Sanchez's old support BBS I found a utility thatreset the message bases. All well and good. Of course, once reset, thecounter now shows the current high message as if we just started over again.So...what's a SysOp to do? Well, turn to the built in scripting language ofcourse. Seemed simple enough - &25 returns the high message marker. I thought I'djust adjust the relevant script to put the &25 into a field, then do a " +32000", then read the field for display in the menu. Tried that and everytimethe result was "0". Huh, I thought. So just for the fun of it I put " &25 +1" and the result was the correct amount. Hmm. So I tried a few more times,bumping the number up each time, and the results were spot on. So I gotambitious and went with 31000. Results again went back to zero. So just forthe fun of it, I entered an amount that was equal to 32000 - the current highmessage count, and that worked. Then I tried 1 digit over that number. Bam,back to zero. Apparently the scripting language also has a high limit of 32k!Ouch. Now what to do...Well, I could just put something like " &25 " plus 32k in plain text, lettingusers know there is an additional 32000 messages, but that's not veryappealing to me. (and besides that, who wants to set there and go "hmm,number xxxx plus 32000, ah - that's the high number!" ).I've not found a perfect solution so far. I finally put &25 in a field, minus4000 (current number plus) and then 36 (the actual first 2 digits in the highmessage count) like this:PRINTE ' Total Number Of Messages ---------- 36[TMSGS]'So now it is showing an accurate number. You can easily see the problem withthis though - I'll have to adjust the scripts every time the thousands digitrolls over...This will do for now, but I'm still thinking about it. Any and allsuggestions welcome as always. Here are the 2 scripts (the first one calls the info, the 2nd one actually creates it): SCRIPTABORT OFFCLEAR SCREEN; Small menu script to show users some BBS stats.DEFINE C_DRIVE = 'C'DEFINE MENUS_PATH = 'C:\BBS\MENUS_80\'DEFINE CH_DRIVEDEFINE CH_DIRECTORYDEFINE USER_SELECTIONDEFINE MCALLDEFINE MCALL_DRIVE = 'C'DEFINE MCALL_PATH = 'C:\BBS\LISTINGS\'DEFINE LMCALLDEFINE LMCALL_DRIVE = 'C'DEFINE LMCALL_PATH = 'C:\BBS\LISTINGS\'DEFINE TMSGSDEFINE TMSGS_DRIVE = 'C'DEFINE TMSGS_PATH = 'C:\BBS\LISTINGS\'; Next 3 "open" statements grab info for this months call totals,; last months call totals, and total messages, for insertion into; the menu screen.OPEN ('[MCALL_PATH]MTH_CALL.TXT', INPUT)FINPUT MCALLCLOSEOPEN ('[LMCALL_PATH]LM_CALL.TXT', INPUT)FINPUT LMCALLCLOSEOPEN ('[TMSGS_PATH]T_MSGS.TXT', INPUT)FINPUT TMSGSCLOSEPRINTE '\N\N\N\N\N'PRINTE '\R{}---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---{}\B' CENTERPRINTEPRINTE ' The Current Time Is --------------- &23'PRINTEPRINTE ' The Current Date Is --------------- &24'PRINTEPRINTE ' Total Number Of Messages ---------- 36[TMSGS]'PRINTEPRINTE ' Total Number Of Calls So Far ------ &26'PRINTEPRINTE ' Total Number Of Calls This Month -- [MCALL]'PRINTEPRINTE ' Total Number Of Calls Last Month -- [LMCALL]'PRINTEPRINTE ' Total Number Of Calls Today ------- &27'PRINTEPRINTE ' The Last Caller Was --------------- &28'PRINTEPRINTE '\R{}---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---<>---{}\B' CENTERPRINTEPRINTEPRINTE 'Press Any <\rKey\b> To Continue...' CENTERGET_KEY USER_SELECTIONIF USER_SELECTION = '' THENENDIFGOTO EOFEOF:CLOSEDEFAULT_PATHEXECUTE ('C:\BBS\MENUS_80\SYSNEWS.COM')EXIT and the logoff.scr script: SCRIPTABORT OFFCLEAR SCREEN; This script asks users if they want to leave a 1-line message or; not, and saves it if they do...DEFINE PICS_DRIVE = 'C'DEFINE PICS_PATH = 'C:\BBS\MENUS_80\PICS\DEFINE CH_DRIVEDEFINE CH_DIRECTORYDEFINE COUNTERDEFINE DELAYDEFINE MCALLDEFINE MCALL_DRIVE = 'C'DEFINE MCALL_PATH = 'C:\BBS\LISTINGS\'DEFINE TMSGSDEFINE TMSGS_DRIVE = 'C'DEFINE TMSGS_PATH = 'C:\BBS\LISTINGS\'DEFINE USER_SELECTIONDEFINE SELECTIONDEFINE ONEDEFINE BADLOGF_DRIVE = 'C'DEFINE BADLOGF_PATH = 'C:\BBS\BAD_LOG.OFF\'DEFINE USERNUM = &31INTEGER RC;This section is used to censor any users whom I do not want to;have this privilege...and visitors.IF COMMAND_LEVEL(2) THENELSEGOTO MONTHLY_CALLSENDIFIF &31 = '29' THENGOTO MONTHLY_CALLSENDIFTOP:CLEAR SCREENPRINTEPRINTE '\i \o' CENTERPRINTE '\i \o' CENTERPRINTE '\i Would You Like To Leave A 1-Line Message For Other Callers? (Y/N) \o' CENTERPRINTE '\i \o' CENTERPRINTE '\i \o' CENTERPRINTE '\n\n\n\n\n\n\n\n\n\n'GET_KEY SELECTIONIF SELECTION = 'Y' THENGOTO ENTERENDIFEF SELECTION = 'N' THENGOTO MONTHLY_CALLSENDIFENTER:PRINTEPRINTE 'Please Enter Your 1-Line Message Here:' CENTERPRINTEINPUT ONE 74PRINTEPRINTE 'Is That Correct? (\gY\bes/\rN\bo/Quit)' CENTERGET_KEY SELECTIONIF SELECTION = 'Y' THENCLOSEOPEN ('C:\BBS\LOGS\MESSAGE.TXT', OUTPUT)FPRINTEFPRINTE 'Before Logging Off, --> &1 <-- Mumbled Something About:'FPRINTEFPRINTE '[ONE]'FPRINTECLOSEGOTO MONTHLY_CALLSEF SELECTION = 'N' THENCLEAR SCREENGOTO ENTEREF SELECTION = 'Q' THENCLEAR SCREENGOTO TOPENDIF; Routine to count monthly callsMONTHLY_CALLS:IF &31 = '1' THENELSEOPEN ('[MCALL_PATH]MTH_CALL.TXT', INPUT)FINPUT MCALLCLOSEMCALL = MCALL + 1RC = FILE_DELETE ('[MCALL_PATH]MTH_CALL.TXT')OPEN ('[MCALL_PATH]MTH_CALL.TXT', APPEND)FPRINTE 'MCALL'CLOSEENDIFTOTAL_MESSAGES:TMSGS = &25 - 4000RC = FILE_DELETE ('[TMSGS_PATH]T_MSGS.TXT')OPEN ('[TMSGS_PATH]T_MSGS.TXT', APPEND)FPRINTE 'TMSGS'CLOSE; Routine to show logoff picturePICTURE:CH_DRIVE = FILE_CHGDRIVE ('[PICS_DRIVE]')CH_DIRECTORY = FILE_CHGDIR ('[PICS_PATH]'); -- 1 = ASCII (text); -- 2 = VT52 (mono); -- 3 = VT52 (color); -- 4 = ANSI (mono); -- 5 = ANSI (color)IF &66 = '1' THENTRANSLATION (1)GOTO ASCIIEF &66 = '2' THENTRANSLATION (2)GOTO ASCIIEF &66 = '3' THENTRANSLATION (3)GOTO VT52EF &66 = '4' THENTRANSLATION (4)GOTO ASCIIEF &66 = '5' THENTRANSLATION (5)GOTO ANSIENDIFASCII:CLEAR SCREENCOUNTER = RANDOM (3)IF COUNTER = '1' THENVIEW ('[PICS_PATH]LOGOFF1.ASC')GOTO BADLOGFEF COUNTER = '2' THENVIEW ('[PICS_PATH]LOGOFF2.ASC')GOTO BADLOGFEF COUNTER = '3' THENVIEW ('[PICS_PATH]LOGOFF3.ASC')GOTO BADLOGFENDIFANSI:CLEAR SCREENCOUNTER = RANDOM (3)IF COUNTER = '1' THENVIEW ('[PICS_PATH]LOGOFF1.ANS')GOTO BADLOGFEF COUNTER = '2' THENVIEW ('[PICS_PATH]LOGOFF2.ANS')GOTO BADLOGFEF COUNTER = '3' THENVIEW ('[PICS_PATH]LOGOFF3.ANS')GOTO BADLOGFENDIFVT52:CLEAR SCREENCOUNTER = RANDOM (3)IF COUNTER = '1' THENVIEW ('[PICS_PATH]LOGOFF1.V52')GOTO BADLOGFEF COUNTER = '2' THENVIEW ('[PICS_PATH]LOGOFF2.V52')GOTO BADLOGFEF COUNTER = '3' THENVIEW ('[PICS_PATH]LOGOFF3.V52')GOTO BADLOGFENDIF; Routine to reset users entry to 0 for the BAD_LOG.OFF script.BADLOGF:CH_DRIVE = FILE_CHGDRIVE ('[bADLOGF_DRIVE]')CH_DIRECTORY = FILE_CHGDIR ('[bADLOGF_PATH]')OPEN ('[bADLOGF_PATH]USER.[uSERNUM]', OUTPUT)FPRINTE '0'CLOSEEXIT:FOR DELAY = 1 TO 1000 DOENDFORSTATUS_BOX (ON)CLOSEDEFAULT_PATHEXIT Thanks everyone. Edited November 25, 2013 by DarkLord 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 27, 2013 Share Posted November 27, 2013 Interesting... I wonder if PRO 2.1a (the one I run) supported scripting... don't remember hearing about this. Maybe I'll read my docs. Quote Link to comment Share on other sites More sharing options...
