pjduplooy Posted January 14 Share Posted January 14 Rasmus Sorry, bot Mario Bros games. The one listed under Software-Games, and the TI99 Mario Bros under F18A specific games. And I had F18A enabled. Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 14 Share Posted January 14 Tried again after re-starting computer and it's still bad. Might try a different browser? Edit: Saving to Cassette under Firefox 9 has failed. 😕 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 14 Author Share Posted January 14 (edited) 1 hour ago, Retrospect said: Saving to Cassette under Firefox 9 has failed. Firefox 9? My Firefox is 121.0.1! [Edit: and saving in Firefox also works for me.] Edited January 14 by Asmusr Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 14 Author Share Posted January 14 3 hours ago, pjduplooy said: Rasmus Sorry, bot Mario Bros games. The one listed under Software-Games, and the TI99 Mario Bros under F18A specific games. And I had F18A enabled. Do you have 32K enabled? Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 14 Share Posted January 14 I'm not sure if "warning: sample rate is 96,000 not 48,000" in the log has anything to do with my troubles. Either way, tape saving won't work in either Chrome or Firefox and it does usually work fine in chrome. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 15 Author Share Posted January 15 9 hours ago, Retrospect said: I'm not sure if "warning: sample rate is 96,000 not 48,000" in the log has anything to do with my troubles. Yes it could. There is a note about it in the code: 🙂 if (this.sampleRate !== 0 && this.sampleRate !== 48000) { // TODO: Resample ZERO and ONE this.log.warn("Sample rate is " + this.sampleRate + ", not 48000."); } If you have any idea why the sample rate on your computer has changed, you could try to set it back. Otherwise you have to wait for my fix. Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 15 Share Posted January 15 11 minutes ago, Asmusr said: Otherwise you have to wait for my fix I'll take this option. Thanks in advance. Edit: I'm not as daft as I think I am, I went into my advanced sound settings and found it to be set to 96,000hz. After testing a tape I've fixed my issue. I had no idea about this until I googled 'why has my sample rate changed' , i still don't know what i did to change it but i put it back to 32-bit 48000hz and it's happy now. 2 Quote Link to comment Share on other sites More sharing options...
pjduplooy Posted January 15 Share Posted January 15 Hi Rasmus. Yes I have. Quote Link to comment Share on other sites More sharing options...
SteveB Posted January 15 Share Posted January 15 8 hours ago, Retrospect said: i put it back to 32-bit 48000hz Isn't 16bit with 44.1khz the default sample rate? Like the Audio CD ? Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 15 Share Posted January 15 1 hour ago, SteveB said: Isn't 16bit with 44.1khz the default sample rate? Like the Audio CD ? Possibly? I don't know. I don't even know how or why it changed, so I never knew what setting it was on, I just picked one that JS99er seemed happy with. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 15 Share Posted January 15 4 hours ago, SteveB said: Isn't 16bit with 44.1khz the default sample rate? Like the Audio CD ? It depends upon your audio device. Most of the time, Windows will default to the highest quality setting offered by the driver or what the driver says to use. The highest quality setting on my laptop is 24-bit 192kHz, and the default is 24-bit 44kHz. Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 15 Share Posted January 15 25 minutes ago, OLD CS1 said: Windows will default to the highest quality setting offered by the driver Is it possible that could happen when Windows does an update? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 15 Share Posted January 15 1 hour ago, Retrospect said: Is it possible that could happen when Windows does an update? With everything else Windows and Chrome do when they update, why not? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 16 Author Share Posted January 16 16 hours ago, pjduplooy said: Hi Rasmus. Yes I have. Both games work fine for me. What does the log say? Quote Link to comment Share on other sites More sharing options...
pjduplooy Posted January 16 Share Posted January 16 Hi. Sorted, for some weird reason TIPI Emulation was turned on in JS99'er when I use Chrome, but turned off in Brave Browser. Turned it off, so its working now. Sorry for the noise. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 16 Author Share Posted January 16 On 1/15/2024 at 7:04 AM, Retrospect said: After testing a tape I've fixed my issue. I had no idea about this until I googled 'why has my sample rate changed' , i still don't know what i did to change it but i put it back to 32-bit 48000hz and it's happy now. I have deployed a fix in version 9.9.2. I'm not able to test it myself, since the control to change the sample rate is disabled on my machine. So I would appreciate if you could set the sample rate back to 96000 and try if the fix is working. I would expect saving sound to sound normal and the output to be a 96000 Hz wav file. 5 Quote Link to comment Share on other sites More sharing options...
Retrospect Posted January 16 Share Posted January 16 1 hour ago, Asmusr said: I have deployed a fix in version 9.9.2. I'm not able to test it myself, since the control to change the sample rate is disabled on my machine. So I would appreciate if you could set the sample rate back to 96000 and try if the fix is working. I would expect saving sound to sound normal and the output to be a 96000 Hz wav file. Okay, I set it back to 96000 and it worked - JS99er recorded a Cassette, and was able to play it back and load it too. 👍 6 Quote Link to comment Share on other sites More sharing options...
Cheung Posted March 2 Share Posted March 2 sorry if this has been asked before, but is it possible to copy or otherwise output the BASIC or XB program in JS99er's memory as ASCII text? I see that you can paste a program written into ASCII text into the JS99er, but I couldn't find a way to copy it to the clipboard or therwise write it as ASCII to a file. Thanks for the trouble. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted March 2 Author Share Posted March 2 1 hour ago, Cheung said: sorry if this has been asked before, but is it possible to copy or otherwise output the BASIC or XB program in JS99er's memory as ASCII text? I see that you can paste a program written into ASCII text into the JS99er, but I couldn't find a way to copy it to the clipboard or therwise write it as ASCII to a file. Thanks for the trouble. Not directly, but you can save to disk, save the dsk file, open the dsk in TI99dir, and use F3 to view the file as text. 4 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted May 5 Share Posted May 5 Hi! Not getting any RAM at MEDIUM MEMORY(>7000->7FFF). This makes MINI MEMORY's @LOADER, fail. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted May 5 Author Share Posted May 5 8 hours ago, HOME AUTOMATION said: Hi! Not getting any RAM at MEDIUM MEMORY(>7000->7FFF). This makes MINI MEMORY's @LOADER, fail. Did you use an external mini memory rpk instead of the one in the App menu? Anyway, it should be fixed now. 1 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted May 5 Share Posted May 5 I had done this... ...works now though! I was giving this a spin... ...yours is the only EMULATOR, that does it any justice! Though I have to remember to hit the REC, button in the virtual TAPE recorder(to hear live sound). I seem to be crashing after a few minutes ...It used to run longer ...maybe a memory issue on my side... Thanks! Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted May 20 Share Posted May 20 I was wondering @Asmusr are you going to update your Github repo at some point: https://github.com/Rasmus-M/Js99er as that version is 6.3.2 (23 July 2018) And I am looking at setting little different version for my O.P.A. development work, and it would be nice to able to do so with your latest version. As I test I installed the github version on my domain https://ti99ers.com and it is running ok, but of course missing all the cool and amazing new features you have added over the years. Please when you have chance let me know, and if need be we can discuss this via private message, you done amazing work with this javascript emulator. Thanks. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 20 Share Posted May 20 14 minutes ago, Gary from OPA said: I was wondering @Asmusr are you going to update your Github repo at some point: https://github.com/Rasmus-M/Js99er as that version is 6.3.2 (23 July 2018) And I am looking at setting little different version for my O.P.A. development work, and it would be nice to able to do so with your latest version. As I test I installed the github version on my domain https://ti99ers.com and it is running ok, but of course missing all the cool and amazing new features you have added over the years. Please when you have chance let me know, and if need be we can discuss this via private message, you done amazing work with this javascript emulator. Thanks. Of course I'll let @Asmusr speak some more on it if he needs to, but back in the 2018 area, he started programming JS99er in Angular, so here is the uptodate thread https://github.com/Rasmus-M/js99er-angular FYI. 1 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted May 20 Share Posted May 20 12 minutes ago, RickyDean said: Of course I'll let @Asmusr speak some more on it if he needs to, but back in the 2018 area, he started programming JS99er in Angular, so here is the uptodate thread https://github.com/Rasmus-M/js99er-angular FYI. ok, thanks i will take a look at that version later on this week, and see how to set it up for my development needs. i didn't know there was a new typescript design, makes sense now, as there no mention of it in the first post on this thread. so much catching up to do, what happens when you miss a few years reading daily here on this forum! 1 Quote Link to comment Share on other sites More sharing options...
