citrus3000psi Posted May 3, 2017 Share Posted May 3, 2017 So does anyone know if these (Sophia) boards are available for purchase? I talked to @Simius yesterday and he said a batch of boards would be available for purchase in about a month. He did not give details on the size of the batch or an exact ETA The project is closed source in case anyone was wondering. Quote Link to comment Share on other sites More sharing options...
Brentarian Posted May 3, 2017 Share Posted May 3, 2017 Already fixed. What's the name of such Our5oft demo? Thank you, Simius! Quote Link to comment Share on other sites More sharing options...
lemiel Posted May 3, 2017 Share Posted May 3, 2017 That one? https://demozoo.org/productions/111372/ http://g2f.atari8.info/instrukcja.html Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 4, 2017 Share Posted May 4, 2017 Hi Simius I have made a Component cable and have both jumpers installed on my Rev.A board but I cannot get a picture on my monitor. The only thing that works for me is sound. My cable is as follows: Pin 1 - Red and White audio connections signal terminal (connected to pin 2 of RF modulator internally) Pin 2 - Component Pb signal (blue) Pin 3 - Component Y signal (green) Pin 4 - Component Pr signal (red) Pin 6 - Signal ground for all signals I have tried both jumpers on or off but assume they should normally both be installed for it to work. I have tested from the numbers pins on the 9 pin connector through to the component signals using a continuity test and they are all connected as they should be. GTIA is installed on Sophia board (with index notch to the left) and it is installed in the GTIA socket of 800XLF (UK PAL model with integrated FREDDIE chip). Sound and video output is working over composite using the standard inbuilt connector. Have you any ideas why this may not be working for me? Quote Link to comment Share on other sites More sharing options...
+mytek Posted May 4, 2017 Share Posted May 4, 2017 Hi Simius I have made a Component cable and have both jumpers installed on my Rev.A board but I cannot get a picture on my monitor. The only thing that works for me is sound. My cable is as follows: Pin 1 - Red and White audio connections signal terminal (connected to pin 2 of RF modulator internally) Pin 2 - Component Pb signal (blue) Pin 3 - Component Y signal (green) Pin 4 - Component Pr signal (red) Pin 6 - Signal ground for all signals I have tried both jumpers on or off but assume they should normally both be installed for it to work. I have tested from the numbers pins on the 9 pin connector through to the component signals using a continuity test and they are all connected as they should be. GTIA is installed on Sophia board (with index notch to the left) and it is installed in the GTIA socket of 800XLF (UK PAL model with integrated FREDDIE chip). Sound and video output is working over composite using the standard inbuilt connector. Have you any ideas why this may not be working for me? I hate to say it, but it could be an incompatibility of the component video processing in your monitor with the strange timing of the A8. I have two monitors that don't work (Insignia and Element), and we had a similar issue when I was testing over at Bob Woolley's house with one of his monitors as well (I forget the brand name). However the monitors that do seem to always work are ones by Samsung (I have one that works, so does Bob, and also Simius). - Michael Quote Link to comment Share on other sites More sharing options...
Simius Posted May 4, 2017 Author Share Posted May 4, 2017 (edited) As Mytekcontrols said, that may be an intolerance to different lenghts of half-images. Do you have the SCART connector in your TV set? Edited May 4, 2017 by Simius Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 4, 2017 Share Posted May 4, 2017 Ok thanks What is the frequency it uses over Component? Is it 240p, 480p or 480i (or something else)? I wanted to use it with my monitor but I do have a 14" Trinitron TV with SCART I can use and fortunately a spare d-sub connector I could wire up to it. Quote Link to comment Share on other sites More sharing options...
+mytek Posted May 4, 2017 Share Posted May 4, 2017 Ok thanks What is the frequency it uses over Component? Is it 240p, 480p or 480i (or something else)? I wanted to use it with my monitor but I do have a 14" Trinitron TV with SCART I can use and fortunately a spare d-sub connector I could wire up to it. I would definitely suggest wiring up the DB9 to SCART connection and try it on your Trinitron. Chances are very good that it'll work just fine with that TV. Good luck - Michael Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 4, 2017 Share Posted May 4, 2017 Thanks. Would definitely prefer to connect it to the 24" Dell Monitor if possible though. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 5, 2017 Share Posted May 5, 2017 I talked to @Simius yesterday and he said a batch of boards would be available for purchase in about a month. He did not give details on the size of the batch or an exact ETA The project is closed source in case anyone was wondering. I missed this thread completely but I am definitely interested in one board. I'll have to keep an eye out for when Simius releases the next batch Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted May 5, 2017 Share Posted May 5, 2017 What is the frequency it uses over Component? Is it 240p, 480p or 480i (or something else)?IIRC it's switchable to either 240p or 480i. Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 5, 2017 Share Posted May 5, 2017 (edited) Right, i've made up an RGB SCART cable with better results, but still not working right (though it is not a cable I am proud of). I now have it connected to my old Trinitron TV. When I switch the input on the TV to the SCART, the picture appears for about 1 second then disappears. While it is visible it looks great (though I am not sure it is RGB since the TV is supposed to display a different symbol for RGB SCART). Every time I switch back to the input it appears again stable then vanishes after 1 second each time. Does anybody know what could be causing this? Also, does anyone know where I could get a better quality cable in the UK (mine in Rev.A so not the same as Rev.B boards). Edited May 5, 2017 by steddyman Quote Link to comment Share on other sites More sharing options...
Simius Posted May 5, 2017 Author Share Posted May 5, 2017 (edited) Both jumpers are open? What type of monitor do you have? 24" Dell that's too little information. Edited May 5, 2017 by Simius Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 5, 2017 Share Posted May 5, 2017 Yes they are, though I have tried it with the Interlaced jumper also closed and it does the same. Quote Link to comment Share on other sites More sharing options...
Simius Posted May 5, 2017 Author Share Posted May 5, 2017 Try to disconnect CSYNC signal from pin20 SCART and connect a plain video signal from pin1 DIN socket instead. Write what you see. Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 5, 2017 Share Posted May 5, 2017 Not quite sure what you mean there Simius. I understand disconnect pin20 on the SCART end, but pin1 on the D-SUB socket is the audio connection isn't it? Quote Link to comment Share on other sites More sharing options...
lemiel Posted May 5, 2017 Share Posted May 5, 2017 Standard monitor jack - 5 pin DIN socket - from its first pin. Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 5, 2017 Share Posted May 5, 2017 Ah right. I started again with another cable because the old one was a mess and noticed my issue. I had accidentally connected the CVBS signal to the wrong pin. Working perfectly now. Simius, did you say my Rev A board had the latest CPLD code with the auto palette selection? Quote Link to comment Share on other sites More sharing options...
gozar Posted May 6, 2017 Share Posted May 6, 2017 If I have the original batch, how do I get the latest CPLD code? I have a USB blaster to upgrade it. Quote Link to comment Share on other sites More sharing options...
Joey Z Posted May 6, 2017 Share Posted May 6, 2017 (edited) If I have the original batch, how do I get the latest CPLD code? I have a USB blaster to upgrade it. http://atariage.com/forums/topic/258702-new-development-gtia-in-cpld/?p=3745241 I don't know if this is the latest or not, but it was the only one I found in the thread. EDIT: I suspect there will be a newer core available at some point: http://atariage.com/forums/topic/258702-new-development-gtia-in-cpld/?p=3754566 The above fix isn't in the first link. Edited May 6, 2017 by Joey Z 1 Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 6, 2017 Share Posted May 6, 2017 Simius. Can you comment on what code I have loaded on my Rev.A? A few games look really pink to me, especially Donkey Kong. My son even commented on it. If it isn't the latest can you please provide it to me. I do have a USB Blaster lying around somewhere I can flash it with. Thanks Quote Link to comment Share on other sites More sharing options...
Simius Posted May 6, 2017 Author Share Posted May 6, 2017 Simius, did you say my Rev A board had the latest CPLD code with the auto palette selection? Yes, you have the firmware with auto palette selection. Donkey Kong is pink because you have PAL computer. Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 6, 2017 Share Posted May 6, 2017 Thanks for confirming Quote Link to comment Share on other sites More sharing options...
Arnuphis Posted May 6, 2017 Share Posted May 6, 2017 I'd like one for my NTSC 800XL so please add me to the list for the next run. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
steddyman Posted May 6, 2017 Share Posted May 6, 2017 Just going back to my Component cable above. Is it correct that I did not connect the yellow S-video connection to the onboard Composite Sync? I thought sync was on green so didn't connect it. But I've just connected an Amiga via VGA to the same monitor and it reports it cannot display the screen mode. It was just blank with no error on the Component cable. Quote Link to comment Share on other sites More sharing options...
