+jedimatt42 Posted June 11 Author Share Posted June 11 Until I get a new image out, people should use Raspberry PI Imager and have it set the wifi settings while flashing the SD card. Hopefully I can fix this all this weekend. Apparently PI.CONFIG needs to be reimplemented to issue nmcli commands instead of manipulating wpa_supplicant files. I will also fix my testing notes to give me more fear around testing wifi. 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 11 Author Share Posted June 11 And thanks @dgrissom for exposing this! As well as persevering through the challenges you faced! Quote Link to comment Share on other sites More sharing options...
jrhodes Posted June 11 Share Posted June 11 I guess I'm just going to sit here on tipi version 3.25 for awhile, it's doing everything I need. If my Pi3b+ ever dies, I guess I'll try to get another; failing that, I'll have to pick up a Pi4. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 12 Author Share Posted June 12 I would like to understand how to read that. Could @jrhodes clarify please? It seems to me that you took the time to say something that literally goes without saying. Maybe this was literal, and just not thoughtful with regard to the audience. Or maybe this was a solicitation to find others that are not x.0 adopters. Or maybe this was an attempt at a ward to others? All of the above, and whatever other reason is fine, I would just like to know how to read the posts in this forum. 3 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted June 12 Share Posted June 12 1 hour ago, jedimatt42 said: I would like to understand how to read that. Could @jrhodes clarify please? It seems to me that you took the time to say something that literally goes without saying. Maybe this was literal, and just not thoughtful with regard to the audience. Or maybe this was a solicitation to find others that are not x.0 adopters. Or maybe this was an attempt at a ward to others? All of the above, and whatever other reason is fine, I would just like to know how to read the posts in this forum. Yes it was meant literally; I'm happy with my tipi the way it is and don't see a reason to update. No, I'm not trying to stop anyone from upgrading to the latest version. Sorry, guess I have a habit of just posting what ever is on my mind as if I was talking to myself. 2 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted June 15 Share Posted June 15 (edited) On 6/12/2024 at 10:42 AM, jrhodes said: Sorry, guess I have a habit of just posting what ever is on my mind as if I was talking to myself. And here I've been silent all this time with noise noise all in my head. Tipi is the next best thing to chocolate Edited June 15 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted June 15 Share Posted June 15 1 hour ago, GDMike said: Tipi is the next best thing to chocolate I will find out soon enough as I tonight mine in and will be setting it up this weekend. Only problem chocolate normally makes my sleepy so I hope I don't fall asleep enjoying my tipi. 4 Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 15 Share Posted June 15 My starlink went out a couple of weeks ago, in the process of bring everything backup, I was unable to access tipi's web page... I saw a lot of these in the log: root@gen-tipi:~# tail -F /var/log/daemon.log un 15 11:54:00 gen-tipi avahi-daemon[343]: Registering new address record for 192.168.2.206 on wlan0.IPv4. Jun 15 11:54:00 gen-tipi avahi-daemon[343]: Registering new address record for ::1 on lo.*. Jun 15 11:54:00 gen-tipi avahi-daemon[343]: Registering new address record for 127.0.0.1 on lo.IPv4. Jun 15 11:54:10 gen-tipi dhcpcd[663]: wlan0: Router Advertisement from fe80::f<snip> Jun 15 11:54:21 gen-tipi avahi-daemon[343]: Withdrawing address record for fd94:<snip> on wlan0. And before that Avahi was complaining about duplicate hostname. I decided maybe the best thing to do was just disable avahi. sudo systemctl mask avahi-daemon sudo systemctl disable avahi-daemon sudo systemctl stop avahi-daemon I could still ssh, but not go to the webpage. O'yea, need to add the port :9900, I book marked that URL for future reference! Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 17 Author Share Posted June 17 @dhe, So this sounds like a solution without a problem? It seems avahi was just doing its job. What problem was solved by disabling avahi? Just log messages that made you suspicious? I do not recommend others disable avahi. Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 18 Share Posted June 18 Do these have a corresponding version number in the DSR header? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted June 19 Share Posted June 19 I've never been able to set up my network using the TIPI configuration screen (aka CALL TIPI). I have to manually edit and add the wsupplicant file (that name always conjures visions of worshippers pleading with the TIPI gods to make it work 😄) to the SD card root for the network to take. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 19 Author Share Posted June 19 13 hours ago, dhe said: Do these have a corresponding version number in the DSR header? No. But those dates are in the ROM at >401A as a c-string ( null terminated char array ) The full build timestamp is there. This is shown in TIPICFG 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 19 Author Share Posted June 19 3 hours ago, Vorticon said: I've never been able to set up my network using the TIPI configuration screen (aka CALL TIPI). I have to manually edit and add the wsupplicant file (that name always conjures visions of worshippers pleading with the TIPI gods to make it work 😄) to the SD card root for the network to take. I will take a stab at fixing how PI.CONFIG executes this. If interested, here is a detailed analysis of how the PI OS handles headless setup : https://www.zansara.dev/posts/2024-01-06-raspberrypi-headless-bookworm-wifi-config/ 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 19 Share Posted June 19 I purchased a PI4, installed the bookworm version of tipi. Backed up my old tipi, put new tipi in place, restored my backup. Enabled emulation. And all worked perfectly. Great Job Jedi! I'm also rocking the latest tstat. 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 19 Author Share Posted June 19 2 hours ago, dhe said: I purchased a PI4, installed the bookworm version of tipi. Backed up my old tipi, put new tipi in place, restored my backup. Enabled emulation. And all worked perfectly. Great Job Jedi! I'm also rocking the latest tstat. I believe 'RELDATE' in tstat (Geneve) is the value from PI.STATUS, the python side date. This is entirely different from the EPROM build date that is in the ROM. From my eyes, it looks like an equivalent 'COPY PI.STATUS CON:' command ( if that were to work from MDOS, IDK ) 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 19 Share Posted June 19 @jedimatt I already put in a feature request to display the date of the EPROM! Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 19 Share Posted June 19 2 hours ago, jedimatt42 said: I believe 'RELDATE' in tstat (Geneve) is the value from PI.STATUS, the python side date. This is entirely different from the EPROM build date that is in the ROM. From my eyes, it looks like an equivalent 'COPY PI.STATUS CON:' command ( if that were to work from MDOS, IDK ) The info is also available from the MDOS command line via "TYPE PI.STATUS". The program by default doesn't display the status info as its purpose is to compare the version and latest values, alert the user when an update is available, and facilitate an update. Some may recall I had DSR problems a while ago because I wasn't diligently checking the version numbers, hence this program is intended to help users (Geneve) stay current. 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 19 Author Share Posted June 19 Update 4.1 - 2024-06-19 - Fix web-ui 'daemon logs' page to show data from journalctl since last boot, as daemon.log is not used on bookworm - Fix PI.CONFIG ( and TIPICFG indirectly ) to delegate to: raspi-config nonint do_wifi_ssid_passphrase <ssid> <passphrase> 1 - includes 5 retries cause WiFi... and bad antennae. This should solve configuring wifi for most US users. Including those with hidden SSIDs. Your network must be reachable for the settings to persist in the OS NetworkManager. Succeeding, and getting to an assigned ip address can take a bit. This is asynchronous from writing to PI.CONFIG as it is handed off to the service that runs as root. But it should work. It uses a documented feature of raspi-config, so I would expect them to preserve this functionality. I'll produce a new sd image soon, but not today. 4 1 Quote Link to comment Share on other sites More sharing options...
chris36 Posted June 20 Share Posted June 20 Anyone try to use the "standard" Raspberry Pi standoff kit? The screws are metric M2.5, or 2.5 mm diameter. According to my web search, #2 screws are 2.18 mm. So I would need to know if the holes drilled in the TIPI (PEB version from @arcadeshopper) are oversized enough to accommodate the 2.5 mm screws. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 20 Author Share Posted June 20 35 minutes ago, chris36 said: Anyone try to use the "standard" Raspberry Pi standoff kit? The screws are metric M2.5, or 2.5 mm diameter. According to my web search, #2 screws are 2.18 mm. So I would need to know if the holes drilled in the TIPI (PEB version from @arcadeshopper) are oversized enough to accommodate the 2.5 mm screws. holes in the TipiPEB are 3mm diameter 2 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 20 Author Share Posted June 20 7 hours ago, jedimatt42 said: Update 4.1 - 2024-06-19 - Fix web-ui 'daemon logs' page to show data from journalctl since last boot, as daemon.log is not used on bookworm - Fix PI.CONFIG ( and TIPICFG indirectly ) to delegate to: raspi-config nonint do_wifi_ssid_passphrase <ssid> <passphrase> 1 - includes 5 retries cause WiFi... and bad antennae. This should solve configuring wifi for most US users. Including those with hidden SSIDs. Your network must be reachable for the settings to persist in the OS NetworkManager. Succeeding, and getting to an assigned ip address can take a bit. This is asynchronous from writing to PI.CONFIG as it is handed off to the service that runs as root. But it should work. It uses a documented feature of raspi-config, so I would expect them to preserve this functionality. I'll produce a new sd image soon, but not today. Ok, well, it is still Today, so I'm a liar. New 4.1 sdimage has been uploaded to my website for hopefully easier first time wifi setup the way I intended back in the original release. 3 1 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted June 20 Share Posted June 20 24 minutes ago, jedimatt42 said: Ok, well, it is still Today, so I'm a liar. New 4.1 sdimage has been uploaded to my website for hopefully easier first time wifi setup the way I intended back in the original release. did this fix also the issue with having a space in the wifi SSID? Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 20 Author Share Posted June 20 The TIPICFG 4A code seems to be the source of this 'space' problem in the SSID ( found it, line 738 ).. it truncates input after a space... An alternative in TI BASIC that does work looks like: 10 OPEN #1:"PI.CONFIG",OUTPUT 20 PRINT #1:"WIFI_SSID=With spaces" 30 PRINT #1:"WIFI_PSK=goodguys" 40 CLOSE #1 I'll try and fix that soon 2 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 22 Author Share Posted June 22 Update 4.2 -> 2024-06-21 - Fix TIPICFG to allow spaces in SSID and PSK New SD image available as well, since some might need this fix for first use. 3 2 Quote Link to comment Share on other sites More sharing options...
chris36 Posted June 29 Share Posted June 29 (edited) I'm sorry. When I searched for TELNET, there were 69 results. Nice! But I'm afraid I just screwed that up. New PEB TIPI user. Installed per instructions. I can SSH to the Pi. I can view the TIPI web interface. I can CALL TIPI from the 4A and get to settings. But I can't TELNET to localhost, port 23, from the 4A. However, I can TELNET from the 4A to thekeep.net, port 23. 2024-06-29 11:40:25,098 TipiDisk : INFO Opcode 5 LOAD - TIPI.NET.TELNEU 2024-06-29 11:40:25,099 Pab : INFO opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198 2024-06-29 11:40:25,100 TipiDisk : INFO LOAD image size 5120 2024-06-29 11:40:25,966 TipiService : INFO Request completed. 2024-06-29 11:40:37,771 TiSocket : INFO open socket(0) LOCALHOST:23 2024-06-29 11:40:37,773 TiSocket : INFO failed to connect socket: 0 2024-06-29 11:40:37,773 TiSocket : INFO closing socket I'm using the SD image version that was available for Download on 29 June 2024. Edited June 29 by chris36 Version Quote Link to comment Share on other sites More sharing options...
