+x=usr(1536) Posted January 29, 2023 Share Posted January 29, 2023 20 hours ago, kenp said: two 8" floppies Just curious as I obtained a pair of 8" floppy drives recently: what are you using for controllers and power supply? Quote Link to comment Share on other sites More sharing options...
kenp Posted January 29, 2023 Share Posted January 29, 2023 1 hour ago, x=usr(1536) said: Just curious as I obtained a pair of 8" floppy drives recently: what are you using for controllers and power supply? Wow. That must have set you back. Each of my drives is in a cabinet with its own power supply and they have a little patch cable inside that brings the 50 pin card edge connections out to a 50 pin dual-in-line connector on the back of the case. The company that made them was called Thinkertoys and they were originally from my even older IMSAI 8080 S-100 machine. I no longer have that machine. They used to be attached to the Atari through the ATR8000 BUT after turning my basement upside down and inside out I cannot find the cable that I had back then. Gonna have to make up a new one. Been working on that and mapping the connections. Now I need to find somewhere to get a 50 pin flat cable with some dual-in-line connectors, like the 34 pin version for 3.5 Inch drives, and a few more bits to make the actual adapter from 34 pins on the ATR8000 to the 50 pin on the drives. Haven't been in too much of a hurry about it, though after getting the FujiNet. That's been very distracting. 🙂 ( not finding the cable was making me wonder if my memory was wrong about using them on the ATR8000 but the drives are labelled as #3 and #4 for the Atari and C and D for the CP/M system that you can run with the ATR8000 and I do have 8" floppy disks that are labelled as having Atari files on them SOOO I'm going to have to work them back into the chain and see what's on them floppy disks. And now I see notes about running CP/M on or through the FujiNet. That's going to take some looking into as well. It's an amazing device, it seems. ) Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted January 29, 2023 Share Posted January 29, 2023 37 minutes ago, kenp said: Wow. That must have set you back. Knowing what they usually go for, I was extremely fortunate to be in the right place at the right time when they popped up. No idea if they're working or not yet, but I'm hopeful. 37 minutes ago, kenp said: Now I need to find somewhere to get a 50 pin flat cable with some dual-in-line connectors, like the 34 pin version for 3.5 Inch drives, and a few more bits to make the actual adapter from 34 pins on the ATR8000 to the 50 pin on the drives. Yep, the 50-pin card edge connector has been a pain to find at anything approaching a reasonable price. Found the edge connectors not even 10 minutes after I'd typed that. They're on Amazon; a 5-pack is $15. I have looked for cables with the type of connectors you're describing, but with no luck. Either way, with the quantity of connectors available in that pack, adding them to a 50-pin ribbon cable is a realistic proposition. FWIW (and I'll cease the thread hijack after this ), I'm looking at picking up a FDADAP floppy disk adapter and FDDC DC-DC converter for 8" floppy drives from dbit.com to get them up and running. They're late enough manufacture that I'm willing to take the plunge since there's a good chance of being able to resurrect them, but man are those DC-DC converter boards not cheap. Quote Link to comment Share on other sites More sharing options...
kenp Posted January 29, 2023 Share Posted January 29, 2023 18 minutes ago, x=usr(1536) said: Knowing what they usually go for, I was extremely fortunate to be in the right place at the right time when they popped up. No idea if they're working or not yet, but I'm hopeful. Yep, the 50-pin card edge connector has been a pain to find at anything approaching a reasonable price. Found the edge connectors not even 10 minutes after I'd typed that. They're on Amazon; a 5-pack is $15. I have looked for cables with the type of connectors you're describing, but with no luck. Either way, with the quantity of connectors available in that pack, adding them to a 50-pin ribbon cable is a realistic proposition. FWIW (and I'll cease the thread hijack after this ), I'm looking at picking up a FDADAP floppy disk adapter and FDDC DC-DC converter for 8" floppy drives from dbit.com to get them up and running. They're late enough manufacture that I'm willing to take the plunge since there's a good chance of being able to resurrect them, but man are those DC-DC converter boards not cheap. Good luck with those drives and the converters. I'll be crossing my fingers with my drives as well when the time comes. 1 Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) Hi, I have a FujiNet 1.5 (firmware 1.0) that is running perfectly with my unexpanded (except internal 64k) 600XL. When I connect the same FujiNet to my heavily expanded 800XL (sophia2, PokeyMax3, U1MB, VBXE) it isn't recognized at boot up so I have to press SELECT+RESET on my Atari then FujiNet is recognized. No other SIO or cartridge devices attached. Any ideas or do I have to upgrade to FujiNet 1.7 (is it possible via hardware modification to upgrade a FujiNet 1.5 to 1.7 btw)? Edited July 30, 2023 by patjomki Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 30, 2023 Author Share Posted July 30, 2023 Just now, patjomki said: Hi, I have a FujiNet 1.5 (firmware 1.0) that is running perfectly with my unexpanded (except internal 64k) 600XL. When I connect the same FujiNet to my heavily expanded 800XL (sophia2, PokeyMax3, U1MB, VBXE) it isn't recognized at boot up so I have to press SELECT+RESET on my Atari then FujiNet is recognized. No other SIO or cartridge devices attached. Any ideas or do I have to upgrade to FujiNet 1.7 (is it possible via hardware modification to upgrade a FujiNet 1.5 to 1.7 btw)? Loading the FujiNet flasher, and using the debug console, while you boot the 800XL would be most helpful. -Thom Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) 32 minutes ago, tschak909 said: Loading the FujiNet flasher, and using the debug console, while you boot the 800XL would be most helpful. -Thom This is the logfile of the debug console Spoiler [18:14:57] [18:14:57] CF: 0f fc 0f fc 0f [18:14:57] CHECKSUM_ERROR [18:14:58] [18:14:58] CF: 0f fc 0f fc d8 [18:14:58] CHECKSUM_ERROR [18:14:58] Toggling baudrate from 19200 to 67431 [18:14:58] [18:14:58] CF: 02 c8 c8 00 08 [18:14:58] CHECKSUM_ERROR [18:14:58] [18:14:58] CF: 02 c8 c8 00 08 [18:14:58] CHECKSUM_ERROR [18:14:58] Toggling baudrate from 67431 to 19200 [18:14:59] [18:14:59] CF: d8 08 f8 da 08 [18:14:59] CHECKSUM_ERROR [18:14:59] [18:14:59] CF: 31 53 20 00 a4 [18:14:59] FujiNet CONFIG boot [18:14:59] disk sio_process() [18:14:59] ignoring status command [18:14:59] [18:14:59] CF: 31 53 20 00 a4 [18:14:59] FujiNet CONFIG boot [18:14:59] disk sio_process() [18:14:59] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #1 [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #2 [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #3 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #4 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #5 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #6 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #7 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #8 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #9 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #10 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #11 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #12 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #13 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #14 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #15 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #16 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #17 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #18 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #19 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #20 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #21 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #22 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #23 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #24 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #25 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #26 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #27 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #28 And this after I pressed SELECT-RESET: Spoiler [18:17:22] [18:17:22] CF: 0f fc 0f fc 0f [18:17:22] CHECKSUM_ERROR [18:17:22] Toggling baudrate from 19200 to 67431 [18:17:22] [18:17:22] CF: 61 a3 40 00 4c [18:17:22] CHECKSUM_ERROR [18:17:22] [18:17:22] CF: 61 a3 40 00 4c [18:17:22] CHECKSUM_ERROR [18:17:22] Toggling baudrate from 67431 to 19200 [18:17:23] [18:17:23] CF: d8 08 f8 d8 08 [18:17:23] CHECKSUM_ERROR [18:17:23] [18:17:23] CF: d8 08 f8 d8 08 [18:17:23] CHECKSUM_ERROR [18:17:23] Toggling baudrate from 19200 to 67431 [18:17:23] [18:17:24] CF: 02 c8 c8 00 08 [18:17:24] CHECKSUM_ERROR [18:17:24] [18:17:24] CF: 38 c0 f8 c0 38 [18:17:24] CHECKSUM_ERROR [18:17:24] Toggling baudrate from 67431 to 19200 [18:17:24] [18:17:24] CF: 31 53 20 00 a4 [18:17:24] FujiNet CONFIG boot [18:17:24] disk sio_process() [18:17:24] ACK! [18:17:24] disk STATUS [18:17:24] response: 0x00, 0xff, 0xe0 [18:17:24] ->SIO write 4 bytes [18:17:24] COMPLETE! [18:17:24] [18:17:24] CF: 31 3f 20 00 90 [18:17:24] FujiNet CONFIG boot [18:17:24] disk sio_process() [18:17:24] ACK! [18:17:24] sio HSIO INDEX [18:17:24] ->SIO write 1 bytes [18:17:24] COMPLETE! [18:17:24] [18:17:24] CF: 08 fe 08 fe 08 [18:17:24] CHECKSUM_ERROR [18:17:25] [18:17:25] CF: 08 fe 08 fe 08 [18:17:25] CHECKSUM_ERROR [18:17:25] Toggling baudrate from 19200 to 67431 [18:17:25] [18:17:25] CF: 31 53 00 00 84 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] disk STATUS [18:17:25] response: 0x00, 0xff, 0xe0 [18:17:25] ->SIO write 4 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 01 00 84 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 02 00 85 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 03 00 86 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 04 00 87 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 05 00 88 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 06 00 89 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 07 00 8a [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 08 00 8b [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 09 00 8c [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 3f 00 00 70 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] sio HSIO INDEX [18:17:26] ->SIO write 1 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0a 00 8d [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0b 00 8e [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0c 00 8f [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0d 00 90 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0e 00 91 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0f 00 92 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 10 00 93 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 11 00 94 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 12 00 95 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 13 00 96 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 14 00 97 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 15 00 98 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 16 00 99 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 17 00 9a [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 18 00 9b [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 19 00 9c [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1a 00 9d [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1b 00 9e [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1c 00 9f [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1d 00 a0 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1e 00 a1 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1f 00 a2 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 20 00 a3 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 21 00 a4 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 22 00 a5 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 23 00 a6 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 24 00 a7 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 25 00 a8 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 26 00 a9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 27 00 aa [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 28 00 ab [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 29 00 ac [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2a 00 ad [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2b 00 ae [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2c 00 af [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2d 00 b0 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2e 00 b1 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2f 00 b2 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 30 00 b3 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 31 00 b4 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 32 00 b5 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 33 00 b6 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 34 00 b7 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 35 00 b8 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 36 00 b9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 37 00 ba [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 38 00 bb [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 39 00 bc [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3a 00 bd [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3b 00 be [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3c 00 bf [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3d 00 c0 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3e 00 c1 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3f 00 c2 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 40 00 c3 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 41 00 c4 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 42 00 c5 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 43 00 c6 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 44 00 c7 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 45 00 c8 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 46 00 c9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 47 00 ca [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 48 00 cb [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 49 00 cc [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4a 00 cd [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4b 00 ce [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4c 00 cf [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4d 00 d0 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4e 00 d1 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4f 00 d2 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 50 00 d3 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 51 00 d4 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 52 00 d5 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 53 00 d6 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 54 00 d7 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 55 00 d8 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 56 00 d9 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 57 00 da [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 58 00 db [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 59 00 dc [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5a 00 dd [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5b 00 de [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5c 00 df [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5d 00 e0 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5e 00 e1 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5f 00 e2 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 60 00 e3 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 61 00 e4 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 62 00 e5 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 63 00 e6 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 64 00 e7 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 65 00 e8 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 66 00 e9 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 67 00 ea [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:29] CF: 31 52 68 00 eb [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 69 00 ec [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6a 00 ed [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6b 00 ee [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6c 00 ef [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6d 00 f0 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6e 00 f1 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6f 00 f2 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 70 00 f3 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 71 00 f4 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 72 00 f5 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 73 00 f6 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 74 00 f7 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 75 00 f8 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 76 00 f9 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 77 00 fa [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 78 00 fb [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 79 00 fc [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7a 00 fd [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7b 00 fe [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7c 00 ff [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7d 00 01 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7e 00 02 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7f 00 03 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 80 00 04 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 81 00 05 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 82 00 06 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 83 00 07 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 84 00 08 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 85 00 09 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 86 00 0a [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 87 00 0b [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 88 00 0c [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 89 00 0d [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8a 00 0e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8b 00 0f [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8c 00 10 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8d 00 11 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8e 00 12 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8f 00 13 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 90 00 14 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 91 00 15 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 92 00 16 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 93 00 17 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 94 00 18 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 95 00 19 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 96 00 1a [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 97 00 1b [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 98 00 1c [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 99 00 1d [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9a 00 1e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9b 00 1f [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9c 00 20 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9d 00 21 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9e 00 22 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9f 00 23 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a0 00 24 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a1 00 25 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a2 00 26 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a3 00 27 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a4 00 28 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a5 00 29 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a6 00 2a [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a7 00 2b [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a8 00 2c [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a9 00 2d [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 aa 00 2e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ab 00 2f [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ac 00 30 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ad 00 31 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ae 00 32 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 af 00 33 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 b0 00 34 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 00 38 38 00 00 [18:17:31] CHECKSUM_ERROR [18:17:31] [18:17:31] CF: 00 38 38 00 00 [18:17:31] CHECKSUM_ERROR [18:17:31] Toggling baudrate from 67431 to 19200 [18:17:31] [18:17:31] CF: 70 ea 00 00 5b [18:17:31] sioFuji::sio_process() called [18:17:31] ACK! [18:17:31] Fuji cmd: GET WIFI ENABLED: 1 [18:17:31] ->SIO write 1 bytes [18:17:31] COMPLETE! [18:17:32] [18:17:32] CF: 70 fa 00 00 6b [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: GET WIFI STATUS [18:17:32] ->SIO write 1 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f4 00 00 65 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ HOST SLOTS [18:17:32] ->SIO write 256 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f2 00 00 63 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ DEVICE SLOTS [18:17:32] ->SIO write 304 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f4 00 00 65 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ HOST SLOTS [18:17:32] ->SIO write 256 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f2 00 00 63 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ DEVICE SLOTS [18:17:32] ->SIO write 304 bytes [18:17:32] COMPLETE! Edited July 30, 2023 by patjomki Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 30, 2023 Author Share Posted July 30, 2023 2 minutes ago, patjomki said: This is the logfile of the debug console Reveal hidden contents [18:14:57] [18:14:57] CF: 0f fc 0f fc 0f [18:14:57] CHECKSUM_ERROR [18:14:58] [18:14:58] CF: 0f fc 0f fc d8 [18:14:58] CHECKSUM_ERROR [18:14:58] Toggling baudrate from 19200 to 67431 [18:14:58] [18:14:58] CF: 02 c8 c8 00 08 [18:14:58] CHECKSUM_ERROR [18:14:58] [18:14:58] CF: 02 c8 c8 00 08 [18:14:58] CHECKSUM_ERROR [18:14:58] Toggling baudrate from 67431 to 19200 [18:14:59] [18:14:59] CF: d8 08 f8 da 08 [18:14:59] CHECKSUM_ERROR [18:14:59] [18:14:59] CF: 31 53 20 00 a4 [18:14:59] FujiNet CONFIG boot [18:14:59] disk sio_process() [18:14:59] ignoring status command [18:14:59] [18:14:59] CF: 31 53 20 00 a4 [18:14:59] FujiNet CONFIG boot [18:14:59] disk sio_process() [18:14:59] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 31 53 20 00 a4 [18:15:00] FujiNet CONFIG boot [18:15:00] disk sio_process() [18:15:00] ignoring status command [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:00] SIO TYPE3 POLL [18:15:00] Sending TYPE3 poll to dev 50 [18:15:00] modem::sio_process() called [18:15:00] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:00] [18:15:00] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 4f 4f 2e [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL <<RESET POLL>> [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #1 [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #2 [18:15:01] [18:15:01] CF: 4f 40 00 00 8f [18:15:01] SIO TYPE3 POLL [18:15:01] Sending TYPE3 poll to dev 50 [18:15:01] modem::sio_process() called [18:15:01] MODEM TYPE 3 POLL #3 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #4 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #5 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #6 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #7 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #8 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #9 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #10 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #11 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #12 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #13 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #14 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #15 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #16 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #17 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #18 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #19 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #20 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #21 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #22 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #23 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #24 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #25 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #26 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #27 [18:15:02] [18:15:02] CF: 4f 40 00 00 8f [18:15:02] SIO TYPE3 POLL [18:15:02] Sending TYPE3 poll to dev 50 [18:15:02] modem::sio_process() called [18:15:02] MODEM TYPE 3 POLL #28 And this after I pressed SELECT-RESET: Hide contents [18:17:22] [18:17:22] CF: 0f fc 0f fc 0f [18:17:22] CHECKSUM_ERROR [18:17:22] Toggling baudrate from 19200 to 67431 [18:17:22] [18:17:22] CF: 61 a3 40 00 4c [18:17:22] CHECKSUM_ERROR [18:17:22] [18:17:22] CF: 61 a3 40 00 4c [18:17:22] CHECKSUM_ERROR [18:17:22] Toggling baudrate from 67431 to 19200 [18:17:23] [18:17:23] CF: d8 08 f8 d8 08 [18:17:23] CHECKSUM_ERROR [18:17:23] [18:17:23] CF: d8 08 f8 d8 08 [18:17:23] CHECKSUM_ERROR [18:17:23] Toggling baudrate from 19200 to 67431 [18:17:23] [18:17:24] CF: 02 c8 c8 00 08 [18:17:24] CHECKSUM_ERROR [18:17:24] [18:17:24] CF: 38 c0 f8 c0 38 [18:17:24] CHECKSUM_ERROR [18:17:24] Toggling baudrate from 67431 to 19200 [18:17:24] [18:17:24] CF: 31 53 20 00 a4 [18:17:24] FujiNet CONFIG boot [18:17:24] disk sio_process() [18:17:24] ACK! [18:17:24] disk STATUS [18:17:24] response: 0x00, 0xff, 0xe0 [18:17:24] ->SIO write 4 bytes [18:17:24] COMPLETE! [18:17:24] [18:17:24] CF: 31 3f 20 00 90 [18:17:24] FujiNet CONFIG boot [18:17:24] disk sio_process() [18:17:24] ACK! [18:17:24] sio HSIO INDEX [18:17:24] ->SIO write 1 bytes [18:17:24] COMPLETE! [18:17:24] [18:17:24] CF: 08 fe 08 fe 08 [18:17:24] CHECKSUM_ERROR [18:17:25] [18:17:25] CF: 08 fe 08 fe 08 [18:17:25] CHECKSUM_ERROR [18:17:25] Toggling baudrate from 19200 to 67431 [18:17:25] [18:17:25] CF: 31 53 00 00 84 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] disk STATUS [18:17:25] response: 0x00, 0xff, 0xe0 [18:17:25] ->SIO write 4 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 01 00 84 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 02 00 85 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 03 00 86 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 04 00 87 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 05 00 88 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 06 00 89 [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:25] [18:17:25] CF: 31 52 07 00 8a [18:17:25] FujiNet CONFIG boot [18:17:25] disk sio_process() [18:17:25] ACK! [18:17:25] ATR READ [18:17:25] ->SIO write 128 bytes [18:17:25] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 08 00 8b [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 09 00 8c [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 3f 00 00 70 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] sio HSIO INDEX [18:17:26] ->SIO write 1 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0a 00 8d [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0b 00 8e [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0c 00 8f [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0d 00 90 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0e 00 91 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 0f 00 92 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 10 00 93 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 11 00 94 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 12 00 95 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 13 00 96 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 14 00 97 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 15 00 98 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 16 00 99 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 17 00 9a [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 18 00 9b [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 19 00 9c [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1a 00 9d [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1b 00 9e [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1c 00 9f [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1d 00 a0 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1e 00 a1 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 1f 00 a2 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 20 00 a3 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 21 00 a4 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 22 00 a5 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 23 00 a6 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 24 00 a7 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:26] [18:17:26] CF: 31 52 25 00 a8 [18:17:26] FujiNet CONFIG boot [18:17:26] disk sio_process() [18:17:26] ACK! [18:17:26] ATR READ [18:17:26] ->SIO write 128 bytes [18:17:26] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 26 00 a9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 27 00 aa [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 28 00 ab [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 29 00 ac [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2a 00 ad [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2b 00 ae [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2c 00 af [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2d 00 b0 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2e 00 b1 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 2f 00 b2 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 30 00 b3 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 31 00 b4 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 32 00 b5 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 33 00 b6 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 34 00 b7 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 35 00 b8 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 36 00 b9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 37 00 ba [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 38 00 bb [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 39 00 bc [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3a 00 bd [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3b 00 be [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3c 00 bf [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3d 00 c0 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3e 00 c1 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 3f 00 c2 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 40 00 c3 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 41 00 c4 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 42 00 c5 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 43 00 c6 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 44 00 c7 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 45 00 c8 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:27] [18:17:27] CF: 31 52 46 00 c9 [18:17:27] FujiNet CONFIG boot [18:17:27] disk sio_process() [18:17:27] ACK! [18:17:27] ATR READ [18:17:27] ->SIO write 128 bytes [18:17:27] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 47 00 ca [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 48 00 cb [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 49 00 cc [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4a 00 cd [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4b 00 ce [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4c 00 cf [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4d 00 d0 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4e 00 d1 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 4f 00 d2 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 50 00 d3 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 51 00 d4 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 52 00 d5 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 53 00 d6 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 54 00 d7 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 55 00 d8 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 56 00 d9 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 57 00 da [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 58 00 db [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 59 00 dc [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5a 00 dd [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5b 00 de [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5c 00 df [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5d 00 e0 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5e 00 e1 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 5f 00 e2 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 60 00 e3 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 61 00 e4 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 62 00 e5 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 63 00 e6 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 64 00 e7 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 65 00 e8 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 66 00 e9 [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:28] CF: 31 52 67 00 ea [18:17:28] FujiNet CONFIG boot [18:17:28] disk sio_process() [18:17:28] ACK! [18:17:28] ATR READ [18:17:28] ->SIO write 128 bytes [18:17:28] COMPLETE! [18:17:28] [18:17:29] CF: 31 52 68 00 eb [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 69 00 ec [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6a 00 ed [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6b 00 ee [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6c 00 ef [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6d 00 f0 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6e 00 f1 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 6f 00 f2 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 70 00 f3 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 71 00 f4 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 72 00 f5 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 73 00 f6 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 74 00 f7 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 75 00 f8 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 76 00 f9 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 77 00 fa [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 78 00 fb [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 79 00 fc [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7a 00 fd [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7b 00 fe [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7c 00 ff [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7d 00 01 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7e 00 02 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 7f 00 03 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 80 00 04 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 81 00 05 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 82 00 06 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 83 00 07 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 84 00 08 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 85 00 09 [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 86 00 0a [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 87 00 0b [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 88 00 0c [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:29] [18:17:29] CF: 31 52 89 00 0d [18:17:29] FujiNet CONFIG boot [18:17:29] disk sio_process() [18:17:29] ACK! [18:17:29] ATR READ [18:17:29] ->SIO write 128 bytes [18:17:29] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8a 00 0e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8b 00 0f [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8c 00 10 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8d 00 11 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8e 00 12 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 8f 00 13 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 90 00 14 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 91 00 15 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 92 00 16 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 93 00 17 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 94 00 18 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 95 00 19 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 96 00 1a [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 97 00 1b [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 98 00 1c [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 99 00 1d [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9a 00 1e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9b 00 1f [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9c 00 20 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9d 00 21 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9e 00 22 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 9f 00 23 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a0 00 24 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a1 00 25 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a2 00 26 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a3 00 27 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a4 00 28 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a5 00 29 [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a6 00 2a [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a7 00 2b [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a8 00 2c [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 a9 00 2d [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:30] ->SIO write 128 bytes [18:17:30] COMPLETE! [18:17:30] [18:17:30] CF: 31 52 aa 00 2e [18:17:30] FujiNet CONFIG boot [18:17:30] disk sio_process() [18:17:30] ACK! [18:17:30] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ab 00 2f [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ac 00 30 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ad 00 31 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 ae 00 32 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 af 00 33 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 31 52 b0 00 34 [18:17:31] FujiNet CONFIG boot [18:17:31] disk sio_process() [18:17:31] ACK! [18:17:31] ATR READ [18:17:31] ->SIO write 128 bytes [18:17:31] COMPLETE! [18:17:31] [18:17:31] CF: 00 38 38 00 00 [18:17:31] CHECKSUM_ERROR [18:17:31] [18:17:31] CF: 00 38 38 00 00 [18:17:31] CHECKSUM_ERROR [18:17:31] Toggling baudrate from 67431 to 19200 [18:17:31] [18:17:31] CF: 70 ea 00 00 5b [18:17:31] sioFuji::sio_process() called [18:17:31] ACK! [18:17:31] Fuji cmd: GET WIFI ENABLED: 1 [18:17:31] ->SIO write 1 bytes [18:17:31] COMPLETE! [18:17:32] [18:17:32] CF: 70 fa 00 00 6b [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: GET WIFI STATUS [18:17:32] ->SIO write 1 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f4 00 00 65 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ HOST SLOTS [18:17:32] ->SIO write 256 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f2 00 00 63 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ DEVICE SLOTS [18:17:32] ->SIO write 304 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f4 00 00 65 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ HOST SLOTS [18:17:32] ->SIO write 256 bytes [18:17:32] COMPLETE! [18:17:32] [18:17:32] CF: 70 f2 00 00 63 [18:17:32] sioFuji::sio_process() called [18:17:32] ACK! [18:17:32] Fuji cmd: READ DEVICE SLOTS [18:17:32] ->SIO write 304 bytes [18:17:32] COMPLETE! That looks like a pretty normal boot, to me. -Thom Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) 4 minutes ago, tschak909 said: That looks like a pretty normal boot, to me. -Thom Both? Of course after SELECT-RESET it normally boots (second part of my message in spoiler tags) but not when I start my ATARI (first part of my message in spoiler tags). You then hear the typical sound when the atari is searching for a sio device and in the end it starts either basic or self test (depends on what I configured in U1MB) Edited July 30, 2023 by patjomki Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 Ah, just found out that FujiNet boots without any error when I disable pbi bios in U1MB. Well that is a conflict as I am also using an AVG Cart and pbi bios is very very useful then. Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) Do you think there will be a solution that FujiNet and pbi bios of U1MB can work together? @flashjazzcat perhaps? Edited July 30, 2023 by patjomki Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 30, 2023 Author Share Posted July 30, 2023 Just now, patjomki said: Do you think there will be a solution that FujiNet and pbi bios of U1MB can work together? @flashjazzcat perhaps? I use a FujiNet with U1MB's PBI bios all the time (high speed SIO works great). I only turn it off when loading ATX titles. -Thom Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) @tschak909 Which settings do you use? My settings are: PBI BIOS: Enabled PBI device ID: 6 PBI notice: Enabled Hard disk: Disabled With these settings FujiNet is not found at boot only after SELECT+RESET. Edited July 30, 2023 by patjomki Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 30, 2023 Share Posted July 30, 2023 (edited) Problem solved. I don't know why but I had HSIO+SIO2BT configured in SIO and CIO Drivers in U1MB. Now that I changed it (back) to HSIO only everything works as expected. Edited July 30, 2023 by patjomki 1 Quote Link to comment Share on other sites More sharing options...
sideburn Posted December 30, 2023 Share Posted December 30, 2023 Has anyone else noticed that the Fujinet won’t boot if there’s an SDrive Max on the SIO bus if it is turned off? I have to power up the SDrive Max and the. Set D1: to “empty” for the Fujinet to boot up. If the SDrive Max is powered down then Fujinet freezes. My physical 1050 can remain on the SIO bus powered down without issue. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 30, 2023 Author Share Posted December 30, 2023 1 minute ago, sideburn said: Has anyone else noticed that the Fujinet won’t boot if there’s an SDrive Max on the SIO bus if it is turned off? I have to power up the SDrive Max and the. Set D1: to “empty” for the Fujinet to boot up. If the SDrive Max is powered down then Fujinet freezes. My physical 1050 can remain on the SIO bus powered down without issue. Why are you putting an SDrive Max on the same bus as a FujiNet? There's absolutely zero reason to do that. -Thom Quote Link to comment Share on other sites More sharing options...
sideburn Posted December 30, 2023 Share Posted December 30, 2023 4 minutes ago, tschak909 said: Why are you putting an SDrive Max on the same bus as a FujiNet? There's absolutely zero reason to do that. -Thom Because I use it. As well as my 1050 drive. I have the cable going from the 130xe to an SIO hub and the SDrive Max, 1050, and Fujinet are all plugged into the chain. Seems normal to me. Why would I NOT have my SDrive Max connected to my computer? I just got the Fujinet. Are you saying I should ditch the SDrive Max and don’t use it anymore? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 30, 2023 Author Share Posted December 30, 2023 6 minutes ago, sideburn said: Because I use it. As well as my 1050 drive. I have the cable going from the 130xe to an SIO hub and the SDrive Max, 1050, and Fujinet are all plugged into the chain. Seems normal to me. Why would I NOT have my SDrive Max connected to my computer? I just got the Fujinet. Are you saying I should ditch the SDrive Max and don’t use it anymore? The FujiNet completely subsumes the functions of the SDrive-Max. -Thom Quote Link to comment Share on other sites More sharing options...
sideburn Posted December 30, 2023 Share Posted December 30, 2023 Unless you want to power on and boot straight into something (on any drive ID). In that case Fujinet lags in comparison. The fact that you have to first boot into Fujinet, then navigate to destination disk image and move it to D1: slot and hold down option to boot it is a process. Sdrive max can have 4 disk images on 4 drive IDs and boot straight into them on power up. Also some things just don’t work on Fujinet (like Copymate XE) because they think there’s a cart still installed even when holding down option on boot. They both have their own advantages in my opinion. But Fujinet is the winner if it were a contest. 1 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 30, 2023 Author Share Posted December 30, 2023 2 minutes ago, sideburn said: Unless you want to power on and boot straight into something (on any drive ID). In that case Fujinet lags in comparison. The fact that you have to first boot into Fujinet, then navigate to destination disk image and move it to D1: slot and hold down option to boot it is a process. Sdrive max can have 4 disk images on 4 drive IDs and boot straight into them on power up. Also some things just don’t work on Fujinet (like Copymate XE) because they think there’s a cart still installed even when holding down option on boot. They both have their own advantages in my opinion. But Fujinet is the winner if it were a contest. You can set mount-and-boot in the web UI to bypass CONFIG: http://fujinet/ -Thom Quote Link to comment Share on other sites More sharing options...
sideburn Posted December 30, 2023 Share Posted December 30, 2023 (edited) 11 minutes ago, tschak909 said: You can set mount-and-boot in the web UI to bypass CONFIG: http://fujinet/ -Thom still more hassle. Also I’m not sure if will work with cartridges like Mac/65 for coding and you need the floppy drive to load and save your work. Maybe it’s possible, I’m still a Fujinet N00b. I’ve got my own local server and got printing working and terminal programs going but that’s about it. Anyway. Regardless. Seems like a bug that it’s unhappy having a device (in this case the sdrive max) in the SIO chain and powered off. Edited December 30, 2023 by sideburn 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted December 30, 2023 Share Posted December 30, 2023 15 minutes ago, tschak909 said: The FujiNet completely subsumes the functions of the SDrive-Max. subsumes: to include something or someone as part of a larger group 1 minute ago, sideburn said: Unless you want to power on and boot straight into something (on any drive ID). In that case Fujinet lags in comparison. The fact that you have to first boot into Fujinet, then navigate to destination disk image and move it to D1: slot and hold down option to boot it is a process. My feeling and experience as well. Personally I see each one having its own unique strengths and weaknesses. So much so that I'm developing a dual version daughter board for the 576NUC+ that allows for a FujiNet plug-in that shares the singular SD Card slot in an independent manner since they don't work as cooperatively as I'd like to see. I presently have a working production version that makes the best of both aspects. When set to SDrive mode, that's all it does, and when set to FujiNet mode SDrive is kicked to the curb and FujiNet takes over the driver's seat. 8 minutes ago, sideburn said: They both have their own advantages in my opinion. But Fujinet is the winner if it were a contest. I totally agree. FujiNet brings so much to the table, and I absolutely love the virtual printer to pdf. Also the WiFi remote capabilities are truly remarkable, as well as extremely useful 👍 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 30, 2023 Author Share Posted December 30, 2023 2 minutes ago, sideburn said: still more hassle. Also I’m sure sure if will work with cartridges like Mac/65 for coding and you need the floppy drive to load and save your work. Maybe it’s possible, I’m still a Fujinet N00b. I’ve got my own local server and got printing working and terminal programs going but that’s about it. Anyway. Regardless. Seems like a bug that it’s unhappy having a device (in this case the sdrive max) in the SIO chain and powered off. I regularly use FujiNet for development. I do not need a floppy drive. I either create a new disk image in config, or, I use the N: device to save to a server directly (there are several filesystem protocols that N: supports) Here is a video showing the N: device, in perspective. -Thom Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 30, 2023 Share Posted December 30, 2023 16 minutes ago, sideburn said: Unless you want to power on and boot straight into something (on any drive ID). In that case Fujinet lags in comparison. The fact that you have to first boot into Fujinet, then navigate to destination disk image and move it to D1: slot and hold down option to boot it is a process. Exactly, 100% agreed. You don't need to boot anything to select your image(s) but just tap on the screen. This is infinitely faster, particularly if you change images quite often. 4 minutes ago, mytek said: My feeling and experience as well. Personally I see each one having its own unique strengths and weaknesses. [...] When set to SDrive mode, that's all it does, and when set to FujiNet mode SDrive is kicked to the curb and FujiNet takes over the driver's seat. Nope, 100% disagreed. The SDrive (non-MAX) also needs something booted before you can select images. Thsi is exact the same as with a FujiNet. Quote Link to comment Share on other sites More sharing options...
+mytek Posted December 30, 2023 Share Posted December 30, 2023 2 minutes ago, DjayBee said: 8 minutes ago, mytek said: My feeling and experience as well. Personally I see each one having its own unique strengths and weaknesses. [...] When set to SDrive mode, that's all it does, and when set to FujiNet mode SDrive is kicked to the curb and FujiNet takes over the driver's seat. Nope, 100% disagreed. The SDrive (non-MAX) also needs something booted before you can select images. Thsi is exact the same as with a FujiNet. Well to be fair if I pulled out a stop watch and timed both systems (SDrive and FujiNet) from power-up to application/game launch the SDrive would easily win with time to spare. Bottom line there are just more steps you need to go through with Fujinet, albeit they are there for a reason to make the system more powerful and versatile, but for launching a game from the SD card those extra steps get in the way. Of course for an even faster experience a multi-cart like the AVG, SIDE3, UNO, ect. will wipe the floor and leave the SIO derivatives eating dirt when it comes to launching games and applications. Bottom line there's room in Atari land for everything, and this isn't about which product is superior, but more about which one does what you want in the way that you want. And I think the OP was looking for a way to have his SDrive-Max exist in a more cooperative manner with FujiNet. He also acknowledged the superiority of the FujiNet, but this wasn't the issue. 2 Quote Link to comment Share on other sites More sharing options...
