tschak909 Posted November 3, 2021 Author Share Posted November 3, 2021 and by setting MIO/BB, I literally mean doing that in SYSEDIT. -Thom Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 3, 2021 Share Posted November 3, 2021 (edited) except I did, using an ATR8000 as the serial port and the the drives... for years and years, the ATR8000 handled four QUADS and the modem... if the waitcalls are fubar now... then it's the result of later changes... perhaps the waitcalls need to be fixed/rolled back to a time before everyone running a board had hard drives... early on very few Express BBS! and PRO! boards had hard drives let alone a black box or mio... Edited November 3, 2021 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 3, 2021 Author Share Posted November 3, 2021 ATR8000's concurrent mode behavior in the handler is completely different than the 850. -Thom 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 I can see a few bytes before ATA (Ctrl-M) and some after. My initial thought was edit waitcall w/ a hex editor and move ATA (Ctrl-M) three bytes ahead. But: Those 3 bytes look like they could easily be code. It would likely crash if attempted. I may try, but I expect failure. This thing is supposed to emulate 850 / Hayes 100%, right? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 3, 2021 Author Share Posted November 3, 2021 yes, am guessing that the connect message from the modem is happening too fast. This was fixed in firmware many months ago. -Thom Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 SYSEDIT just set interface type to 850. Try it now. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 3, 2021 Share Posted November 3, 2021 (edited) Maybe it would be good for fujinet to emulate the ATR8000 handler then... better serial and SIO just have to up the drive speeds in the atr8000 firmware. and perhaps the waitcall/pro issues could of course use some work as well. Still wondering how so many BBS Express! and PRO! boards had nothing but a memory upgrade, an 850, modem, and a stack of 1050's/percoms. Edited November 3, 2021 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 I am using the FN that I received in October, with the antenna (which is a wonderful improvement). Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 (edited) 2 minutes ago, _The Doctor__ said: Maybe it would be good for fujinet to emulate the ATR8000 handler then... better serial and SIO just have to up the drive speeds in the atr8000 firmware. YES! I have been harping on this for years. We have GT-Sync on Indus bit-banging using a 4Mhz. Z80. ATR-8000 has the same wonderful CPU. This should be an EASY transplant. We even have US Doubler ROM for the Indus GT. That would be perfect in the ATR-8000 ROM. [Sorry, O/T]. Edited November 3, 2021 by Kyle22 grammar / sp Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 I'll take it downstairs tomorrow to the Win 10 (spy) machine and update the firmware in case I don't have the latest. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 3, 2021 Share Posted November 3, 2021 kyle you're using PBI hard drives anyway on the incognito correct? so no fujinet drives or real sio 1050's etc... correct? Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 (edited) Yes. Correct. There is a PCL: cable attached which should'nt hurt, but I unplugged it now. Edited November 3, 2021 by Kyle22 punctuation. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Try it again. It is 800 + FN. Nothing else plugged in SIO. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 It tried, but no connection. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Do you think the WTCALL96 would be worth a try (again)? I'm gonna do it now. Connect in 5 mins. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Done. FN & 800 rebooted @ same time. FN Reset pressed, then Fuji + System Reset -> BIOS then B for Boot. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Try again. I plugged the PCL: cable in again, but it was disconnected before I just saw this call right now. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 It's disconnected now. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Looking for a carrier 9600 Press Return then Dis-conn. on my end. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 3, 2021 Author Share Posted November 3, 2021 You should load the flasher so that you can get a debug console. You can also do so by attaching a terminal program to the com port exposed by the Fujinet's CP2102 UART. Baud rate is 921600 -Thom You can also get to it via installing platformio and running pio run monitor Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 I have the entire waitcall ZIP that tschak kindly posted mounted as PCLD: in SDX, so it it is quick and easy to try a new one that may work with FujiNet. I am open to suggestions. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 (edited) Just installed waitcal0. Does anyone have detailed docs on this? Other than [Carden] ? Edit: Trying different ones again to see if anything works. Should I go go back to the default one and see if there is a firmware update? Edited November 3, 2021 by Kyle22 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 3, 2021 Share Posted November 3, 2021 Default WAITCALL installed again. Will check Firmware tomorrow. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted November 3, 2021 Share Posted November 3, 2021 (edited) 3 hours ago, Kyle22 said: I must do that downstairs at my store. I don't have a Win 10 machine upstairs. I use XP because M$ can't $py on me here. M$ = EVIL. [GATES] of hell Disgusting. Why do you always have to hijack other people's threads instead of opening your own? ? Also I do not understand why you are not banned with all your paranoid tinfoil shit. Edited November 3, 2021 by DjayBee added quote 2 Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted November 3, 2021 Share Posted November 3, 2021 10 hours ago, _The Doctor__ said: ...early on very few Express BBS! and PRO! boards had hard drives let alone a black box or mio... I did 2 Quote Link to comment Share on other sites More sharing options...
