+DjayBee Posted August 2, 2023 Share Posted August 2, 2023 (edited) duplicate post Edited August 2, 2023 by DjayBee Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 3, 2023 Author Share Posted August 3, 2023 19 hours ago, DjayBee said: Do you have a DD capable drive and did you try to boot side B there? ATX currently does not support DD disks. I have not tried to convert a DD flux image but not detecting anything on a DD flux dump would be a valid option in this case. Can you please redo this disk in INDEX mode? For a diagnostic disk this might be worth the effort. Oh, and I see no need for BASIC with this title. IT DOES BOOT! WooHoo! I will get a new copy as soon as I can. Will ATX ever support DD, ED? 17 hours ago, DjayBee said: This disk misses the needed copy protection which should be a bad sector. If you select a printer, a copyright screen shows up and the system reboots.Forms Generator (1986)(Twenty-Fifth Century)(US)[disk][f].atx Weird-o-Fact: This is the second dump of this program and the third from this company which shows this error. Can you please try if this disk works on hardware? I really don't want to believe that several non-working disks were sold. It does boot on real Hardware. I will get a new copy as soon as I can. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 3, 2023 Author Share Posted August 3, 2023 Gettysburg The Turning Point v1.0 (1985)(SSI)(US)[disk] has been updated with @DjayBee's Fix. Maxi Golf (1984)(Adventure International)(US)[disk] has been updated with @DjayBee's Fix. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 3, 2023 Author Share Posted August 3, 2023 Previously posted here. BackTalk 1.2 (1986)(Antic Software)(US)[disk] I recorded it 3 times. each times the bad sectors are the same. The -p option does nothing. Did Antic use copy protection? Repaired by @DjayBee. BackTalk 1.2 (1986)(Antic Software)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 3, 2023 Share Posted August 3, 2023 1 minute ago, SoulBuster said: IT DOES BOOT! WooHoo! I will get a new copy as soon as I can. Will ATX ever support DD, ED? Yeah, this is what I had expected. ATX will support DD. ijor and phaeron are currently discussing details of its implementation. 1 hour ago, SoulBuster said: It does boot on real Hardware. I will get a new copy as soon as I can. Since we already have two other dumps with the same problem, I do not expect a fresh dump to be much different. Can you please run the attached image against your physical floppy and return the resulting image to me? It will extract all sectors from track 4 plus each of sectors 84 and 85 two additional times. Take care not to accidentally overwrite your original disk. Dos25Extract 25th.atr Example run assuming you booted the ATR from D1 and put the physical Forms Generator disk in D2: (The program will also work with only one drive. It then asks to switch disks.) 1 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 3, 2023 Author Share Posted August 3, 2023 That was interesting. I used Ape and the Black Box to move drives around without changing IDs on the units themselves. Dumped Sectors.atr 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 3, 2023 Share Posted August 3, 2023 On 5/23/2023 at 6:05 PM, SoulBuster said: Jupiter Mission 1999 (1983)(Microcomputer Games)(US)[disk] Boot with BASIC. I spent a couple hours on this one. It looks like someone opened a can of coke over the disks. I had to clean the disks, the drive and re-record several times. I finally did get clean copies. Mostly clean: Three neded and several unneeded sectors close to the end are missing. Repaired using sectors from set #2: Jupiter Mission 1999 Disk 1[f].atx On 1/29/2023 at 5:16 PM, SoulBuster said: Learn About Words in Reading 2 Grades 2-4 I am not sure what is going on here. It boots to Black Rabbit 1.5, but the files look like it might be the right stuff. AUTORUN.SYS overwritten? Not only AUTORUN.SYS was overwritten but the first half of the disk. Thus I cannot repair the disk. Black Rabbit seems to be a sector copier from ANALOG. 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 4, 2023 Share Posted August 4, 2023 15 hours ago, SoulBuster said: That was interesting. I used Ape and the Black Box to move drives around without changing IDs on the units themselves. Phaeron and ijor ask what drive you used to dump these sectors because it seemingly cannot have been a 1050. I guess that I should have given more attention to your mentioning of the Black Box. Best answer directly to that posting. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 4, 2023 Author Share Posted August 4, 2023 Originally posted here. This set includes a fix by @DjayBee Jupiter Mission 1999 (1983)(Microcomputer Games)(US)[disk] Boot with BASIC. I spent a couple hours on this one. It looks like someone opened a can of coke over the disks. I had to clean the disks, the drive and re-record several times. I finally did get clean copies. Jupiter Mission 1999 (1983)(Microcomputer Games)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 4, 2023 Author Share Posted August 4, 2023 20 hours ago, DjayBee said: Not only AUTORUN.SYS was overwritten but the first half of the disk. Thus I cannot repair the disk. Black Rabbit seems to be a sector copier from ANALOG. I figured as much on that disk. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 4, 2023 Share Posted August 4, 2023 On 3/5/2023 at 10:47 PM, SoulBuster said: Word Attack! (1983-1989)(Davidson)(US)[disk] Set #2 Includes untested C64 files Box is different so I am posting all contents. Disk 2 misses sector 28 which is needed right after the shooting splash screen. Fixed with data from the other set: Word Attack! (1983-1989)(Davidson)(US)(Side 2, Program)[disk][f].atx And btw. this whole release is different, not only the packaging. Inside a file it carries a release date of 03-27-87. 2 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 11, 2023 Author Share Posted August 11, 2023 Word Attack! (1983-1989)(Davidson)(US)[disk] Set #2 Includes untested C64 files (Originally posted here, This set includes @DjayBee's fix above) Box is different so I am posting all contents. Word Attack! (1983-1989)(Davidson)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Just had to mention new equipment: a QNAP TVS-h874 NAS (Specs). The top one in the picture. I installed: 2 Sabrent 8TB m.2 SSDs that are mirrored. (7000 mbs) 8 22 TB Seagate Exos Hard drives on a Raid 6. 2nd NAS in the pic is the old NAS and will be used as a synchronized backup to the first on a Raid 6. All this on a 2.5 gig LAN. TOP NAS has 2 2.5 gig network ports trunked together. Bottom one has 4 1 gig network ports trunked together. This gives the top one a 5 gig network connection and the bottom a 4 gig network connection. The PC I built has a 2.5 gig network port in it. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 The condition of the following Analog disks are the worst I have seen yet. They all had water spots on the surface along with something crusty that alcohol would not take off. In some cases, I used a plastic "scraper" to help remove the crust and bathed them in alcohol to remove the grime. In all cases, this helped, but just was not enough for all disks. I was lucky to get what I got. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 17, 2023 Share Posted August 17, 2023 That's space for maaany flux dumps. 🤣 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #38 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A -p 101 for a clean disk, Side B -p 103 still has 2 bad sectors. Analog Computing #38 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #39 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A -p 102 for a clean disk, Side B is clean. Analog Computing #39 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #40 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A -p 108 for a clean disk, Side B -p 103 for a clean disk. Analog Computing #40 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #41 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A 10 recordings, no clean disk, Side B is a clean disk. Analog Computing #41 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #42 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A 10 recordings, no clean disk, Side B 10 recordings, no clean disk. Analog Computing #42 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #43 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A -p 103 for a clean disk, Side B -p 110, but still has a bad sector in a blank area. Analog Computing #43 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #44 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A 10 recordings, no clean disk, No Side B. Analog Computing #44 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #45 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A -p 102 for a clean disk, Side B -p 103 for a clean disk. Analog Computing #45 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17, 2023 Author Share Posted August 17, 2023 Analog Computing #46 (1986)(Analog Magazine)(US)[disk] Boot with BASIC. Side A 10 recordings, no clean disk, Side B 10 Recordings, No clean disk. Analog Computing #46 (1986)(Analog Magazine)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
