+SoulBuster Posted August 20, 2023 Author Share Posted August 20, 2023 On 8/19/2023 at 2:29 AM, DjayBee said: IMHO has this disk hardware-damage for protection. Can you please check the bottom side for any visual "things" and make a photo if you find something? I wouldn't expect it as intrusive as the first picture in this post but maybe like the second one. Perhaps some of the readers here know how to use the tool and could test in Altirra if the ATX works (which I do not expect): The Black Patch Master.scp.atx(must NOT be write-protected) And then please test if my quick and dirty crack works: Black Patch!, The v1.1 (1987)(Computer Software Services)(US)(Master Disk)[cr CSS].atr (must be write-protected) I tested on the Official Frogger from the A8SP zip. I took the ATX and used copy mate to make an ATR. Booted the ATR to make sure some anomaly was not interfering to show a good disk. The disk failed to load, as expected. Booted up the first version you posted and it does not complete the patch. Booted the ATR, it does not boot. Booted the second version and the ATR patched frogger like normal. The Frogger ATR works. Original used: Frogger (The Official) v1.0 (1981)(SierraVision)(US)[!].atx Patched version: Frogger (The Official) v1.0 (1981)(SierraVision)(US)[!].atr 4 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 20, 2023 Share Posted August 20, 2023 I thought the Black Patch had a 1987 version and a 1989 version, the latter having updates and more titles. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted August 20, 2023 Share Posted August 20, 2023 46 minutes ago, _The Doctor__ said: I thought the Black Patch had a 1987 version and a 1989 version, the latter having updates and more titles. Exactly. Soulbuster's version is 1.1 and has 1989 on the program disks label. There is also a v1.0 which then must be from 1987. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 21, 2023 Author Share Posted August 21, 2023 During the recent recording of Analog disks (which were horribly bad), I updated the batch file that I use to include running the -p option through 110. I will post it here in case someone else can use it. scp.bat.zip 1 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 7, 2023 Share Posted September 7, 2023 On 3/7/2023 at 10:07 PM, SoulBuster said: SoftSide Issue #34 (1982)(SoftSide Publications)(US)[disk] - No Dos, Boot Atari Dos 2.5 first, RUN"D:COVER" Side "B" appears to be overwritten. Write protect your disk if you are going to test it. Dunno what happened there because the dump is OK. Side B contains the Rotberg Synthesizer demo and its reaction to failed copy protection is to format the disk. Therefore the protection must have failed in your emulator. 1 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted September 8, 2023 Author Share Posted September 8, 2023 Converter, The & Companion v1.51 (1988)(No Frills Software)(US) Converter, The & Companion v1.51 (1988)(No Frills Software)(US).zip 4 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 8, 2023 Share Posted September 8, 2023 THE Converter & COMPANION, plays on capitalization. Quote Link to comment Share on other sites More sharing options...
FULS Posted October 5, 2023 Share Posted October 5, 2023 (edited) On 8/20/2023 at 10:06 AM, SoulBuster said: Solo Flight 2nd Edition (1985)(Microprose)(GB)[cassette] Autoload without BASIC. Solo Flight 2nd Edition (1985)(Microprose)(GB)[cassette].zip 198.01 MB · 8 downloads Solo Flight 2nd Edition Inlay.pdf 648 kB · 4 downloads Solo Flight 2nd Edition Catalog.pdf 9.5 MB · 4 downloads Your zip file contains the file "Solo Flight 2nd Edition Side 2 (C64 untested).wav". This is not a C64 file but is actually Side B that is needed by the main program after typing in the Security Code to run the program. Should this be converted into a cas file? Thank you for dumping this. I could not find a dump of Side B anywhere before this. Edited October 5, 2023 by FULS 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted November 10, 2023 Author Share Posted November 10, 2023 Musical Computer (1981)(APX)(US)[BASIC] Set #2 Boot with BASIC. RUN"D:"MUSCOM1" OR RUN"D:MUSCOM2" Musical Computer (1981)(APX)(US)[BASIC].zip Musical Computer Manual.pdf 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted November 14, 2023 Author Share Posted November 14, 2023 Invasion Orion (1981)(Epyx)(US)[cassette] Includes untested TRS-80 WAV file. CLOAD, then RUN. Then RUN again after second part loads. You are asked what scenario to run. There are two PILGRIMAGE CHALLENGE Challenge does not load properly. If you do not type PILGRIMAGE, it will always try load CHALLENGE and fail. To play the game, type PILGRIMAGE for a good load. I tried several recordings and they all end up with the same error. I have included only the cleanest of them. Invasion Orion (1981)(Epyx)(US)[cassette].zip Invasion Orion Manual.pdf Invasion Orion Loading Instructions.pdf Invasion Orion How to Build Scenarios.pdf Invasion Orion New Two Player Option.pdf Invasion Orion Have You Serviced Your Heads Lately.pdf Invasion Orion Catalog.pdf 5 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 26, 2023 Share Posted December 26, 2023 On 7/9/2021 at 2:04 AM, SoulBuster said: HDPro Backup! HDPro Backup!.zip 4.94 MB · 94 downloads Can you please try a redump? This is v1.0. I tried to fix it and believed to have been successful but restoring a backup does not work correctly. 1 Quote Link to comment Share on other sites More sharing options...
BillC Posted December 26, 2023 Share Posted December 26, 2023 2 hours ago, DjayBee said: Can you please try a redump? This is v1.0. I tried to fix it and believed to have been successful but restoring a backup does not work correctly. SideB may also contain a duplicate of sideA, the v1.5 disk I have does. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted December 27, 2023 Author Share Posted December 27, 2023 If there was a side B in the package, that is a mistake. I just checked side B of the disk on Real Hardware and nothing is there, unformatted. Here is a new recording. HDPro Backup!.zip The bad sectors remained constant even when trying -p options. 2 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 29, 2023 Share Posted December 29, 2023 On 12/27/2023 at 7:48 PM, SoulBuster said: The bad sectors remained constant even when trying -p options. Yes but the contents differ and the new dump gave me the last missing byte. Now the restore of a 360K disk worked. Hard Disk Backup Pro!, The v1.0 (1990)(Computer Software Services)(US)[f].atx 3 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Awardware - New Graphics Disk (1988-11)(Hi-Tech Expressions)(US)[disk] Source: Allan Recording: SoulBuster Data disk, does not boot. Awardware - New Graphics Disk (1988-11)(Hi-Tech Expressions)(US)[disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Games Pak V (198x)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. Games Pak V (198x)(Dynacomp)(US)[BASIC][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Games Pack VI (198x)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. Games Pack VI (198x)(Dynacomp)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Probability Through Problem Solving (198x)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. Probability Through Problem Solving (198x)(Dynacomp)(US)[BASIC][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Microteach Accounting (-)(Dynacomp)(US)[No Boot][disk] Source: Allan Recording: SoulBuster It is apparently a Data Disk. It does not Boot. Microteach Accounting (-)(Dynacomp)(US)[No Boot][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Games Pack III (198x)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. Games Pack III (198x)(Dynacomp)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 Fourier Analyzer (1981)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. Fourier Analyzer (1981)(Dynacomp)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 AtariOracle (1984)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. AtariOracle (1984)(Dynacomp)(US)[BASIC][disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1 Author Share Posted February 1 International Vocabulary Manager (198x)(Dynacomp)(US)[BASIC][disk] Source: Allan Recording: SoulBuster Boot with BASIC. International Vocabulary Manager (198x)(Dynacomp)(US)[BASIC][disk].zip 4 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted February 1 Share Posted February 1 Holy crap, Dynacomp mania! Many thanks to both of you! 1 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted February 1 Share Posted February 1 3 hours ago, SoulBuster said: Probability Through Problem Solving (198x)(Dynacomp)(US)[BASIC][disk] Is this the only disk? Quote Link to comment Share on other sites More sharing options...
