Roydea6 Posted May 22, 2012 Share Posted May 22, 2012 Yes!!! There is a Z: configuration the Bios. I haven't been using the IDE +2.0 very often and completely missed this option as the cause... Thank You... Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 24, 2012 Share Posted May 24, 2012 SDXCLOCK.ATR Is a turbo basic compiled program that displays an analogue clock with a sweeping second hand. Also displayed is a date and seconds count. Runs with SDX445.rom in emulator or SIDE cartridge and IDE 2.0 PBI device. SDXCLOCK.ATR Mostly to test my rtime8 cartridge, incognito Atari800, and SIDE cartridge. Quote Link to comment Share on other sites More sharing options...
St(r)yker Posted September 6, 2012 Share Posted September 6, 2012 Ide Plus bios 1.0 beta http://drac030.krap.pl/ideplus-bios-20120708.arc http://drac030.krap.pl/ideplus-utilities-disk-2012-09-06.tar.gz Quote Link to comment Share on other sites More sharing options...
spookt Posted September 6, 2012 Share Posted September 6, 2012 Any info on what's new? Quote Link to comment Share on other sites More sharing options...
drac030 Posted September 6, 2012 Author Share Posted September 6, 2012 This is not a complete an perfect update, but since I have virtually no time for coding and I can't say for now, when I'll be able to code anything bigger again, I've decided (under some pressure from Stryker) to share what I have now. The new things are: 1) APT support: the BIOS should be able to recognize APT-partitioned media (like under SIDE). There is a program called IDEA2APT.COM in the archive, which converts the old partition table format to the new one. Before doing that, please backup your partition table (in sector 0) in some safe place, e.g. use Eddy in the "device edit" mode just copy the first sector of the disk to the very last one. The conversion does not establish a PC MBR there, to have that, you'll have to repartition the disk. ALSO: the FDISK2 included does NOT know APT format, sorry, I had no time to code new FDISK, but you may try using the SIDE FDISK made by FJC. It should - in theory - work, because SIDE and IDE Plus share common API, which allows the partition table area access. 2) support for Karin Maxi disk drive: you may selectively disable US SIO patch for drives 1-4. This allows to access parallel floppies, which otherwise (when US SIO is on) get masked out by the IDE Plus SIO. 3) support for other parallel devices in the loader: the loader should now be able to access not only SIO devices and IDE Plus drives, but also the media attached via other PBI devices (such as the Karin drive above). 4) minor bugfixes. The thing which is not there is the mounting support in the API. No time to code this, sorry. :/ Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 6, 2012 Share Posted September 6, 2012 ...the FDISK2 included does NOT know APT format, sorry, I had no time to code new FDISK, but you may try using the SIDE FDISK made by FJC. It should - in theory - work, because SIDE and IDE Plus share common API, which allows the partition table area access. For the price of a simple email, the APT FDISK could have been included on the support disk, saving users the trouble of going looking for the right version. Does your valuable time really need to be spent reinventing the wheel yet again? Or is there some inherent problem in endorsing the available software which I don't quite grasp? In addition, I've been testing various builds of FDISK with the beta APT BIOS for some nine months now... so there's no need to theorise as to whether it works or not. Quote Link to comment Share on other sites More sharing options...
candle Posted September 6, 2012 Share Posted September 6, 2012 Jon, don't start he really HAS NO TIME Quote Link to comment Share on other sites More sharing options...
drac030 Posted September 6, 2012 Author Share Posted September 6, 2012 fjc: sorry, I did not intend to question the quality of your FDISK. I simply forgot that you had the earlier beta and an opportunity to test it thoraoughly. "In theory" means that I didn't test it myself, so take it as a sort of assecuration, not a statement. Quote Link to comment Share on other sites More sharing options...
+Larry Posted September 9, 2012 Share Posted September 9, 2012 "assecuration" Now there's a word you don't see every day. Had to look that one up. -Larry fjc: sorry, I did not intend to question the quality of your FDISK. I simply forgot that you had the earlier beta and an opportunity to test it thoraoughly. "In theory" means that I didn't test it myself, so take it as a sort of assecuration, not a statement. Quote Link to comment Share on other sites More sharing options...
drac030 Posted September 10, 2012 Author Share Posted September 10, 2012 Ehm, sorry for that mistake. My English sometimes fails more than usually, especially when I am distracted. What I meant was that the words "in theory", being in fact superfluous there, were intended as some sort of precaution, just in case it turns out that in practice there's a problem I have no possibility to fix. Quote Link to comment Share on other sites More sharing options...
+David_P Posted September 11, 2012 Share Posted September 11, 2012 Draco: I'll critique your English once I get my Polish up to that level. So far, all I know is "Poproszę piwo" Quote Link to comment Share on other sites More sharing options...
+Larry Posted September 11, 2012 Share Posted September 11, 2012 No critique -- I'd just never seen the word before. Believe me, Konrad, your English is impressive! How many different languages can you navigate? BTW, I also had to look up "Philology." -Larry Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 15, 2012 Share Posted October 15, 2012 Bug with 0.9 and 1.0 Bios? This is a small bug -- MAC/65 will not work with the IDE +2. It comes up properly, but with the keyboard "locked up." I've the (real) cart with both 0.9 and 1.0, and it does it with both. -Larry Quote Link to comment Share on other sites More sharing options...
+David_P Posted October 15, 2012 Share Posted October 15, 2012 Is that an IDE 2.0 bug, or a problem with SDX? I seem to recall that the SDX key buffer didn't play nicely with some software. Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 15, 2012 Share Posted October 15, 2012 No SDX active (I'm a MyDos holdout). Remove the IDE+2 and boot from SIO or Black Box, and MAC/65 comes up and works correctly. -Larry Is that an IDE 2.0 bug, or a problem with SDX? I seem to recall that the SDX key buffer didn't play nicely with some software. Quote Link to comment Share on other sites More sharing options...
drac030 Posted October 16, 2012 Author Share Posted October 16, 2012 Thanks, Larry. Problem noted. For now I have no idea, what may be the reason, Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 17, 2012 Share Posted November 17, 2012 Here is another issue... APE's print-thru feature will not work with the IDE+2 attached and powered. It will work if the IDE+2 is attached but not powered. It works with my other PBI devices, so I think it's something in the +2. Incidently, with the external power removed from the interface, the CF adapter LED still glows. Tried this on two XL's with the same result. (I know that is not your area.) With the IDE+2 attached and powered, I get this on the APE SIO monitor: Device: 40 Command: 3F Aux 1: 00 Aux 2: 00 Checksum: 7F Device: 40 Command: 3F Aux 1: 00 Aux 2: 00 Checksum: 7F Device: 40 Command: 3F Aux 1: 00 Aux 2: 00 Checksum: 7F Device: 40 Command: 3F Aux 1: 00 Aux 2: 00 Checksum: 7F (...repeated about 20 times or so.) With the IDE not powered, APE responds like this: Device: 40 Command: 53 Aux 1: 53 Aux 2: 02 Checksum: E8 Device: 40 Command: 57 Aux 1: 4E Aux 2: 02 Checksum: E7 Device: 40 Command: 57 Aux 1: 4E Aux 2: 02 Checksum: E7 Device: 40 Command: 57 Aux 1: 4E Aux 2: 02 Checksum: E7 (...repeats command 4E) Turning the IDE OFF in the menu does not solve the issue -- that gives same results as the first example above. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted November 17, 2012 Share Posted November 17, 2012 Larry, I have not tried this but you might try to turn off CIO in the START+RESET menu. Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 17, 2012 Share Posted November 17, 2012 Hi Roy- Thanks for the suggestion. That didn't work, but gave me an idea -- if I turn Ultra Speed OFF, then it works! Probably is a bug, but using the menu to turn off the US is sure a lot easier than unplugging the interface! Thanks, again! -Larry Quote Link to comment Share on other sites More sharing options...
drac030 Posted November 17, 2012 Author Share Posted November 17, 2012 Ok, I will block the US mode for device $4x. Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 18, 2012 Share Posted November 18, 2012 Thanks, Konrad! No hurry, for sure. -Larry Ok, I will block the US mode for device $4x. Quote Link to comment Share on other sites More sharing options...
Frankie Posted December 14, 2012 Share Posted December 14, 2012 SDXCLOCK.ATR Is a turbo basic compiled program that displays an analogue clock with a sweeping second hand. Also displayed is a date and seconds count. Runs with SDX445.rom in emulator or SIDE cartridge and IDE 2.0 PBI device. SDXCLOCK.ATR Mostly to test my rtime8 cartridge, incognito Atari800, and SIDE cartridge. Cool! When I run it on my 800XL it doesn't look as perfectly round as your screenshot. Your screen seems wider. Frank Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted March 23, 2013 Share Posted March 23, 2013 This is not a complete an perfect update, but since I have virtually no time for coding and I can't say for now, when I'll be able to code anything bigger again, I've decided (under some pressure from Stryker) to share what I have now. The new things are: 1) APT support: the BIOS should be able to recognize APT-partitioned media (like under SIDE). There is a program called IDEA2APT.COM in the archive, which converts the old partition table format to the new one. Before doing that, please backup your partition table (in sector 0) in some safe place, e.g. use Eddy in the "device edit" mode just copy the first sector of the disk to the very last one. The conversion does not establish a PC MBR there, to have that, you'll have to repartition the disk. ALSO: the FDISK2 included does NOT know APT format, sorry, I had no time to code new FDISK, but you may try using the SIDE FDISK made by FJC. It should - in theory - work, because SIDE and IDE Plus share common API, which allows the partition table area access. 2) support for Karin Maxi disk drive: you may selectively disable US SIO patch for drives 1-4. This allows to access parallel floppies, which otherwise (when US SIO is on) get masked out by the IDE Plus SIO. 3) support for other parallel devices in the loader: the loader should now be able to access not only SIO devices and IDE Plus drives, but also the media attached via other PBI devices (such as the Karin drive above). 4) minor bugfixes. The thing which is not there is the mounting support in the API. No time to code this, sorry. :/ So I decided to IDEA2APT my original CF card for the IDE2.0 rev'C' interface, but immediately put it back to original with the backup partition table(sector 0). I have been wondering if any further updates to IDEA2APT program are expected or should I just use (fjc) FDISK APT software on any new CF card. I have been able to insert a SIDE CF card into the IDE plus 2.0 and reads just fine. Quote Link to comment Share on other sites More sharing options...
Marius Posted March 23, 2013 Share Posted March 23, 2013 @reda6 I had problems with IDEA2APT tool. I had a few partitions that where now reporting invalid file system after the conversion. So I decided to go back too. Quote Link to comment Share on other sites More sharing options...
drac030 Posted March 24, 2013 Author Share Posted March 24, 2013 It seems that there is a problem with the converter, which I find odd because I have used it to convert my own disk and there were no problems. I hope to find this out soon. Quote Link to comment Share on other sites More sharing options...
