Images generated by RastaConverter
Philsan
23 hours ago, Beeblebrox said:
Great conversion and excellent choice of source image. Like the dithering algorythm used here. If anything I reckon it would benefit from more dithering around the face. Can you share the source image? :)
Yes. Excellent 3 color parts. Green area, orange area and blue area. Shows the power of Atari 800/400!
Atari black & White reflection. 8 colors.
AtariBWreflect.png.7799c68334d010a7b109b3a889826eea.pngGS_AtariBWReflect.xex
Atari Aqua Fuji. 83 colors.
AtariAqua1.png.62054cf3aefc4f1b01734049bb310e06.pngGS_AtariAqua1.xex
Atari Vector Fuji.  52 colors.
AtariVector.png.ca05a33b14b3dc42f3528484f2d32095.pngGS_AtariVector.xex
Atari Fuji rainbow. 43 colors.
AtariFujiRainbow.png.79b1fdd8f172ba86786aca83625205d2.pngGS_AtariFujiRainbow.xex
Red Atari.  24 colors.
RedAtari.png.60718c90c79cda17bc7e93e6790d2bd6.pngGS_RedAtari.xex
  • Like 11
AtariBWreflect.png.7799c68334d010a7b109b3a889826eea.png GS_AtariBWReflect.xex 22.39 kB · 0 downloads
AtariAqua1.png.62054cf3aefc4f1b01734049bb310e06.png GS_AtariAqua1.xex 21.98 kB · 0 downloads
AtariVector.png.ca05a33b14b3dc42f3528484f2d32095.png GS_AtariVector.xex 22.05 kB · 0 downloads
AtariFujiRainbow.png.79b1fdd8f172ba86786aca83625205d2.png GS_AtariFujiRainbow.xex 18.51 kB · 0 downloads
RedAtari.png.60718c90c79cda17bc7e93e6790d2bd6.png GS_RedAtari.xex 22 kB · 0 downloads
These are real nice I will use them to start a slide show.  Nice work!
On 2/20/2024 at 6:57 PM, MrFish said:
I'm getting the following error when I attempt to use the color remap batch file from RastaSlide 4.2.
Ok, thanks. that's interesting. The GO runtime itself is crashing. Were you able to run it OK on the 4.1 version of the color converter? I'm guessing it is crashing when it tries to open the Windows file selector GUI?
Feel free to PM me the details
Kind regards
Chris
[Edit]
I should note here, I'm running Windows 7 64-bit.
Edited by Sheddy
This was the first time I'd run the "#try to remap colours.bat" at all; but I just tried the ones from version 4 and version 4.1 with the same results. The last version I've successfully run is "#try to map PAL to NTSC.bat" from version 3.3. I think "#try to map PAL to NTSC.bat" wasn't included with version 3.4; so, nothing to try there.
  • Thanks 1
On 2/21/2024 at 7:59 PM, Atari8man2004 said:
American Indian Tribal Chief, Teepee and Buffalo.
Indian chief Colors: 66
Teepee       Colors: 70
Buffalo       Colors: 46
Plus the source images
Atari8man_TeePee.xex 22.05 kB · 12 downloads Atari8man_Buffalo.xex 22.1 kB · 10 downloads Source.7z 2.16 MB · 3 downloads
Chief is so awesome! Kudos!
[Edit]
RastaSlide 4.3 - RastaConverter Slide Show Maker and Tools
Changes in version 4.3
- Compiled with old GO version 1.20.14 which is the last that works with Windows 7
- Early version of tool to help recreate some files for RastaConverter /continue
@MrFish Hopefully this should work for you
RastaSlide 4.3.zip sheddy_opal_sea_turtle.xex
  • Like 4
  • Thanks 3
Worked perfectly.
I was able to convert colors for the Lincoln stamp from the original PAL to NTSC and avoid the greenery growing on Lincoln's eyebrows that showed up using remap with Rastaslide 3.3. :D
With this version (4.3) zero colors failed to be mapped.
Great having a generic color remap with dialogue that allows choosing a file with conversion values desired -- as well as the improved mapping accuracy (and having all the other RastaSlide functions available). Thanks!
mrfish - lincoln [ntsc].xex
  • Like 7
1 hour ago, Atari8guy said:
Never tried this before....so I thought I'd give it a go...not as good as all yours - open to tips.
image.thumb.jpeg.3c6063bf002b3509820ac32e042a935d.jpeg A8Guy_Spacekeeper.xex 22.03 kB · 0 downloads
You can use mask on the face...
Command line :
/details=mask.png /details_val=4
image.thumb.jpeg.3c6063bf002b3509820ac32e042a935d.jpeg A8Guy_Spacekeeper.xex 22.03 kB · 1 download
It looks like you created the image with a PAL palette and are viewing it with an NTSC palette. When I load it in Altirra with the NTSC palette it nearly matches your colors above and the fingers are off the bottom. When I switch to PAL I think the suit and glove and skin and hair colors are closer to the original. And it's the full frame.
  • Thanks 1
image.thumb.jpeg.3c6063bf002b3509820ac32e042a935d.jpeg A8Guy_Spacekeeper.xex 22.03 kB · 2 downloads
OK, a couple of tips...set the 'number of solutions' high, in the thousands or tens of thousands. This allows Rastaconverter many more attempts to get the conversion closer to the destination image. Images will take much longer to resolve, but will be much more representative of the destination image.
Also, the higher the contrast the easier it is for Rastaconverter to choose from the limited color pallette between best color and shade when down grading the color depth from the 256 color palette of the destination image to the 128 color palette of the Atari's graphic mode Rastaconverter uses and limitations in color change and position (less horizontal line stripes throughout the image).
Don't be afraid to experiment with drastic changes in the color brightness, contrast and gamma levels and all other settings to see what happens and experience will allow refinement of control and best initial guess for setting on any given image. It's more a learned skill, nearly an art form in itself in finding the best settings for Rastaconverter to get the best results on any given image. I liken it to photography, back when everything was manual, pre-digital cameras, when a photographer had to have knowledge and skill and talent to get the right lighting conditions, proper lens choice and adept focusing skills, on to development of the film to make the best photos. The best (manual-analog) camera in the world will only produce pictures based on the skill and talent of the photographer.
Edited by Gunstar
  • Like 4
On 10/4/2023 at 6:11 PM, MrFish said:
Classic airmail postage. Any stamp collectors out there?
Colors match up with the original image better on the NTSC version. Also, the aspect ratio was intended to match NTSC; so the PAL version is a bit squished.
NTSC
PAL
Remap of the NTSC version using RastaSlide 4.3.
mrfish - 24c curtis jenny NTSC.xex
  • Like 7
  • Thanks 1
