_The Doctor__ Posted May 14, 2023 Share Posted May 14, 2023 It does not save the SIO speed, you must change it after a power up... that what he's trying to convey... or so I would seem. 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 14, 2023 Share Posted May 14, 2023 (edited) 6 hours ago, _The Doctor__ said: It does not save the SIO speed, you must change it after a power up... that what he's trying to convey... or so I would seem. I understand what he's saying. Mine was saved as FastSIO $28. Unplugged all night. This morn on power up it's still at FastSIO $28. Brought to you by: [CTRL] W UBL Y. Edited May 14, 2023 by Ricky Spanish clarity Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 14, 2023 Share Posted May 14, 2023 BTW, loading ATARI DOS 2.5 at any speed shows zero errors in the Sdrive Max debugger. Whereas SPARTADOS 3.2x shows multiple SIO loading errors. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted May 14, 2023 Share Posted May 14, 2023 7 hours ago, Ricky Spanish said: I understand what he's saying. Mine was saved as FastSIO $28. Unplugged all night. This morn on power up it's still at FastSIO $28. Brought to you by: [CTRL] W UBL Y. when saving the configuration is only for sdrive-ng, it updates the configuration that is inside the sdrive.atr. on mine when I start sdrive-max in the touch menu it doesn't save any sio speed setting since I don't start sdrive-ng, it always detects it at $06. 2 hours ago, Ricky Spanish said: Whereas SPARTADOS 3.2x shows multiple SIO loading errors. in my case it does not show error when loading in $10 spartados Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 14, 2023 Share Posted May 14, 2023 On 5/13/2023 at 12:13 PM, Ricky Spanish said: Resolved. There are seven atmega328 folders, the correct one for me was: atmega328-hx8347i However v1.3 did not resolve the issue with spartados_3.2G.atr having to be booted from D0 with FastSIO $10 39000. Any setting faster than 39000 it will not boot even from D0. Since I've never done this before I am following this guys lead on how to burn/update.Which in this video start at about 14:06. Couple questions. How can I be sure what Aduro or touch screen I have? How about com ports? Are these things autodetected? Quote Link to comment Share on other sites More sharing options...
ascrnet Posted May 14, 2023 Share Posted May 14, 2023 4 minutes ago, JagChris said: Since I've never done this before I am following this guys lead on how to burn/update.Which in this video start at about 14:06. Couple questions. How can I be sure what Aduro or touch screen I have? How about com ports? Are these things autodetected? is that easy as shown in the video. 1. the easy way is to ask your sdrive-max supplier. 2. when you connect it to your PC check which new usb port appeared in device manager. Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 14, 2023 Share Posted May 14, 2023 17 minutes ago, ascrnet said: is that easy as shown in the video. 1. the easy way is to ask your sdrive-max supplier. 2. when you connect it to your PC check which new usb port appeared in device manager. 1. I got it from the brewing academy so i will either have to find the instructions I've misplaced or ask them. 2. OK. Can do. Ill get to all this at some point. Not a huge priority. Only program I'm having issues with so far is Atari Planetarium. All copies work fine so long as I am careful I'm not in screensaver mode when using info or going to the map screens. Which are the ones that access the drive. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 14, 2023 Share Posted May 14, 2023 (edited) 9 minutes ago, JagChris said: 1. I got it from the brewing academy So did I. Everything, and I mean everything works awesome. Even .atx. Edited May 14, 2023 by Ricky Spanish Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 14, 2023 Share Posted May 14, 2023 1 hour ago, Ricky Spanish said: So did I. Everything, and I mean everything works awesome. Even .atx. Good. So you resolved your issues? What type screen/Arduro do you have? I'm going to assume they're the same. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 15, 2023 Share Posted May 15, 2023 1 hour ago, JagChris said: Good. So you resolved your issues? Never had issues save for one very minor one with spartados. But in no way did it prevent it from loading. 4 hours ago, ascrnet said: in my case it does not show error when loading in $10 spartados Guess my copy of SD 3.2g (from atariwiki) is pooched in some way. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted May 15, 2023 Share Posted May 15, 2023 6 minutes ago, Ricky Spanish said: Guess my copy of SD 3.2g (from atariwiki) is pooched in some way. strange I used these two for my tests : 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 15, 2023 Share Posted May 15, 2023 3 hours ago, ascrnet said: strange I used these two for my tests : Yes I'm using the 92KB atr Quote Link to comment Share on other sites More sharing options...
magnusfalkirk Posted May 15, 2023 Share Posted May 15, 2023 I've got the S-Drive Max that I bought from The Brewing Academy, not having any issues with it. Is there any reason why I should update the firmware from 1.2 to 1.3? If there is how would I do that using a Mac? Quote Link to comment Share on other sites More sharing options...
ascrnet Posted May 15, 2023 Share Posted May 15, 2023 32 minutes ago, magnusfalkirk said: I've got the S-Drive Max that I bought from The Brewing Academy, not having any issues with it. Is there any reason why I should update the firmware from 1.2 to 1.3? If there is how would I do that using a Mac? for your questions about v1.3 read here, as I do on Mac read here 😉 Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 19, 2023 Share Posted May 19, 2023 Found another one that doesn't like the screensaver mode. Seven Cities of Gold. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 19, 2023 Share Posted May 19, 2023 (edited) I am sure you will find a thread that covered the screensaver issues and a number of titles that failed because of it. Turn it off. Edited May 19, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 19, 2023 Share Posted May 19, 2023 Just disable the screensaver and go ahead. 1 Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 19, 2023 Share Posted May 19, 2023 3 hours ago, _The Doctor__ said: I am sure you will find a thread that covered the screensaver issues and a number of titles that failed because of it. Turn it off. Yeah that or if I can ever find the instructions I can probably figure out what hardware I have to.update it. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted May 19, 2023 Share Posted May 19, 2023 (edited) 1 hour ago, JagChris said: Yeah that or if I can ever find the instructions I can probably figure out what hardware I have to.update it. The update will not matter for this problem. The latest changes are related to cassette file use. Take @_The Doctor__ suggestion. Just turn it off. I think in the same thread, kbr mentioned it was just a small feature that he thought would be nice to have. He did not know it was going to cause these problems. He may find the problem eventually, but I know I do not care about possible burn-in on my Sdrive Max touchscreen. As far as updating, try every option. You can’t brick the device doing that. You’ll be able to tell immediately if it works or not. Bob C Edited May 19, 2023 by darwinmac Stupid autocorrect and update suggestions Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 20, 2023 Share Posted May 20, 2023 4 hours ago, darwinmac said: The update will not matter for this problem. The latest changes are related to cassette file use. Take @_The Doctor__ suggestion. Just turn it off. Bob C Apparently so. I don't know why that guy was telling me to update the firmware then. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 20, 2023 Share Posted May 20, 2023 Maybe because they expect you will move on to other things and have a problem there as well. So I'd do the update anyway. Quote Link to comment Share on other sites More sharing options...
magnusfalkirk Posted May 20, 2023 Share Posted May 20, 2023 (edited) 23 hours ago, JagChris said: Yeah that or if I can ever find the instructions I can probably figure out what hardware I have to.update it. If you need a copy of the instructions for the S-Drive Max from The Brewing Academy I can email you a pdf. I scanned the instructions and turned them into a pdf just in case I managed to lose the paper copy I got with the S-Drive Max. Edited May 20, 2023 by magnusfalkirk Quote Link to comment Share on other sites More sharing options...
JagChris Posted May 20, 2023 Share Posted May 20, 2023 1 hour ago, magnusfalkirk said: If you need a copy of the instructions for the S-Drive Max from The Brewing Academy I can email you a pdf. I scanned the instructions and turned them into a pdf just in case I managed to lose the paper copy I got with the S-Drive Max. That would be great. Just pm me. I tried looking on the brewing academy's site etc. Does the instructions have the component types in it? Right after I receive them ill surely find the originals. Quote Link to comment Share on other sites More sharing options...
magnusfalkirk Posted May 20, 2023 Share Posted May 20, 2023 PM sent Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 21, 2023 Share Posted May 21, 2023 https://atari8bit.net/tutorials/de-re-sdrive-max/ Quote Link to comment Share on other sites More sharing options...
