Albert Posted August 17, 2022 Author Share Posted August 17, 2022 59 minutes ago, Stephen said: Is there a way to turn off the live banner that shows who is in a forum / thread? It's very annoying, takes up space, and loads a few seconds after the page which causes it to suddenly drop down. I've currently got it blocked via a content rule, but a setting would be cool. I haven't seen the issue where the page drops down (I'm using the latest version of Firefox), but it is unnecessary, so I just turned it off. ..Al 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted August 18, 2022 Share Posted August 18, 2022 On 8/15/2022 at 11:29 AM, Albert said: There's not really anything that can be fixed on this side. An CDN (Content Delivery Network) is now being used for attachments. I can download an attachment in a new browser window if I manually use the link (paste it into the URL bar), so I'm not sure why this doesn't work for JS7800/Javatari, but hopefully it's something that can be solved. It's possible there's security against external sites attempting to access these resources, even if they are publicly viewable on the forum. It's something I'd need to research further. ..Al @Albert If this helps I found this website that parses redirects and shows the resulting full redirected URL: https://wheregoes.com/ I used the binary (CB_2022_08_15b.bas.bin) from a couple of days ago posted in this thread as an example: Original AA file URL: https://forums.atariage.com/applications/core/interface/file/attachment.php?id=961046&key=5e5af444ff3268565c0e4824b9772ea7 When the trace is performed on it, the result is an extremely long URL string from the Amazon CDN: When you click or paste the URL into a browser it will result in prompting you to download a file, which is the expected result. When you pass the long URL to the Javatari emulator it has no clue what to do with it, resulting in an error. If you try to reduce the URL down to just past the file name, to possibly make it more friendly for the emulator page, it will break the ability to download the file from the CDN. I don't think there will be a solution to the file redirect issue unless possibly one of these unlikely things happens: 1) The CDN changes the way the file URL is presented in a more friendly fashion 2) The emulators are able to handle these long URLs. Thoughts? - James 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 The theme designer made a ton of changes to the forum this evening, and I just went through all of them. One of the changes, for instance, is putting the "Edit" button back on the bottom bar of a post next to the Quote bottom (the Report link is now visible at the top of a post as well). Messages are now cleanly separated in the Messenger like before, which I'm grateful for, as that was driving me nuts. Lots of color and other aesthetic changes, like using an orange AtariAge logo on the main page to denote forums with unread content, replacing the small "pinned" icon with a green PINNED label, making the tags orange again (although I still see a problem with that), fixing the dark gray text that would appear in some blue horizontal bars (like in the "Who's Online" section on the main forum index), etc. I will be making another, hopefully much shorter list of things to change once I can more carefully go through all the changes (I see a few issues still), and of course I need to go through the mobile skin to change several things there. But it's looking a lot better now with all these new changes! ..Al 3 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted August 18, 2022 Share Posted August 18, 2022 Once again - thanks for all this BS you go through to keeps the forums up & running. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 18, 2022 Share Posted August 18, 2022 I suppose this is a bug too, because it is not my topic: 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 18, 2022 Share Posted August 18, 2022 Hi Albert, 75%+ of the time when I mark a forum as read I get this. It started after the last upgrade. I mentioned it then, it has never gone away. This happens only on a PC, not on a tablet or phone. Before you ask, this is not the same PC as I had during the last upgrade. It has done this on every PC I have used since then. I can hit the back button and the second time it works, every time on the second try it works. 1 Quote Link to comment Share on other sites More sharing options...
+Bruce-Robert Pocock Posted August 18, 2022 Share Posted August 18, 2022 12 hours ago, ZeroPage Homebrew said: @Albert If this helps I found this website that parses redirects and shows the resulting full redirected URL: https://wheregoes.com/ I used the binary (CB_2022_08_15b.bas.bin) from a couple of days ago posted in this thread as an example: Original AA file URL: https://forums.atariage.com/applications/core/interface/file/attachment.php?id=961046&key=5e5af444ff3268565c0e4824b9772ea7 When the trace is performed on it, the result is an extremely long URL string from the Amazon CDN: When you click or paste the URL into a browser it will result in prompting you to download a file, which is the expected result. When you pass the long URL to the Javatari emulator it has no clue what to do with it, resulting in an error. If you try to reduce the URL down to just past the file name, to possibly make it more friendly for the emulator page, it will break the ability to download the file from the CDN. I don't think there will be a solution to the file redirect issue unless possibly one of these unlikely things happens: 1) The CDN changes the way the file URL is presented in a more friendly fashion 2) The emulators are able to handle these long URLs. Thoughts? - James The Javatari script calls to https://webmsx.herokuapp.com/proxy-remote-download?url=https://atariage.com/forums/applications/core/interface/file/attachment.php?id=611057 (for example) to fetch a binary. This in turn is being actively blocked by CloudFront. From the console I see this being returned by Heroku: 403 ERROR The request could not be satisfied. Request blocked. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner. If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation. Generated by cloudfront (CloudFront) Request ID: WC5TRK7lMA85JauG5D9K4FvtTsQ5PnjOi7PeI-12g_UYPnUatdMumA== Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 18, 2022 Share Posted August 18, 2022 (edited) 16 hours ago, atari2600land said: I get the orange message to read this thread when I already did. I get the heart or a Bell not sure what it's supposed to be, but says click here to click again a bell to read a post that hasn't been read . nothing like click click lol It's working just like it's supposed to.. Edited August 18, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 16 hours ago, atari2600land said: I get the orange message to read this thread when I already did. Yeah, pretty sure that uses a cookie that must have expired, so as it's been two weeks, I'm going to remove that entirely. ..Al Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted August 18, 2022 Share Posted August 18, 2022 I want to say thank you. This morning I woke up and my eyes didn't hurt from the typical white washed flat bland design that seems to be prevelent these days. The pages look crisp, the hardly noticeable thumbtacks are replaced with PINNED images -- things are looks so much better to my eyes. I'm still iffy on the washed out number of pages in a thread boxes that appear next to a topic until you mouse over them but damn its looking so much better. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 49 minutes ago, kheller2 said: I want to say thank you. This morning I woke up and my eyes didn't hurt from the typical white washed flat bland design that seems to be prevelent these days. The pages look crisp, the hardly noticeable thumbtacks are replaced with PINNED images -- things are looks so much better to my eyes. Yeah, the changes yesterday were numerous and definitely helped quite a bit. There are still things to fix, though! 49 minutes ago, kheller2 said: I'm still iffy on the washed out number of pages in a thread boxes that appear next to a topic until you mouse over them but damn its looking so much better. I've asked for this to be changed to more closely match the old forum. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 I've gone through all the changes that were made yesterday, and made a new list of changes for the theme designer to implement to further polish the theme. Once these are done, I will then focus my efforts on the mobile view of the theme, as I know there's a bunch of stuff there that needs to be tweaked. Also, I will continue working on functional problems, such as the missing emoticons, and I'll need to dig into issues with the forum incorrectly displaying unread status for forums/threads. Will post again once the next round of changes are implemented. These shouldn't take as long as I provided a lot of screenshots and it's a much shorter list this time. ..Al 4 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted August 18, 2022 Share Posted August 18, 2022 9 hours ago, Thomas Jentzsch said: I suppose this is a bug too, because it is not my topic: I don't think this is a bug, the first post in the thread was posted by you. - James 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted August 18, 2022 Share Posted August 18, 2022 (edited) 3 hours ago, kheller2 said: I want to say thank you. This morning I woke up and my eyes didn't hurt from the typical white washed flat bland design that seems to be prevelent these days. Yup. Thankfully the sudden jump to flat metro and wasted whitespace hasn't happened. Clean delineation and gentle outlining without loss of functionality is important in forums. I kinda thunked it wouldn't happen, but reassuring to see it didn't. Much commercial software intended for mass public consumption seems to have its user interface dumbed down with removed features/functionality nowadays. Some even becomes unpleasant to use. Edited August 18, 2022 by Keatah 2 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 7 minutes ago, ZeroPage Homebrew said: I don't think this is a bug, the first post in the thread was posted by you. Yes, that is correct. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 18, 2022 Author Share Posted August 18, 2022 On 8/17/2022 at 1:49 PM, Thomas Jentzsch said: How about all the bugs reported before the migration? BTW: The Issue Tracker doesn't work anymore. So, I looked at this, and the reason it's not active is the author has not yet updated it for version 4.7 of the software. I posted a message in the support topic for this forum asking if he plans on updating it. I may need to search for an alternative, as it doesn't look like the author's really paying attention to this application any more. He did update it to version 4.6, but that was a while ago. ..Al Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 18, 2022 Share Posted August 18, 2022 1 hour ago, ZeroPage Homebrew said: I don't think this is a bug, the first post in the thread was posted by you. I still don't remember that I had created the thread. I was 100% sure it was you. 2 Quote Link to comment Share on other sites More sharing options...
Shannon Posted August 18, 2022 Share Posted August 18, 2022 34 minutes ago, Thomas Jentzsch said: I still don't remember that I had created the thread. I was 100% sure it was you. ZeroPage Homebrew changed the topic title at some point. Maybe that is what threw you off. 2 Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 19, 2022 Share Posted August 19, 2022 if you don't mind me asking - how many moderators does this site have? after the update I see a few members that now have this badge in the upper right corner of their profile picture: Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted August 19, 2022 Share Posted August 19, 2022 3 hours ago, fdr4prez said: if you don't mind me asking - how many moderators does this site have? after the update I see a few members that now have this badge in the upper right corner of their profile picture: I think it used to say 'Moderator' under the icon which has been replaced with a shield, which looks much cleaner IMO. I believe you can find the list of moderators on this page, which is accessible under 'More' then 'Staff' in the top menu. - James 1 Quote Link to comment Share on other sites More sharing options...
Jason_Atari Posted August 19, 2022 Share Posted August 19, 2022 I'm not sure if this has been mentioned before but ever since the update emojis are appearing as question marks. Quote Link to comment Share on other sites More sharing options...
Keatah Posted August 19, 2022 Share Posted August 19, 2022 Not sure if it's been reported yet. Page numbers and window title bar numbers not consistent. Say open a thread on page 2, It opens to page 2. Ok good. But now left-click on page 3 to advance. The page content changes and updates of course, but the title in the window bar stays the same like so. However, if I open it in a new tab, it works fine. Like so. Quote Link to comment Share on other sites More sharing options...
Atarian7 Posted August 19, 2022 Share Posted August 19, 2022 If you hover your mouse over a person's name it shows if they are online or not , but it used to show where they were. Was this done on purpose? Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 19, 2022 Share Posted August 19, 2022 1 hour ago, Atarian7 said: If you hover your mouse over a person's name it shows if they are online or not , but it used to show where they were. Was this done on purpose? And it use to show you the last time they were online, but it doesn't show that any longer either Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 19, 2022 Share Posted August 19, 2022 3 hours ago, fdr4prez said: And it use to show you the last time they were online, but it doesn't show that any longer either nevermind, it seems to show that now (again) Quote Link to comment Share on other sites More sharing options...
