matosimi Posted June 21, 2023 Author Share Posted June 21, 2023 12 minutes ago, ascrnet said: Game Over !!!! 😜 Congrutalations! 13 minutes ago, ascrnet said: no problem, I just needed the exact number. if I play from the emulator as the 5 levels at the end take time because the screen is smaller, more accurate shots at you and must make more combinations with the blocks to unlock access. 😄 I see you spotted that the shots are different... they shoot more often, but also in regular game the collision algorithm is pixel perfect, so it is possible that the shot flies through you or in between 0 and 1... however in the endpart the collision algorithm is using bigger hitbox instead of pixel-perfect collisions so it is no longer possible that the shot flies through you. 3 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted June 21, 2023 Share Posted June 21, 2023 2 hours ago, matosimi said: Congrutalations! I see you spotted that the shots are different... they shoot more often, but also in regular game the collision algorithm is pixel perfect, so it is possible that the shot flies through you or in between 0 and 1... however in the endpart the collision algorithm is using bigger hitbox instead of pixel-perfect collisions so it is no longer possible that the shot flies through you. 👍 of course, my strategy was to stop seconds before the shot and then continue. this ensured that I dodged the bullet going straight at the player. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted July 4, 2023 Share Posted July 4, 2023 No one seems to be playing it anymore if it's not that hard. 😅 I'm playing it again because I forgot to write down the names of the first levels : 00. WELCOME 01. RESTART 02. PETERLIEPA 03. RIDICULOUS ZERO 04. WORMZORG 05. CHUCKNORRIS 06. MONEX ONE 07. ARCH O NEMESIS 08. ZYBEXLAND 09. PROMISCUOUS CAT 10. DEADLY PROJECT ISLE 11. NINE ELEVEN TWO 12. SPIELER EINS LOS 13. LIQUIDSNAKE This is to put it in a cheat article 😉 1 1 Quote Link to comment Share on other sites More sharing options...
patjomki Posted July 5, 2023 Share Posted July 5, 2023 (edited) 7 hours ago, ascrnet said: No one seems to be playing it anymore if it's not that hard. 😅 I'm playing it again because I forgot to write down the names of the first levels : ... This is to put it in a cheat article 😉 Would you mind using spoiler tags next time? 😉 Edited July 5, 2023 by patjomki 2 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted July 5, 2023 Share Posted July 5, 2023 8 hours ago, patjomki said: Would you mind using spoiler tags next time? 😉 I see that you never played it, even if I put the 30 levels you will not finish it because the last level has 5 levels in a row to finish it and these are more difficult than the previous 29. To not continue with the spoiler as you say, I will publish it only in my web.😉 1 Quote Link to comment Share on other sites More sharing options...
