F4NTOM Posted January 22 Share Posted January 22 Trying to update my 2600+ on my PC (that I used before to perform the first update) and the PC doesn't recognize the 2600+. Is there something I'm not doing or did something change? Quote Link to comment Share on other sites More sharing options...
+karri Posted January 22 Share Posted January 22 Did the dump still get identified as a RAM enabled cart? I believed all the RAM areas in the 4k blocks needed to be identical for the cart to be recognized correctly. Quote Link to comment Share on other sites More sharing options...
NicodemusLegend Posted January 22 Share Posted January 22 On 1/19/2024 at 6:24 PM, chad5200 said: I don’t have Time Pilot but I do have Mouse Trap and it’s playing fine. Always has since 1.00 if I recall correctly. I can confirm that Mouse Trap works fine on my 1.00 2600+. I'm always curious to learn if a Firmware upgrade breaks something, of course, but I'm guessing that's not what's going on here. Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 22 Share Posted January 22 27 minutes ago, F4NTOM said: Trying to update my 2600+ on my PC (that I used before to perform the first update) and the PC doesn't recognize the 2600+. Is there something I'm not doing or did something change? Try a usb 3.0 port. First time I had to use 2.0 then it would not recognize the 2600+ Or it was intermittent 1 Quote Link to comment Share on other sites More sharing options...
F4NTOM Posted January 23 Share Posted January 23 9 minutes ago, MrChickenz said: Try a usb 3.0 port. First time I had to use 2.0 then it would not recognize the 2600+ Or it was intermittent I goofed - forgot to use the pack-in cable. Got it to work and now I can play Robot Tank! 2 Quote Link to comment Share on other sites More sharing options...
dfdfan Posted January 23 Share Posted January 23 I will be unable to update firmware until a mac loader is available but in the meantime, does anyone know if there will be trackball support for the TB hacks? Or is that pretty much a pipe dream with emulation the same way paddles will always be a little choppy? 2 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 23 Share Posted January 23 (edited) 9 hours ago, Blinky said: my PAL dig dug and Fatal play fine too (not counting the 50/60 Hz issues). I dumped both roms on the 2600+ and noticed something interesting. on Fatal run the RAM sections all read FFs except the section at offset 0x6000 that one reads as all 00s. Dig dug is even more interesting. All ram sections are different but the 128 byte write section contains the same contents as the 128 byte read section. With @Thomas Jentzsch knowledge that SC RAM is slow. I'd say the dumper reads out the data stored in ROM that is normally not accessible but since the dumper is faster than than RAM. it reads the rom before the ram data is enabled/output. The data read is probably junk that was in memory when the source code of the game was assembled. two sections that cointain mostly ASCII: I have to correct myself regarding SC RAM detection. Here is Stella's code: bool CartDetector::isProbablySC(const ByteBuffer& image, size_t size) { // We assume a Superchip cart repeats the first 128 bytes for the second // 128 bytes in the RAM area, which is the first 256 bytes of each 4K bank const uInt8* ptr = image.get(); while(size) { if(std::memcmp(ptr, ptr + 128, 128) != 0) return false; ptr += 4_KB; size -= 4_KB; } return true; } So not all banks have to be equal, but the first 128 bytes or RAM have to be identical with the 2nd 128 bytes. Sorry for causing confusion. Edited January 23 by Thomas Jentzsch 4 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted January 23 Share Posted January 23 OMG! That is why my cart fails on the 2600+. This is an amazing forum. So much information and things to learn. 2 Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted January 23 Share Posted January 23 39 minutes ago, Thomas Jentzsch said: I have to correct myself regarding SC RAM detection. Here is Stella's code: bool CartDetector::isProbablySC(const ByteBuffer& image, size_t size) { // We assume a Superchip cart repeats the first 128 bytes for the second // 128 bytes in the RAM area, which is the first 256 bytes of each 4K bank const uInt8* ptr = image.get(); while(size) { if(std::memcmp(ptr, ptr + 128, 128) != 0) return false; ptr += 4_KB; size -= 4_KB; } return true; } So not all banks have to be equal, but the first 128 bytes or RAM have to be identical with the 2nd 128 bytes. Sorry for causing confusion. That'll work for static binary files. But for dumping a better way might be to have two dumps and compare them. If the RAM area truly is random then the dump differences are where the RAM is located. You'd have to be prepared for similarities occurring by chance though. If it was me, I would try something like this: 1) Acquire two dumps from cartridge 2) Compare bytes in RAM area of cartridge 3) If there are N differences then it's an SC cartridge (N being an appropriate threshold) 4) Check non RAM area. If there are differences then the dump has failed - or at least, it's not an SC chip but something more exotic Quote Link to comment Share on other sites More sharing options...
+karri Posted January 23 Share Posted January 23 7 minutes ago, JetSetIlly said: That'll work for static binary files. But for dumping a better way might be to have two dumps and compare them. If the RAM area truly is random then the dump differences are where the RAM is located. You'd have to be prepared for similarities occurring by chance though. If it was me, I would try something like this: 1) Acquire two dumps from cartridge 2) Compare bytes in RAM area of cartridge 3) If there are N differences then it's an SC cartridge (N being an appropriate threshold) 4) Check non RAM area. If there are differences then the dump has failed - or at least, it's not an SC chip but something more exotic If I had to do it I would write a word to address 0x1000, wait for a while and read it from 0x1080. Repeat the process with another word. If it is RAM I just dump the cart starting at 0x1100 for all blocks and leave the RAM area untouched. For Stella I would fill the RAM area in the dump with zeros. 2 Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted January 23 Share Posted January 23 3 minutes ago, karri said: If I had to do it I would write a word to address 0x1000, wait for a while and read it from 0x1080. Repeat the process with another word. If it is RAM I just dump the cart starting at 0x1100 for all blocks and leave the RAM area untouched. Yes. That's smart. Simpler and quicker Quote Link to comment Share on other sites More sharing options...
Glorkbot Posted January 23 Share Posted January 23 (edited) 10 hours ago, dfdfan said: I will be unable to update firmware until a mac loader is available but in the meantime, does anyone know if there will be trackball support for the TB hacks? Or is that pretty much a pipe dream with emulation the same way paddles will always be a little choppy? No one has said paddles will always be a little choppy! We’re still hoping for a firmware update to fix it! But not many people (comparatively) own the trackballs, and Atari doesn’t currently sell them (unlike the paddles) so I would hope getting the paddles to work better would be a priority. I haven’t heard anyone say there would never be trackball support, though. Edited January 23 by Glorkbot 1 1 Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 23 Share Posted January 23 Private Eye Activision (NTSC) 1.1.0.9 dumper has slight clicking intro music otherwise seems to play good! 1 Quote Link to comment Share on other sites More sharing options...
Plumbob Posted January 23 Share Posted January 23 On 1/1/2024 at 7:03 PM, Plumbob said: I tested with an Atari 7800 ProSystem along side an updated 2600+ both hooked up to different inputs on the same TV so I could compare. I found: For 2600 Astroblast (Mattel Inc.), the paddle input works great but the joystick doesn't work at all. Homebrew 2600 Hero2 (Game Select) just shows a black screen after it says Loading Game. It does NOT say Loading Game Failed. I retried several times. The cartridge works just fine in my 7800. Dig Dug for the 7800 no longer has a random line at the top of the screen. So that is good! I realize this update was mainly focused on 7800 homebrew but wanted to provide feedback on what I found. I had a lot of trouble with updating the 2600+ until I realized that I wasn’t following Ben’s instructions closely enough. I guess I need new glasses! Overall this is great work and I really appreciate that Plaion is providing updates to get it working perfectly! I’m really enjoying “participating” on this forum. My HERO 2 cart doesn’t load on the 2600+. But it doesn’t say load failed either. It just comes up as a blank screen. Can anybody else confirm if Hero 2 is working on their 2600+ or if it will work in the next firmware update? I am very grateful for any help with getting this game to work! Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 23 Share Posted January 23 Pigs in Space 2600 (NTSC) 1.1.0.9. Disappearing enemy missiles unplayable! 1 Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 23 Share Posted January 23 Activison Crackpots 2600 (NTSC) 1.1.0.9. Hesitates while moving left to right! 1 Quote Link to comment Share on other sites More sharing options...
chad5200 Posted January 23 Share Posted January 23 20 minutes ago, MrChickenz said: Activison Crackpots 2600 (NTSC) 1.1.0.9. Hesitates while moving left to right! Not for me... but I don't experience any of the performance related issues that you and others are reporting. I think it's pretty clear now that some 2600+ units are having CPU issues and others are not. Maybe comes down to the different tolerances of the CPU's and when they were manufactured. I think the only solution is for Plaion to optimize the CPU usage. 2 1 Quote Link to comment Share on other sites More sharing options...
TornadoTJ Posted January 23 Share Posted January 23 15 hours ago, dfdfan said: I will be unable to update firmware until a mac loader is available but in the meantime, does anyone know if there will be trackball support for the TB hacks? Or is that pretty much a pipe dream with emulation the same way paddles will always be a little choppy? Currently it works in joystick mode but not in TB mode. Centipede TB for 7800 loads, but you can't do anything after that. 1 Quote Link to comment Share on other sites More sharing options...
inky71 Posted January 23 Share Posted January 23 (edited) On 1/20/2024 at 2:43 PM, MrChickenz said: Can you check Space Attack, I only have one copy but I am getting a popping sound every couple of seconds, I've changed usb power cable, power brick, switched hdmi ports on tv, no popping on Flashback Gold 12 rom or my Retron 77... M-Network the ones I have all work 1 ASTROBLAST (paddles) 2 SPACE ATTACK 3 TRON DEADLY DISCS 4 ADVENTURES OF TRON 5 AIR RAIDERS 6 ARMOR AMBUSH (two player only) 7 FROGS AND FLIES 8 LOCK AND CHASE 9 DARK CAVERN 10 SUPER CHALLANGE FOOTBALL (two player only) 11 SUPER CHALLANGE BASEBALL (two player only) Edited January 23 by inky71 Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 23 Share Posted January 23 24 minutes ago, inky71 said: Yes I do have a popping sound on mine as well! Quote Link to comment Share on other sites More sharing options...
inky71 Posted January 23 Share Posted January 23 14 minutes ago, MrChickenz said: Yes I do have a popping sound on mine as well! Thanks for checking so fast! So its not my cart or my particular 2600+, the Retron 77 has no audio problems but does have graphical errors. I'm collecting all the M Network Games to satisfy my intellivision itch and Space Attack is one of my Fav's so I was bummed to hear this audio problem while play. 1 Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted January 23 Share Posted January 23 16 minutes ago, MrChickenz said: Yes I do have a popping sound on mine as well! I've just checked and this is the same issue as Pitfall, Fishing Derby and Hero. I'm almost certain this is because of the non-zero volume registers and an under-running audio buffer. 1 Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted January 23 Author Share Posted January 23 15 minutes ago, JetSetIlly said: I've just checked and this is the same issue as Pitfall, Fishing Derby and Hero. I'm almost certain this is because of the non-zero volume registers and an under-running audio buffer. Appreciate all your posts. This will be looked into. We're just having some last minute checks on a 1.1 beta rev 2 which should be released imminently, then we'll be looking more at 2600 issues like CPU maxing out and audio clicking. 10 4 Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted January 23 Share Posted January 23 1 minute ago, Ben from Plaion said: Appreciate all your posts. This will be looked into. We're just having some last minute checks on a 1.1 beta rev 2 which should be released imminently, then we'll be looking more at 2600 issues like CPU maxing out and audio clicking. Thanks Ben! And to everyone else involved! Quote Link to comment Share on other sites More sharing options...
Krullor Posted January 23 Share Posted January 23 Hi I have two copies of Defender II PAL. One loads and works 9 times out of 10 and one fails 9 times out of 10 on the 2600+ but both work without issue on my old system. Is this a known issue? Quote Link to comment Share on other sites More sharing options...
