Gazoo Posted May 11, 2014 Author Share Posted May 11, 2014 You want my scuzzy hard drive image? Has a couple hundred ea3 & 5 games including the ones you were looking for? Absolutely. Not being a gamer, I had trouble tracking down enough games to fill this cart. Having an ample supply would help me to construct another one. Gazoo Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 11, 2014 Author Share Posted May 11, 2014 Yeah, it really needs a reset button (maybe a DPST that remove power from the 378 as well as reset the console). But with this cart, you don't need the 32K expansion; it'll work on a stock console. Thus, it worked for someone like my father, who still has a stock console which he and his other grandkids play with. A couple cool things about the program; just as trivia; Tursi did a really cool job with the 256 bytes in VDP making this work, and Sometimes99er did an outstanding job on the font and the graphics! (I really do like the font and graphics....) Well if you're interested in trivia... The code that I've constructed to make this work is 'Code that moves code that moves code that moves code' and finally executes. Sort of like the 'Star Trek The Next Generation' that had a 'Holodeck in a Holodeck in a Holodeck'. I still have trouble watching that one and figuring out what Holodeck we're watching. So just imagine keeping track of what code you're working on. And then you threw me for a loop when you said that the >6000 bank doesn't reset to the first one on a quit. That required putting Rom headers where they didn't belong, and using all of the available Scratchpad Ram except 6 bytes. Actually I'm using more Scratchpad Ram than is allowed, but it doesn't seem to be hurting anything. Anyway... it works. Gazoo Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 12, 2014 Share Posted May 12, 2014 Some thoughts now that I had a couple hours (on and off, mostly off) to mess with the UberGROM cart (PLCC). It's getting really hard to find hobby time lately. 1) The 49F040's are rock solid. They program and verify A-OK. The sockets on the boards are what's causing my grief with them. The sure fire way to fix it (and I've been having to do it frequently) are to take a little needle (one of those like that comes with a collared shirt, really tiny), and stick it in the hole behind the metal contact on the socket; each one of them; do it STRAIGHT DOWN, don't bend it at an angle. That bends them out enough to where they work again. If we go to prod with these boards, we might want to find a different manufacturer of the sockets. 2) I've successfully gotten Gazoo's util cart, Gazoo's games cart, Tursi's Bank Test, and Tursi's Multicart working with the 49F040 boards. 3) Some of my 74LS378's power up in the first bank, some in the last. Don't ask me why. They're all TI brand. They don't have a defined power up state, but now with 512K, we can probably afford putting a safety feature in the last bank just in case as well as the normal first bank. (In fact, let's just make that a standard.) 4) Gazoo's games cart, the latest version, (I haven't reviewed the utility one yet for functionality) only has a few things I noticed offhand on a real console with a Corcomp Mini PEB attached: Blasto just resets my system Blackjack and Poker does the same Hopper has something strange (not sure if it's the cart or the F18A) where I can move the kangaroo throughout the WHOLE screen; that's right, she goes through just about anything. Everything else appears to work (selecting game and trying to start it). I need to buy some more materials to finish making four that Ksarul sent me (mostly sockets and caps). I the meantime, I tried to make 2048 into a cart (thinking it was a 16K ROM image), and couldn't do so, but I'll look at it a little closer and make sure it's meant to be a 16K banked ROM. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 12, 2014 Share Posted May 12, 2014 The last week or two has given me a lot of data that needs to be added to the manual. The more people there are using the boards, the more questions there are as people try to push the envelope with it. That is a very good thing. . .although, from the comments from Acadiel and Gazoo on the foibles of PLCC sockets, it looks like we'll need to devote an entire section to the care and feeding of the PLCC sockets. I'm not sure that it will change with any other socket manufacturer (other than for burn-in sockets, which were designed to take extreme punishment), as most of the ones I've seen for sale seem to be of a similar degree of stability. Gazoo may be able to tell us more there, as he noted that he's worked with them for quite a few years in arcade machine settings. Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 12, 2014 Author Share Posted May 12, 2014 Some thoughts now that I had a couple hours (on and off, mostly off) to mess with the UberGROM cart (PLCC). It's getting really hard to find hobby time lately. 1) The 49F040's are rock solid. They program and verify A-OK. The sockets on the boards are what's causing my grief with them. The sure fire way to fix it (and I've been having to do it frequently) are to take a little needle (one of those like that comes with a collared shirt, really tiny), and stick it in the hole behind the metal contact on the socket; each one of them; do it STRAIGHT DOWN, don't bend it at an angle. That bends them out enough to where they work again. If we go to prod with these boards, we might want to find a different manufacturer of the sockets. 2) I've successfully gotten Gazoo's util cart, Gazoo's games cart, Tursi's Bank Test, and Tursi's Multicart working with the 49F040 boards. 3) Some of my 74LS378's power up in the first bank, some in the last. Don't ask me why. They're all TI brand. They don't have a defined power up state, but now with 512K, we can probably afford putting a safety feature in the last bank just in case as well as the normal first bank. (In fact, let's just make that a standard.) 4) Gazoo's games cart, the latest version, (I haven't reviewed the utility one yet for functionality) only has a few things I noticed offhand on a real console with a Corcomp Mini PEB attached: Blasto just resets my system Blackjack and Poker does the same Hopper has something strange (not sure if it's the cart or the F18A) where I can move the kangaroo throughout the WHOLE screen; that's right, she goes through just about anything. Everything else appears to work (selecting game and trying to start it). I need to buy some more materials to finish making four that Ksarul sent me (mostly sockets and caps). I the meantime, I tried to make 2048 into a cart (thinking it was a 16K ROM image), and couldn't do so, but I'll look at it a little closer and make sure it's meant to be a 16K banked ROM. Blasto just resets my system Blackjack and Poker does the same Hopper has something strange (not sure if it's the cart or the F18A) where I can move the kangaroo throughout the WHOLE screen; that's right, she goes through just about anything. All 3 of these carts work perfectly normally for me. Are you using a console with a standard Grom0? When I used my console with the SOB that contained TKGROM0, I got strange results, switching to a standard console made everything work normally. Are you using a non-standard Grom0? Gazoo 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 12, 2014 Share Posted May 12, 2014 Gazoo, stock 99/4A system except for F18A, and Corcomp Mini Peripheral Expansion system. That is it :-) Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 12, 2014 Author Share Posted May 12, 2014 Gazoo, stock 99/4A system except for F18A, and Corcomp Mini Peripheral Expansion system. That is it :-) It's probably the Corcomp MES funky disk controller powerup causing the trouble. I assume you don't have the Millers Graphics eproms in it? If you feel up to doing an experiment, you could try removing the disk controller eproms from it and see if everything works ok then. Gazoo 1 Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted May 14, 2014 Share Posted May 14, 2014 Thanks to Ksarul I've now got a couple 512K carts an an UberGROM cart. Programmed the gamecart binary from Gazoo into one of the 512K carts and the UberGROM and so far so good. Except for my burner choking on the AT49F040 for some bizarre reason, going with the AM29F040 worked like a charm there. Burned a TC574000AD for the 512K cart. This is sooooo awesome, huge thanks to everyone involved! Now if we could get every TI game cart on to a few of these bad boys... Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 14, 2014 Author Share Posted May 14, 2014 (edited) <snip> Now if we could get every TI game cart on to a few of these bad boys... Well...that's what I'm working on. Gazoo Edited May 14, 2014 by Gazoo 1 Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted May 14, 2014 Share Posted May 14, 2014 As an aside - I emailed Batronix about the issue programming the AT49F040 last night at around 9PM. I received a reply at 8AM this morning saying they replicated the issue in their lab and corrected the issue in the software suite. god I love this company... Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 14, 2014 Share Posted May 14, 2014 As an aside - I emailed Batronix about the issue programming the AT49F040 last night at around 9PM. I received a reply at 8AM this morning saying they replicated the issue in their lab and corrected the issue in the software suite. god I love this company... What burner are you using? I need to purchase one soon for my fbForth 2.0 cartridge work and will be using 28-pin 27C256 EPROMs. (If this gets too far off topic, we can take it over to my fbForth thread.) ...lee Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted May 14, 2014 Share Posted May 14, 2014 What burner are you using? I need to purchase one soon for my fbForth 2.0 cartridge work and will be using 28-pin 27C256 EPROMs. (If this gets too far off topic, we can take it over to my fbForth thread.) ...lee Bagero BX40. Fantastic device and software suite, love it. Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 14, 2014 Share Posted May 14, 2014 I'm using an old 844USB from BK Electronics. It's a rebadged Elnec programmer, and they seem to update the software for it quite frequently for new devices :-) Definitely not a budget programmer, but after some of the cheap ones I bought on eBay, it definitely works well out of the box, which is what I wanted. I find my patience level for inexpensive stuff which you have to fiddle with has gone down as I approach 40. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted May 15, 2014 Share Posted May 15, 2014 Same here. There's lot's of cheapo ways I could have gone but spending the money for a higher end device that without endless screwing around is going to work first time, every time, was the way to go. Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 15, 2014 Author Share Posted May 15, 2014 (edited) Same here. There's lot's of cheapo ways I could have gone but spending the money for a higher end device that without endless screwing around is going to work first time, every time, was the way to go. To each his own. I just got the cheapest one I could find to do the job, the Genius 540. It works. I'll figure out the problem and make it work if it doesn't on the first try. Why spend money needlessly on unnecessary expensive shit? I've done that in the past and the investment just wasn't worth it. But that's just me, I don't have money to flush down the toilet. Oh, and I'm 55 and already been dead twice. Gazoo Edited May 15, 2014 by Gazoo Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 15, 2014 Share Posted May 15, 2014 I'm on the 55 bandwagon too, Gazoo--but I haven't had the been dead experience yet. . .I buy the tools that do what I want them to do, so if they happen to be inexpensive, excellent. If they end up costing more--and I know I'll use them a lot, I buy the expensive stuff (like my Pace kits for soldering). I got the chips this morning too--now I just have to build a pair of boards to put them into (I sold all of the batch I had built already). Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 15, 2014 Author Share Posted May 15, 2014 Menu screen for new game cart. This is fun. It goes back to the first screen after the second one... 'and round and round she goes...' Gazoo 3 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 15, 2014 Share Posted May 15, 2014 Nice! I like it! Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 17, 2014 Author Share Posted May 17, 2014 (edited) The second game cart is done. I managed to squeeze in a little more than the previous menu screens I posted. I'm pretty sure this one is bug free on the first try. Gazoo [deleted attachment=341967:Gamecart2.zip] Edited May 17, 2014 by Gazoo 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 17, 2014 Share Posted May 17, 2014 Excellent! We now have three different 512K images for people to use. Thank you Gazoo! Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 17, 2014 Author Share Posted May 17, 2014 I've been informed that the menu should read 'Spy's Demise' instead of 'Spies Demise'. Change made. Gazoo Gamecart2.zip Quote Link to comment Share on other sites More sharing options...
+acadiel Posted June 10, 2014 Share Posted June 10, 2014 Woot... look what I'm burning right now on a W27E040 :-) ... and the three titles (BlackJack and Poker, Hopper, and Blasto) now all work properly. Thanks, Gazoo. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted June 10, 2014 Share Posted June 10, 2014 Any chance of a 'roll your own' sort of kit for bundling carts into an image? I only ask because apparently there are many crap games on cart 1 Quote Link to comment Share on other sites More sharing options...
Gazoo Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) Any chance of a 'roll your own' sort of kit for bundling carts into an image? I only ask because apparently there are many crap games on cart Anyone is welcome to put whatever games they want into a cart. Gather together the games you want, join the images together with a hex editor, and write a simple assembly program with a menu, read a keypress, move the game out into the appropriate area from rom, and branch to the start of the game. The process is MUCH simpler than actually writing a game. I recommend making up a chart like this so you know where everything is when you start to write the code. Bank Number Eprom Addr Write to CPU Addr Start Addr Contents ----------- ---------- -------- -------- ---------- -------- 1 >0000 >6000 GAMES menu program 2 >2000 >6002 >A000 >A000 Paddleball 3 >4000 >6004 >A000 >A056 Centipede 4 >6000 >6006 >C000 >E02E Dig Dug 5 >8000 >6008 >E000 Dig Dug 6 >A000 >600A >A000 >A072 Defender 7 >C000 >600C >A000 >A086 Donkey Kong 8 >E000 >600E >C000 Donkey Kong 9 >10000 >6010 >C000 >C020 Jungle Hunt 10 >12000 >6012 >E000 Jungle Hunt 11 >14000 >6014 >C000 >C0FE Moon Patrol 12 >16000 >6016 >E000 Moon Patrol 13 >18000 >6018 >C000 >E0AE Ms Pacman 14 >1A000 >601A >E000 Ms Pacman 15 >1C000 >601C >A000 >A052 Pacman 16 >1E000 >601E >C000 Pacman 17 >20000 >6020 >A000 >A060 Pole Position 18 >22000 >6022 >C000 Pole Position 19 >24000 >6024 >C000 >DE3A Protector 20 >26000 >6026 >E000 Protector 21 >28000 >6028 >A000 >CBDA Shamus 22 >2A000 >602A >C000 Shamus 23 >2C000 >602C >A000 >A000 Parsec 24 >2E000 >602E >BFFA Parsec 25 >30000 >6030 >DFF4 Parsec 26 >32000 >6032 >268C Parsec (length >1180) 27 >34000 >6034 >A000 >B458 Ti Invaders 28 >36000 >6036 >BFFA Ti Invaders 29 >38000 >6038 >A000 >A50C 4A Flyer 30 >3A000 >603A >2FFC >315C A-Maze-Ing (length >0C00) 31 >3C000 >603C >A000 A-Maze-Ing (length >1800) 32 >3E000 >603E >A00E >A020 Ambulance 33 >40000 >6040 >2000 >2000 Demon Attack (length >1776) 34 >42000 >6042 >A000 Demon Attack 35 >44000 >6044 >BFFA Demon Attack 36 >46000 >6046 >DFF4 Demon Attack (length >1500) 37 >48000 >6048 >2FFC >315C Hangman (length >0C00) 38 >4A000 >604A >D000 Hangman (length >1800) 39 >4C000 >604C >A000 >A542 Hopper 40 >4E000 >604E >A000 >A000 Jawbreaker 41 >50000 >6050 >BFFA Jawbreaker 42 >52000 >6052 >A000 >AADE Midnight Mason 43 >54000 >6054 >BFFA Midnight Mason (length >0080) 44 >56000 >6056 >A000 >CA82 Moon Mine 45 >58000 >6058 >BFFA Moon Mine 46 >5A000 >605A >DFF4 Moon Mine 47 >5C000 >605C >A024 >A024 Rabbit Trail 48 >5E000 >605E >CFF8 >CFF8 River Rescue 49 >60000 >6060 >EFF2 River Rescue (length >1014) 50 >62000 >6062 >A000 >DA6E Tennis 51 >64000 >6064 >BFFA Tennis 52 >66000 >6066 >A000 >B9A0 TI Toad 53 >68000 >6068 >BFFA TI Toad 54 >6A000 >606A >A000 >A00C Tombstone City 55 >6C000 >606C >BFFC >C118 Buck Rogers 56 >6E000 >606E >DFF8 Buck Rogers 57 >70000 >6070 >2000 >20D6 Blackjack & Poker 58 >72000 >6072 >A000 Blackjack & Poker 59 >74000 >6074 >A000 >A000 Cave Creatures 60 >76000 >6076 >A000 >A000 Blasto 61 >78000 >6078 >BFFA Blasto (length >0200) 62 >7A000 >607A >A000 >BD4E Burgertime 63 >7C000 >607C >BFFA Burgertime 64 >7E000 >607E >A020 >A020 Worm Attack Gazoo Edited June 10, 2014 by Gazoo Quote Link to comment Share on other sites More sharing options...
Gazoo Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) Any chance of a 'roll your own' sort of kit for bundling carts into an image? I only ask because apparently there are many crap games on cart Hell, I'll even give you some example code for a menu. You DO have to put it in the right place when you compile it. Gazoo * GAME LOADER v1.0 * Gazoo * 5-6-14 DEF START Show where program starts. DATA >D820,>07D0,>6000 START B @START1 Go to actual start of program. VDPWD EQU >8C00 VDPST EQU >8802 SCAN EQU >000E GPLWS EQU >83E0 VDPWA EQU >8C02 VDP write address register. VDPRD EQU >8800 VDP read data register. BUFFER EQU >0FC0 SOUND1 BYTE >06,>BF,>DF,>FF,>80,>05,>92,>0A,>01,>9F,>00 H01 BYTE >01 H03 BYTE >03 H05 BYTE >05 EVEN ZERO DATA >0000 Define null character. START1 LIMI 2 LWPI >8300 Load workspace. LI R0,>0180 Set VDP register 1. BLWP @VWTR LI R0,>0200 Set VDP register 2. BLWP @VWTR LI R0,>030E Set VDP register 3. BLWP @VWTR LI R0,>0401 Set VDP register 4. BLWP @VWTR LI R0,>0506 Set VDP register 5. BLWP @VWTR LI R0,>0600 Set VDP register 6. BLWP @VWTR LI R0,>0717 Set VDP register 7. BLWP @VWTR LI R0,>0380 LI R1,SVENTN LI R2,>0010 BLWP @VMBW NOP LI R0,>0800 Load menu character set. LI R1,CHRDAU LI R2,>0400 BLWP @VMBW NOP LI R0,>0000 Put menu on screen. LI R1,MENU LI R2,>0300 BLWP @VMBW NOP LI R0,>01E0 Set VDP register 1. BLWP @VWTR BL @BEEP Sound a beep NOP MOVB @H03,@>8374 KLOOP1 BLWP @KSCAN Check for keypress. MOVB @>837C,R0 JEQ KLOOP1 CLR R1 MOVB @>8375,R1 CI R1,>0F00 Quit if escape is pressed. JEQ SEL00 CI R1,>4100 A JEQ SEL01 CI R1,>4200 B JEQ SEL02 CI R1,>4300 C JEQ SEL03 CI R1,>4400 D JEQ SEL04 CI R1,>4500 E JEQ SEL05 CI R1,>4600 F JEQ SEL06 CI R1,>4700 G JEQ SEL07 CI R1,>4800 H JEQ SEL08 CI R1,>4900 I JEQ SEL09 CI R1,>4A00 J JEQ SEL10 CI R1,>4B00 K JEQ SEL11 CI R1,>4C00 L JEQ SEL12 CI R1,>4D00 M JEQ SEL13 CI R1,>4E00 N JEQ SEL14 CI R1,>4F00 O JEQ SEL15 CI R1,>5000 P JEQ SEL16 CI R1,>5100 Q JEQ SEL17 CI R1,>5200 R JEQ SEL18 CI R1,>5300 S JEQ SEL19 CI R1,>5400 T JEQ SEL20 CI R1,>5500 U JEQ SEL21 CI R1,>5600 V JEQ SEL22 CI R1,>5700 W JEQ SEL23 CI R1,>5800 X JEQ SEL24 CI R1,>5900 Y JEQ SEL25 CI R1,>5A00 Z JEQ SEL26 CI R1,>3100 1 JEQ SEL27 CI R1,>3200 2 JEQ SEL28 CI R1,>3300 3 JEQ SEL29 CI R1,>3400 4 JEQ SEL30 CI R1,>3500 5 JEQ SEL31 CI R1,>3600 6 JEQ SEL32 CI R1,>3700 7 JEQ SEL33 CI R1,>3800 8 JEQ SEL34 B @KLOOP1 SEL00 BL @BEEP B @QUIT SEL01 B @AA SEL02 B @BB SEL03 B @CC SEL04 B @DD SEL05 B @EE SEL06 B @FF SEL07 B @GG SEL08 B @HH SEL09 B @II SEL10 B @JJ SEL11 B @KK SEL12 B @LL SEL13 B @MM SEL14 B @NN SEL15 B @OO SEL16 B @PP SEL17 B @QQ SEL18 B @RR SEL19 B @SS SEL20 B @TT SEL21 B @UU SEL22 B @VV SEL23 B @WW SEL24 B @XX SEL25 B @YY SEL26 B @ZZ SEL27 B @A1 SEL28 B @A2 SEL29 B @A3 SEL30 B @A4 SEL31 B @A5 SEL32 B @A6 SEL33 B @A7 SEL34 B @A8 ****************************************************************************** QUIT LIMI 2 CLR @>837C LWPI >83E0 BLWP @>0000 Go bye-bye. ****************************************************************************** BEEP LI R1,SOUND1 LI R0,BUFFER LI R2,11 BLWP @VMBW LIMI 0 LI R10,BUFFER MOV R10,@>83CC SOCB @H01,@>83FD MOVB @H01,@>83CE LIMI 2 SNDLP MOVB @>83CE,@>83CE JNE SNDLP LIMI 0 RT ******************************************************************************* BEPCLR LI R1,SOUND1 Beep. LI R0,BUFFER LI R2,11 BLWP @VMBW LIMI 0 LI R10,BUFFER MOV R10,@>83CC SOCB @H01,@>83FD MOVB @H01,@>83CE LIMI 2 SNDLP1 MOVB @>83CE,@>83CE JNE SNDLP1 LIMI 0 LI R0,>0000 Clear screen. LI R1,SPACE LI R2,>300 BLWP @VMBW NOP LI R0,>0800 Load TI standard character set. LI R1,CHRDAT LI R2,>0400 BLWP @VMBW NOP MOVB @ZERO,@>8374 Set key unit to 0. RT ****************************************************************************** RUN LWPI >83E0 LI R11,>0024 CLR @>837C B @>8300 ****************************************************************************** * UTILITIES * ****************************************************************************** SET DATA >2000 SAVE DATA 0 REGS BSS 32 EVEN VMBW DATA REGSV,V1 REGSV DATA 0,0,0,>8C02 DATA >8C00,0,>8800,0 DATA >4000,>8000,0,0 DATA 0,0,0,0 V1 MOV R13,R7 MOV *R7+,R0 MOV *R7+,R1 MOV *R7+,R2 SWPB R0 MOVB R0,*R3 SWPB R0 SOC R8,R0 MOVB R0,*R3 NOP V2 MOVB *R1+,*R4 DEC R2 JNE V2 RTWP VSBW DATA REGSV,V3 V3 MOV R13,R7 MOV *R7+,R0 SWPB R0 MOVB R0,*R3 SWPB R0 SOC R8,R0 MOVB R0,*R3 NOP MOVB *R7,*R4 RTWP VWTR DATA REGSV,V4 V4 MOV *R13,R0 SOC R9,R0 SWPB R0 MOVB R0,*R3 SWPB R0 MOVB R0,*R3 RTWP KSCAN DATA KSCAN,KSCAN+4 MOV *R11,R12 LWPI >83E0 BL @>000E LWPI KSCAN MOV R12,*R11 RTWP **************************************************************** MENU DATA >2041,>202D,>2050,>6163,>6D61,>6E20 ' A - Pacman ' DATA >2020,>0D20,>4C20,>2D20,>5072,>6F74 ' . L - Prot' DATA >6563,>746F,>7220,>2020,>2042,>202D 'ector B -' DATA >2050,>6172,>7365,>6320,>2020,>0D20 ' Parsec . ' DATA >4D20,>2D20,>416D,>6275,>6C61,>6E63 'M - Ambulanc' DATA >6520,>2020,>2043,>202D,>2053,>6861 'e C - Sha' DATA >6D75,>7320,>2020,>0D20,>4E20,>2D20 'mus . N - ' DATA >4D6F,>6F6E,>204D,>696E,>6520,>2020 'Moon Mine ' DATA >2044,>202D,>2048,>6F70,>7065,>7220 ' D - Hopper ' DATA >2020,>0D20,>4F20,>2D20,>4365,>6E74 ' . O - Cent' DATA >6970,>6564,>6520,>2020,>2045,>202D 'ipede E -' DATA >2054,>656E,>6E69,>7320,>2020,>0D20 ' Tennis . ' DATA >5020,>2D20,>4D73,>2050,>6163,>6D61 'P - Ms Pacma' DATA >6E20,>2020,>2046,>202D,>2042,>6C61 'n F - Bla' DATA >7374,>6F20,>2020,>0D20,>5120,>2D20 'sto . Q - ' DATA >4275,>7267,>6572,>7469,>6D65,>2020 'Burgertime ' DATA >2047,>202D,>2048,>616E,>676D,>616E ' G - Hangman' DATA >2020,>0D20,>5220,>2D20,>5061,>6464 ' . R - Padd' DATA >6C65,>6261,>6C6C,>2020,>2048,>202D 'leball H -' DATA >2044,>6967,>2044,>7567,>2020,>0D20 ' Dig Dug . ' DATA >5320,>2D20,>4A61,>7762,>7265,>616B 'S - Jawbreak' DATA >6572,>2020,>2049,>202D,>2054,>4920 'er I - TI ' DATA >546F,>6164,>2020,>0D20,>5420,>2D20 'Toad . T - ' DATA >412D,>4D61,>7A65,>2D49,>6E67,>2020 'A-Maze-Ing ' DATA >204A,>202D,>2034,>4120,>466C,>7965 ' J - 4A Flye' DATA >7220,>0D20,>5520,>2D20,>5449,>2049 'r . U - TI I' DATA >6E76,>6164,>6572,>7320,>204B,>202D 'nvaders K -' DATA >2044,>6566,>656E,>6465,>7220,>0D20 ' Defender . ' DATA >5620,>2D20,>4275,>636B,>2052,>6F67 'V - Buck Rog' DATA >6572,>7320,>0B0B,>0B0B,>0B0B,>0B0B 'ers ........' DATA >0B0B,>0B0B,>0B0B,>0C0B,>0B0B,>0B0B '............' DATA >0B0B,>0B0B,>0B0B,>0B0B,>0B0B,>0B0B '............' DATA >2020,>2020,>2057,>202D,>2057,>6F72 ' W - Wor' DATA >6D20,>4174,>7461,>636B,>2020,>2020 'm Attack ' DATA >2020,>2020,>2020,>2020,>2020,>2020 ' ' DATA >2058,>202D,>2044,>6F6E,>6B65,>7920 ' X - Donkey ' DATA >4B6F,>6E67,>2020,>2020,>2020,>2020 'Kong ' DATA >2020,>2020,>2020,>2020,>2059,>202D ' Y -' DATA >204A,>756E,>676C,>6520,>4875,>6E74 ' Jungle Hunt' DATA >2020,>2020,>0102,>0320,>2020,>2020 ' ... ' DATA >2020,>2020,>205A,>202D,>204D,>6F6F ' Z - Moo' DATA >6E20,>5061,>7472,>6F6C,>2020,>2020 'n Patrol ' DATA >0405,>0620,>2020,>2020,>2020,>2020 '... ' DATA >2031,>202D,>2052,>6976,>6572,>2052 ' 1 - River R' DATA >6573,>6375,>6520,>2020,>0708,>0920 'escue ... ' DATA >2020,>2020,>2020,>2020,>2032,>202D ' 2 -' DATA >2052,>6162,>6269,>7420,>5472,>6169 ' Rabbit Trai' DATA >6C20,>2020,>2020,>2020,>2020,>2020 'l ' DATA >2020,>2020,>2033,>202D,>2044,>656D ' 3 - Dem' DATA >6F6E,>2041,>7474,>6163,>6B20,>2020 'on Attack ' DATA >2020,>2020,>2020,>2020,>2020,>2020 ' ' DATA >2034,>202D,>2050,>6F6C,>6520,>506F ' 4 - Pole Po' DATA >7369,>7469,>6F6E,>2020,>2020,>2020 'sition ' DATA >2020,>2020,>2020,>2020,>2035,>202D ' 5 -' DATA >2054,>6F6D,>6273,>746F,>6E65,>2043 ' Tombstone C' DATA >6974,>7920,>2020,>2020,>2020,>2020 'ity ' DATA >2020,>2020,>2036,>202D,>204D,>6964 ' 6 - Mid' DATA >6E69,>6768,>7420,>4D61,>736F,>6E20 'night Mason ' DATA >2020,>2020,>2020,>2020,>2020,>2020 ' ' DATA >2037,>202D,>2043,>6176,>6520,>4372 ' 7 - Cave Cr' DATA >6561,>7475,>7265,>7320,>2020,>2020 'eatures ' DATA >2020,>2020,>2020,>2020,>2038,>202D ' 8 -' DATA >2042,>6C61,>636B,>6A61,>636B,>2026 ' Blackjack &' DATA >2050,>6F6B,>6572,>2020,>2020,>2020 ' Poker ' **************************************************************** CHRDAT DATA >0000,>0000,>0000,>0000,>0000,>003F DATA >3F30,>3030,>3030,>30F0,>F000,>0000 DATA >0000,>00FF,>FF00,>0000,>3030,>303F DATA >3F00,>0000,>0000,>00F0,>F030,>3030 DATA >3030,>3030,>3030,>3030,>0000,>0000 DATA >0000,>0000,>3C42,>9991,>9942,>3C00 DATA >0020,>0018,>241C,>0408,>3C42,>99A1 DATA >A199,>423C,>0040,>0020,>2038,>2438 DATA >0070,>5070,>4854,>1C14,>0070,>4070 DATA >001C,>1010,>0020,>0018,>243C,>2018 DATA >0040,>0814,>101C,>1010,>0040,>4040 DATA >1824,>2418,>0020,>2020,>2808,>0808 DATA >0040,>4058,>2408,>103C,>0040,>4058 DATA >2408,>2418,>0000,>0000,>0000,>0000 DATA >0040,>405C,>1018,>0418,>0040,>4048 DATA >1038,>2418,>0040,>405C,>0408,>1010 DATA >0040,>4058,>2418,>2418,>0040,>4058 DATA >241C,>0408,>0040,>4040,>1824,>3C24 DATA >0040,>4050,>101C,>141C,>0040,>4040 DATA >1C10,>101C,>0040,>4444,>041C,>141C DATA >0070,>7070,>7070,>7070,>0040,>4C50 DATA >101C,>1010,>0000,>0000,>0000,>0000 DATA >0010,>1010,>1010,>0010,>0028,>2828 DATA >0000,>0000,>0028,>287C,>287C,>2828 DATA >0038,>5450,>3814,>5438,>0060,>6408 DATA >1020,>4C0C,>0020,>5050,>2054,>4834 DATA >0008,>0810,>0000,>0000,>0008,>1020 DATA >2020,>1008,>0020,>1008,>0808,>1020 DATA >0000,>2810,>7C10,>2800,>0000,>1010 DATA >7C10,>1000,>0000,>0000,>0030,>1020 DATA >0000,>0000,>7C00,>0000,>0000,>0000 DATA >0000,>3030,>0000,>0408,>1020,>4000 DATA >0038,>4444,>4444,>4438,>0010,>3010 DATA >1010,>1038,>0038,>4404,>0810,>207C DATA >0038,>4404,>1804,>4438,>0008,>1828 DATA >487C,>0808,>007C,>4078,>0404,>4438 DATA >0018,>2040,>7844,>4438,>007C,>0408 DATA >1020,>2020,>0038,>4444,>3844,>4438 DATA >0038,>4444,>3C04,>0830,>0000,>3030 DATA >0030,>3000,>0000,>3030,>0030,>1020 DATA >0008,>1020,>4020,>1008,>0000,>007C DATA >007C,>0000,>0020,>1008,>0408,>1020 DATA >0038,>4404,>0810,>0010,>0038,>445C DATA >545C,>4038,>0038,>4444,>7C44,>4444 DATA >0078,>2424,>3824,>2478,>0038,>4440 DATA >4040,>4438,>0078,>2424,>2424,>2478 DATA >007C,>4040,>7840,>407C,>007C,>4040 DATA >7840,>4040,>003C,>4040,>5C44,>4438 DATA >0044,>4444,>7C44,>4444,>0038,>1010 DATA >1010,>1038,>0004,>0404,>0404,>4438 DATA >0044,>4850,>6050,>4844,>0040,>4040 DATA >4040,>407C,>0044,>6C54,>5444,>4444 DATA >0044,>6464,>544C,>4C44,>007C,>4444 DATA >4444,>447C,>0078,>4444,>7840,>4040 DATA >0038,>4444,>4454,>4834,>0078,>4444 DATA >7850,>4844,>0038,>4440,>3804,>4438 DATA >007C,>1010,>1010,>1010,>0044,>4444 DATA >4444,>4438,>0044,>4444,>2828,>1010 DATA >0044,>4444,>5454,>5428,>0044,>4428 DATA >1028,>4444,>0044,>4428,>1010,>1010 DATA >007C,>0408,>1020,>407C,>0038,>2020 DATA >2020,>2038,>0000,>4020,>1008,>0400 DATA >0038,>0808,>0808,>0838,>0000,>1028 DATA >4400,>0000,>0000,>0000,>0000,>007C DATA >0000,>2010,>0800,>0000,>0000,>0038 DATA >447C,>4444,>0000,>0078,>2438,>2478 DATA >0000,>003C,>4040,>403C,>0000,>0078 DATA >2424,>2478,>0000,>007C,>4078,>407C DATA >0000,>007C,>4078,>4040,>0000,>003C DATA >405C,>4438,>0000,>0044,>447C,>4444 DATA >0000,>0038,>1010,>1038,>0000,>0008 DATA >0808,>4830,>0000,>0024,>2830,>2824 DATA >0000,>0040,>4040,>407C,>0000,>0044 DATA >6C54,>4444,>0000,>0044,>6454,>4C44 DATA >0000,>007C,>4444,>447C,>0000,>0078 DATA >4478,>4040,>0000,>0038,>4454,>4834 DATA >0000,>0078,>4478,>4844,>0000,>003C DATA >4038,>0478,>0000,>007C,>1010,>1010 DATA >0000,>0044,>4444,>4438,>0000,>0044 DATA >4428,>2810,>0000,>0044,>4454,>5428 DATA >0000,>0044,>2810,>2844,>0000,>0044 DATA >2810,>1010,>0000,>007C,>0810,>207C DATA >0018,>2020,>4020,>2018,>0010,>1010 DATA >0010,>1010,>0030,>0808,>0408,>0830 DATA >0000,>2054,>0800,>0000,>0046,>4F52 DATA >0103,>0303,>0000,>0000,>0000,>0000 *************************************************** CHRDAU DATA >0000,>0000,>0000,>0000,>0103,>0303 DATA >0303,>0303,>FC04,>0505,>0406,>020C DATA >0080,>4040,>8000,>0C12,>FF80,>C040 DATA >6038,>1C0E,>1921,>213D,>0505,>05C4 DATA >BA8A,>8ABA,>A1A1,>A122,>0301,>0000 DATA >0000,>0000,>E231,>1018,>0C07,>0300 DATA >4C90,>2040,>4020,>E000,>3C42,>99A1 DATA >A199,>423C,>0000,>00FF,>0000,>0000 DATA >1010,>10FF,>0000,>0000,>1010,>1010 DATA >1010,>1010,>0020,>0018,>243C,>2018 DATA >0040,>0814,>101C,>1010,>0040,>4040 DATA >1824,>2418,>0020,>2020,>2808,>0808 DATA >0040,>4058,>2408,>103C,>0040,>4058 DATA >2408,>2418,>0040,>4054,>141C,>0404 DATA >0040,>405C,>1018,>0418,>0040,>4048 DATA >1038,>2418,>0040,>405C,>0408,>1010 DATA >0040,>4058,>2418,>2418,>0040,>4058 DATA >241C,>0408,>0040,>4040,>1824,>3C24 DATA >0040,>4050,>101C,>141C,>0040,>4040 DATA >1C10,>101C,>0040,>4444,>041C,>141C DATA >0070,>7070,>7070,>7070,>0040,>4C50 DATA >101C,>1010,>0000,>0000,>0000,>0000 DATA >0010,>1010,>1000,>1000,>0028,>2828 DATA >0000,>0000,>0028,>7C28,>287C,>2800 DATA >0038,>5430,>1854,>3800,>0044,>4C18 DATA >3064,>4400,>0020,>5020,>5448,>3400 DATA >0008,>1020,>0000,>0000,>0008,>1010 DATA >1010,>0800,>0020,>1010,>1010,>2000 DATA >0044,>287C,>2844,>0000,>0010,>107C DATA >1010,>0000,>0000,>0000,>0030,>1020 DATA >0000,>007C,>0000,>0000,>0000,>0000 DATA >0030,>3000,>0004,>0810,>2040,>0000 DATA >003C,>4C54,>6444,>3800,>0010,>3010 DATA >1010,>3800,>0038,>4408,>1020,>7C00 DATA >0038,>4418,>0444,>3800,>0008,>1828 DATA >487C,>0800,>0078,>4078,>0444,>3800 DATA >0038,>4078,>4444,>3800,>007C,>0408 DATA >1020,>2000,>0038,>4438,>4444,>3800 DATA >0038,>4444,>3C04,>7800,>0000,>3030 DATA >0030,>3000,>0000,>3030,>0030,>1020 DATA >0000,>1020,>4020,>1000,>0000,>007C DATA >007C,>0000,>0000,>1008,>0408,>1000 DATA >0038,>4408,>1000,>1000,>0038,>4454 DATA >5840,>3C00,>0038,>4444,>7C44,>4400 DATA >0078,>2438,>2424,>7800,>0038,>4440 DATA >4044,>3800,>0078,>2424,>2424,>7800 DATA >007C,>4078,>4040,>7C00,>007C,>4078 DATA >4040,>4000,>0038,>4440,>4C44,>3800 DATA >0044,>447C,>4444,>4400,>0038,>1010 DATA >1010,>3800,>0004,>0404,>0444,>3800 DATA >0044,>4850,>7048,>4400,>0040,>4040 DATA >4040,>7C00,>0044,>6C54,>4444,>4400 DATA >0044,>6454,>544C,>4400,>0038,>4444 DATA >4444,>3800,>0078,>4444,>7840,>4000 DATA >0038,>4444,>544C,>3C00,>0078,>4444 DATA >7848,>4400,>0038,>4430,>0844,>3800 DATA >007C,>1010,>1010,>1000,>0044,>4444 DATA >4444,>3800,>0044,>4444,>4428,>1000 DATA >0044,>4444,>5454,>2800,>0044,>2810 DATA >1028,>4400,>0044,>4428,>1010,>1000 DATA >007C,>0810,>2040,>7C00,>0038,>2020 DATA >2020,>3800,>0000,>4020,>1008,>0400 DATA >0038,>0808,>0808,>3800,>0010,>3854 DATA >1010,>1000,>0000,>0000,>0000,>7C00 DATA >0020,>1008,>0000,>0000,>0000,>0038 DATA >4848,>3C00,>0020,>2038,>2424,>3800 DATA >0000,>001C,>2020,>1C00,>0004,>041C DATA >2424,>1C00,>0000,>001C,>2830,>1C00 DATA >000C,>1038,>1010,>1000,>0000,>001C DATA >241C,>0438,>0020,>2038,>2424,>2400 DATA >0010,>0030,>1010,>3800,>0008,>0008 DATA >0808,>4830,>0020,>2024,>3828,>2400 DATA >0030,>1010,>1010,>3800,>0000,>0078 DATA >5454,>5400,>0000,>0038,>2424,>2400 DATA >0000,>0018,>2424,>1800,>0000,>0038 DATA >2438,>2020,>0000,>001C,>241C,>0404 DATA >0000,>0028,>3420,>2000,>0000,>001C DATA >300C,>3800,>0010,>1038,>1010,>0C00 DATA >0000,>0024,>2424,>1C00,>0000,>0044 DATA >2828,>1000,>0000,>0044,>5454,>2800 DATA >0000,>0024,>1818,>2400,>0000,>0024 DATA >241C,>0438,>0000,>003C,>0810,>3C00 DATA >000C,>1010,>2010,>100C,>0010,>1010 DATA >0010,>1010,>0060,>1010,>0810,>1060 DATA >0000,>2054,>0800,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000,>0000,>0000 *********************************************************** SPACE DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 DATA >2020,>2020,>2020,>2020,>2020,>2020,>2020,>2020 *********************************************************** SVENTN DATA >1717,>1717,>1717,>1717,>1717,>1717,>1717,>1717 THIRTN DATA >1313,>1313,>1313,>1313,>1313,>1313,>1313,>1313 *********************************************************** AA BL @BEPCLR * Pacman LWPI >83E0 LI R1,AADATA LI R2,>8300 LI R3,>003A LOOPAA MOV *R1+,*R2+ DECT R3 JGT LOOPAA B @RUN AADATA DATA >D820,>07D0,>601C,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>601E,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A052 ******************************************************** BB BL @BEPCLR * Parsec LWPI >83E0 LI R1,BBDATA LI R2,>8300 LI R3,>006A LOOPBB MOV *R1+,*R2+ DECT R3 JGT LOOPBB B @RUN BBDATA DATA >D820,>07D0,>602C,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>602E,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6030,>0201,>6000,>0202 DATA >DFF4,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6032,>0201,>6000,>0202 DATA >268C,>0203,>1180,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A000 ******************************************************* CC BL @BEPCLR * Shamus LWPI >83E0 LI R1,CCDATA LI R2,>8300 LI R3,>003A LOOPCC MOV *R1+,*R2+ DECT R3 JGT LOOPCC B @RUN CCDATA DATA >D820,>07D0,>6028,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>602A,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>CBDA ******************************************************* DD BL @BEPCLR * Hopper LWPI >83E0 LI R1,DDDATA LI R2,>8300 LI R3,>0022 LOOPDD MOV *R1+,*R2+ DECT R3 JGT LOOPDD B @RUN DDDATA DATA >D820,>07D0,>604C,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A542 ******************************************************* EE BL @BEPCLR * Tennis LI R0,>0713 Set VDP register 7. BLWP @VWTR LI R0,>0380 SET COLOR >13 LI R1,THIRTN LI R2,>0010 BLWP @VMBW NOP LWPI >83E0 LI R1,EEDATA LI R2,>8300 LI R3,>003A LOOPEE MOV *R1+,*R2+ DECT R3 JGT LOOPEE B @RUN EEDATA DATA >D820,>07D0,>6062,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6064,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>DA6E ******************************************************** FF BL @BEPCLR * Blasto LWPI >83E0 LI R1,FFDATA LI R2,>8300 LI R3,>003A LOOPFF MOV *R1+,*R2+ DECT R3 JGT LOOPFF B @RUN FFDATA DATA >D820,>07D0,>6076,>0201,>6000,>0202 DATA >2000,>0203,>1C00,>CCB1,>0643,>15FD DATA >D820,>07D0,>6078,>0201,>6000,>0202 DATA >A000,>0203,>1800,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>20D6 ******************************************************** GG LWPI >83E0 * Hangman LI R1,GGDATA LI R2,>8300 LI R3,>003A LOOPGG MOV *R1+,*R2+ DECT R3 JGT LOOPGG CLR @>A000 B @RUN GGDATA DATA >D820,>07D0,>603A,>0201,>6000,>0202 DATA >2FFC,>0203,>0C00,>CCB1,>0643,>15FD DATA >D820,>07D0,>604A,>0201,>6000,>0202 DATA >D000,>0203,>1800,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>315C ******************************************************** HH BL @BEPCLR * Dig Dug LWPI >83E0 LI R1,HHDATA LI R2,>8300 LI R3,>003A LOOPHH MOV *R1+,*R2+ DECT R3 JGT LOOPHH B @RUN HHDATA DATA >D820,>07D0,>6006,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6008,>0201,>6000,>0202 DATA >E000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>E02E ******************************************************** II BL @BEPCLR * TI Toad LWPI >83E0 LI R1,IIDATA LI R2,>8300 LI R3,>003A LOOPII MOV *R1+,*R2+ DECT R3 JGT LOOPII B @RUN IIDATA DATA >D820,>07D0,>6066,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6068,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>B9A0 ******************************************************** JJ BL @BEPCLR * 4A Flyer LWPI >83E0 LI R1,JJDATA LI R2,>8300 LI R3,>0022 LOOPJJ MOV *R1+,*R2+ DECT R3 JGT LOOPJJ B @RUN JJDATA DATA >D820,>07D0,>6038,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A50C ******************************************************** KK BL @BEPCLR * Defender LWPI >83E0 LI R1,KKDATA LI R2,>8300 LI R3,>0022 LOOPKK MOV *R1+,*R2+ DECT R3 JGT LOOPKK B @RUN KKDATA DATA >D820,>07D0,>600A,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A072 ******************************************************** LL BL @BEPCLR * Protector LWPI >83E0 LI R1,LLDATA LI R2,>8300 LI R3,>003A LOOPLL MOV *R1+,*R2+ DECT R3 JGT LOOPLL B @RUN LLDATA DATA >D820,>07D0,>6024,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6026,>0201,>6000,>0202 DATA >E000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>DE3A ******************************************************** MM BL @BEPCLR * Ambulance LWPI >83E0 LI R1,MMDATA LI R2,>8300 LI R3,>0022 LOOPMM MOV *R1+,*R2+ DECT R3 JGT LOOPMM B @RUN MMDATA DATA >D820,>07D0,>603E,>0201,>6000,>0202 DATA >A00E,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A020 ******************************************************** NN BL @BEPCLR * Moon Mine LWPI >83E0 LI R1,NNDATA LI R2,>8300 LI R3,>0052 LOOPNN MOV *R1+,*R2+ DECT R3 JGT LOOPNN B @RUN NNDATA DATA >D820,>07D0,>6056,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6058,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>605A,>0201,>6000,>0202 DATA >DFF4,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>CA82 ******************************************************** OO BL @BEPCLR * Centipede LWPI >83E0 LI R1,OODATA LI R2,>8300 LI R3,>0022 LOOPOO MOV *R1+,*R2+ DECT R3 JGT LOOPOO B @RUN OODATA DATA >D820,>07D0,>6004,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A056 ******************************************************** PP BL @BEPCLR * Ms Pacman LWPI >83E0 LI R1,PPDATA LI R2,>8300 LI R3,>003A LOOPPP MOV *R1+,*R2+ DECT R3 JGT LOOPPP B @RUN PPDATA DATA >D820,>07D0,>6018,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>601A,>0201,>6000,>0202 DATA >E000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>E0AE ******************************************************** QQ BL @BEPCLR * Burgertime LWPI >83E0 LI R1,QQDATA LI R2,>8300 LI R3,>003A LOOPQQ MOV *R1+,*R2+ DECT R3 JGT LOOPQQ B @RUN QQDATA DATA >D820,>07D0,>607A,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>607C,>0201,>6020,>0202 DATA >BFFA,>0203,>1FE0,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>BD4E ******************************************************** RR BL @BEPCLR * Paddleball LWPI >83E0 LI R1,RRDATA LI R2,>8300 LI R3,>0022 LOOPRR MOV *R1+,*R2+ DECT R3 JGT LOOPRR B @RUN RRDATA DATA >D820,>07D0,>6002,>0201,>6020,>0202 DATA >A000,>0203,>1FE0,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A000 ******************************************************** SS BL @BEPCLR * Jawbreaker LWPI >83E0 LI R1,SSDATA LI R2,>8300 LI R3,>003A LOOPSS MOV *R1+,*R2+ DECT R3 JGT LOOPSS B @RUN SSDATA DATA >D820,>07D0,>604E,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6050,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A000 ******************************************************** TT BL @BEPCLR * A-Maze-Ing LWPI >83E0 LI R1,TTDATA LI R2,>8300 LI R3,>003A LOOPTT MOV *R1+,*R2+ DECT R3 JGT LOOPTT CLR @>D000 B @RUN TTDATA DATA >D820,>07D0,>603A,>0201,>6000,>0202 DATA >2FFC,>0203,>0C00,>CCB1,>0643,>15FD DATA >D820,>07D0,>603C,>0201,>6000,>0202 DATA >A000,>0203,>1800,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>315C ******************************************************** UU BL @BEPCLR * TI Invaders LWPI >83E0 LI R1,UUDATA LI R2,>8300 LI R3,>003A LOOPUU MOV *R1+,*R2+ DECT R3 JGT LOOPUU B @RUN UUDATA DATA >D820,>07D0,>6034,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6036,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>B458 ******************************************************** VV BL @BEPCLR * Buck Rogers LWPI >83E0 LI R1,VVDATA LI R2,>8300 LI R3,>003A LOOPVV MOV *R1+,*R2+ DECT R3 JGT LOOPVV B @RUN VVDATA DATA >D820,>07D0,>606C,>0201,>6000,>0202 DATA >BFFC,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>606E,>0201,>6000,>0202 DATA >DFF8,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>C118 ******************************************************** WW BL @BEPCLR * Worm Attack LWPI >83E0 LI R1,WWDATA LI R2,>8300 LI R3,>003A LOOPWW MOV *R1+,*R2+ DECT R3 JGT LOOPWW B @RUN WWDATA DATA >D820,>07D0,>607E,>0201,>6020,>0202 DATA >A020,>0203,>1FE0,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000 DATA >0201,>4432,>C801,>C000 DATA >0201,>4230,>C801,>C002 DATA >0201,>32B0,>C801,>C004 DATA >0460,>A020 ******************************************************** XX BL @BEPCLR * Donkey Kong LWPI >83E0 LI R1,XXDATA LI R2,>8300 LI R3,>003A LOOPXX MOV *R1+,*R2+ DECT R3 JGT LOOPXX B @RUN XXDATA DATA >D820,>07D0,>600C,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>600E,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A086 ******************************************************** YY BL @BEPCLR * Jungle Hunt LI R0,>0713 Set VDP register 7. BLWP @VWTR LWPI >83E0 LI R1,YYDATA LI R2,>8300 LI R3,>003A LOOPYY MOV *R1+,*R2+ DECT R3 JGT LOOPYY B @RUN YYDATA DATA >D820,>07D0,>6010,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6012,>0201,>6000,>0202 DATA >E000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>C020 ******************************************************** ZZ BL @BEPCLR * Moon Patrol LWPI >83E0 LI R1,ZZDATA LI R2,>8300 LI R3,>003A LOOPZZ MOV *R1+,*R2+ DECT R3 JGT LOOPZZ B @RUN ZZDATA DATA >D820,>07D0,>6014,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6016,>0201,>6000,>0202 DATA >E000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>C0FE ******************************************************** A1 BL @BEPCLR * River Rescue LWPI >83E0 LI R1,A1DATA LI R2,>8300 LI R3,>003A LOOPA1 MOV *R1+,*R2+ DECT R3 JGT LOOPA1 B @RUN A1DATA DATA >D820,>07D0,>605E,>0201,>6000,>0202 DATA >CFF8,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6060,>0201,>6000,>0202 DATA >EFF2,>0203,>1014,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>CFF8 ******************************************************** A2 BL @BEPCLR * Rabbit Trail LWPI >83E0 LI R1,A2DATA LI R2,>8300 LI R3,>0010 LOOPA2 MOV *R1+,*R2+ DECT R3 JGT LOOPA2 B @RUN A2DATA DATA >D820,>07D0,>605C,>0460,>6024 ******************************************************** A3 BL @BEPCLR * Demon Attack LWPI >83E0 LI R1,A3DATA LI R2,>8300 LI R3,>006A LOOPA3 MOV *R1+,*R2+ DECT R3 JGT LOOPA3 B @RUN A3DATA DATA >D820,>07D0,>6040,>0201,>6000,>0202 DATA >2000,>0203,>1776,>CCB1,>0643,>15FD DATA >D820,>07D0,>6042,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6044,>0201,>6000,>0202 DATA >BFFA,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6046,>0201,>6000,>0202 DATA >DFF4,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>2000 ******************************************************* A4 BL @BEPCLR * Pole Position LWPI >83E0 LI R1,A4DATA LI R2,>8300 LI R3,>003A LOOPA4 MOV *R1+,*R2+ DECT R3 JGT LOOPA4 B @RUN A4DATA DATA >D820,>07D0,>6020,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6022,>0201,>6000,>0202 DATA >C000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A060 ******************************************************** A5 BL @BEPCLR * Tombstone City LWPI >83E0 LI R1,A5DATA LI R2,>8300 LI R3,>0022 LOOPA5 MOV *R1+,*R2+ DECT R3 JGT LOOPA5 B @RUN A5DATA DATA >D820,>07D0,>606A,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A00C ******************************************************** A6 BL @BEPCLR * Midnight Mason LWPI >83E0 LI R1,A6DATA LI R2,>8300 LI R3,>003A LOOPA6 MOV *R1+,*R2+ DECT R3 JGT LOOPA6 B @RUN A6DATA DATA >D820,>07D0,>6052,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6054,>0201,>6000,>0202 DATA >BFFA,>0203,>0080,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>AADE ******************************************************** A7 BL @BEPCLR * Cave Creatures LWPI >83E0 LI R1,A7DATA LI R2,>8300 LI R3,>0022 LOOPA7 MOV *R1+,*R2+ DECT R3 JGT LOOPA7 B @RUN A7DATA DATA >D820,>07D0,>6074,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>A000 ******************************************************** A8 BL @BEPCLR * Blackjack & Poker LWPI >83E0 LI R1,A8DATA LI R2,>8300 LI R3,>003A LOOPA8 MOV *R1+,*R2+ DECT R3 JGT LOOPA8 B @RUN A8DATA DATA >D820,>07D0,>6070,>0201,>6000,>0202 DATA >2000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6072,>0201,>6000,>0202 DATA >A000,>0203,>2000,>CCB1,>0643,>15FD DATA >D820,>07D0,>6000,>0460,>20D6 ******************************************************** TEXT ' Gazoo ' END Edited June 10, 2014 by Gazoo 2 Quote Link to comment Share on other sites More sharing options...
