+SoulBuster Posted February 1, 2023 Author Share Posted February 1, 2023 1 hour ago, luckybuck said: @SoulBuster: Again, thank you sooo much! 馃檪 聽 Your contribution to the Atari cummunity is highly appreciated. 馃檪 聽 Just a suggestion: we have already much published: https://atariwiki.org/wiki/Wiki.jsp?page=Articles#section-Articles-VoiceAndDataCassettes 聽 In case to prevent double work... 聽 Further, for type in: http://ataribasiclistings.mygamesonline.org/ with a Type-In task force... 聽 聽 Ricochet [orig] -bas.atr 90.02 kB聽路聽0 downloads Ricochet -bas.atr 90.02 kB聽路聽0 downloads Ricochet (1981)(Epyx)(US)[BASIC].atr 90.02 kB聽路聽1 download Ricochet (v1,b).atr 90.02 kB聽路聽0 downloads Ricochet (v2,b).atr 90.02 kB聽路聽0 downloads Even doing double duty has produced alternate versions. Take Delta Drawing. The preservation site has version 3.23 as being preserved.聽 The one I posted, version 3.20, is not even listed on the site. It is also in a smaller cart that I have not seen before. 聽 I just dump everything I get. 1 Quote Link to comment Share on other sites More sharing options...
pmgraphics Posted February 1, 2023 Share Posted February 1, 2023 2 hours ago, luckybuck said: @pmgraphics: From that link: http://data.atariwiki.org/FLAC/FRENCH/Conversational_FRENCH-CX4119-Unit_1-Cassette_A-Side_1.flac I can download... Maybe you try again? See the issue now. My network blocks non https links and these flac links are http. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted February 1, 2023 Share Posted February 1, 2023 @SoulBuster: very welcome. Just wanted to sve you work. 馃檪 Please go ahead. :-))) 聽 @pmgraphics: please try from a different source, browser, etc. The data is there. Thank you. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1, 2023 Author Share Posted February 1, 2023 Compu-Read 3.0 - The WAV loads in Altirra, but I could not make a CAS from it.聽 The CAS that is included is a CSAVE CAS, not from the original WAV.聽 I tried recording a WAV 30+ times and this the only way I could get a CAS. I will replace it with a new when I can get a WAV that will convert.聽 But until then, enjoy the software. 聽 Compu-Read 3.0 (1981)(Edu-Ware Services)(US)[cassette].zip Compu-Read 3.0 Manual.PDF Compu-Read 3.0 Note.PDF Compu-Read 3.0 Service Request.PDF 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 1, 2023 Author Share Posted February 1, 2023 Issue #33 BLINE had an update to assembly list from #29. 聽I check the listing on the #29 I posted and it already has the fix, so no changes to BLINE. An update to the Clock program from issue #31. 聽This mod allows for loading the SET program to load automatically. VANDENBG.LST is entered into VANDENBG.BAS from issue #29 for better XL compatibility. BBEXTERM.BAS fixes some problems with BASIC REV A and also puts basic on disk. 聽The BASIC Cartridge is no longer needs in 400/800s. The assembly listing compiles. An ATR is included. SYNTRON.BAS creates a file or a cassette version of the game. The CAS and an ATR from that CAS are included.SYNTRON.M65 compiles into a working game CCOM.BAS creates an AUTORUN.SYS for your DOS disk. 聽The assembly listing compiles using Atari Macro Assembler into a working program. There are 5 SOUNDx.ASM assembly listings that assemble using Assembler Editor. 9 were found on the source disk, but 4 of them belong to the next issue. 聽I will be moving them there. OBJs for the first 5 are included. 聽 Analog Computing #33 (1985-08)(Analog Magazine Corp.)(US)[BASIC].zip 聽 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 2, 2023 Author Share Posted February 2, 2023 If you already got Analog Issue #33, you should get it again.聽 I found that the sound assembly listings 6-9 are on Issue #34 and should not be included here.聽 This also gave me enough room to include the OBJs for 1-5 on the disk. 聽 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 2, 2023 Author Share Posted February 2, 2023 Issue #34 PPCAL.LST from Reader Comments is an update for Personal Planning Calendar From Issue #31. TRANSLTR.LST from Reader Comments is an update for the Home Translator program from issue #32. SOUND6.ASM requires Atari Macro Assembler. Even after verifying the source file matches the listing, I still get 1 error, "Undetermined MACRO definition." SOUND7.ASM, SOUND8.ASM and SOUND9.ASM all compile using Assembler Editor. Dragons Breath has two different versions of the game. 聽Version one is DRAGONBR.BAS and if you enter TRIVISA.LST into DRAGONBR.BAS, you get a different version of the game. ELEVATOR.BAS creates a file or a cassette version of Elevator Repairman. 聽The CAS and an ATR from that CAS are included. 聽The assembly listing compiles with MAC/65 into a working game. 聽 Analog Computing #34 (1985-09)(Analog Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted February 2, 2023 Share Posted February 2, 2023 (edited) 聽聽 On 1/29/2023 at 8:05 AM, SoulBuster said: In addition, I have changed hardware that I am using Disk Drive: TEAC FD-55GFR. All new (or updated) DISK dumps are on this drive. Any聽DISK dumps before this post were聽on a Panasonic JU-475.聽 The Panasonic failed on the disk Slime. Just out of curiosity, since the JU-475 died, how are you managing the flippy disks? 聽 聽聽 On 1/29/2023 at 8:05 AM, SoulBuster said: Cassette: Generic Cassette to MP3 Player and record with Audacity 聽 This could be the explanation for your .wav file issues. Edited February 2, 2023 by Vyvyan B. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 2, 2023 Author Share Posted February 2, 2023 49 minutes ago, Vyvyan B. said: Just out of curiosity, since the JU-475 died, how are you managing the flippy disks? I slice the disk open and turn the inside media over. 49 minutes ago, Vyvyan B. said: 聽聽This could be the explanation for your .wav file issues. The only time I have a problem with WAVs is when the original media is in really poor condition.聽 This little player has done tons of good WAVs, even ones with second channel audio, like Speed Reading and Moonbase IO. 聽 The cassette player is not the problem, it's poor media as a source. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 2, 2023 Author Share Posted February 2, 2023 This is the first disk that the preservation site has listed as copied from original media. 聽The disk itself will remain intact and is included to make the thread complete. 聽I will check all programs on the disk for correctness and any changes will be on a separate disk that I create. I will still make CAS and ATR files where appropriate. 聽 Issue #35聽(Disk 1 Sourced from A8SP) BONK.BAS creates a file or a cassette version of the game. The CAS and an ATR from that CAS are included. 聽The Mac/65 listing compiles into a working game. An additional disk was not necessary. ANALOG Computing #35 (1985-10)(ANALOG Magazine Corp.)(US)[disk].zip 聽 3 Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted February 2, 2023 Share Posted February 2, 2023 21 minutes ago, SoulBuster said: I slice the disk open and turn the inside media over. I was trying to find a way to do the few originals that I have without cutting them up. I picked up a JU-475 a while back with the hope of modding it, but after watching the rather destructive Kryoflux mod video on youtube, I decided against it. I thought I saw something about adding a second IR & photo-diode (not sure if it was the Panasonic or not) to pick up an index signal from a flipped disk, but I cannot seem to find the thread anymore. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 2, 2023 Share Posted February 2, 2023 (edited) 32 minutes ago, Vyvyan B. said: I was trying to find a way to do the few originals that I have without cutting them up. I picked up a JU-475 a while back with the hope of modding it, but after watching the rather destructive Kryoflux mod video on youtube, I decided against it. I thought I saw something about adding a second IR & photo-diode (not sure if it was the Panasonic or not) to pick up an index signal from a flipped disk, but I cannot seem to find the thread anymore. that mod was done for kryo as well as XF551's I'll try to dig the links up again, it's probably now all in another language and on a site that will require a translate button to be hit. 聽 found something similar that will work for atari disks, since index isn't really used by most Atari mechs, It can be approximate and is close enough to fake it. Easily adapted to most direct drive mechs. http://www.b-pahl.de/atari8bit/xf551/xf551.html http://blog.3b2.sk/igi/post/ATARI-floppy-disk-drive-XF551-3_3.aspx the second one is closer to the original mods... and translates slightly easier at the moment when put through online website translators. Edited February 2, 2023 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted February 2, 2023 Share Posted February 2, 2023 Some of the pics in the second link look familiar. Also, they are in English. This one in particular: 聽 聽 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 3, 2023 Author Share Posted February 3, 2023 Issue #36聽(Disk 1 & 2 Sourced from A8SP) 聽 MUSORQA1.LST from Readers Comments is entered into the program of the same name from issue #34 to fix circles being all over the screen MUSORQA2.LST from Readers Comments is entered into the program of the same name from issue #34 to use the Left Button for Sustain MUSORQA3.LST from Readers Comments is entered into the program of the same name from issue #34 to use the Right Button for Sustain MUSORQA4.LST from Readers Comments is entered into the program of the same name from issue #34 to use the Koalapad INTRNTNL.BAS from Readers Comments is a short program to enable the printing of International Characters on the printer MAZEWAR.BAS did not match the Checksum Data for it in the magazine. One that does match is on the Supplemental disk. 聽The only change was a Graphics 0 was added on line 20 after they took the Checksum data. MAZEWAR.BAS creates a file or a cassette version of the game. A CAS and an ATR from that CAS are included. The MAC/65 listing (MAZEWAR.M65, CHRDATA.M65, MAIN.M65, VBI.M65, SUBS.M65 and DBASE.M65) compiles into a complete and working game. 聽 ANALOG Computing #36 (1985-11)(ANALOG Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 3, 2023 Author Share Posted February 3, 2023 Issue #37聽(Disk 1 Sourced from A8SP) 聽 MICROCHK.LST from Readers Comments is entered into the Micro Check program from issues 27 and 28 for better XL/XE compatibility. TRANSLTR.LST from Readers Comments is entered into the Home Translator program form issue #32 to restore original background, keyclick and bell. SPEEDSKI.BAS creates a file or a cassette version of the game. The CAS and an ATR from that CAS are included. The Assembly listing compiles into a complete and working game. ALTSCRN.ENT is entered into SPEEDSKI.BAS and saved to disk as SPEEDALT.BAS for an Alternate Screen. 聽A CAS and an ATR of that CAS are included. CREATOR.BAS creates an AUTORUN.SYS file to load MASTER.DR1 for Master Disk Directory. 聽An ATR is included. 聽 ANALOG Computing #37 (1985-12)(ANALOG Magazine Corp.)(US)[BASIC].zip 聽 3 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 9, 2023 Author Share Posted February 9, 2023 Adventure Pak (198x)(Keypunch Software)(US)[disk] 聽 Adventure Pak (198x)(Keypunch Software)(US)[disk].zip 聽 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 9, 2023 Author Share Posted February 9, 2023 F-15 Strike Eagle (1984)(Microprose Software)(US)[disk] - With Commodore files. 聽 F-15 Strike Eagle (1984)(Microprose Software)(US)[disk][Includes C64].zip 聽 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 9, 2023 Author Share Posted February 9, 2023 Final Legacy (1987)(Atari)(US)[cartridge][new] 聽 All Materials are from a shrink-wrapped box. 聽 Final Legacy (1987)(Atari)(US)[cartridge][new].zip Final Legacy Manual.pdf Final Legacy Warranty.pdf 聽 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 10, 2023 Author Share Posted February 10, 2023 Atari Educational System - Master Cartridge (1979)(Atari)(US)[cartridge] 聽 Atari Educational System - Master Cartridge (1979)(Atari)(US)[cartridge].zip Educational System Master Cartridge Warranty.pdf 聽 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 10, 2023 Author Share Posted February 10, 2023 Basic Electricity (1979)(Atari)(US)[cassette] 聽 These are as recorded with no edits other than clipping the noise off of each end. 聽 Seems to be errors of manufacture Lesson 3 transition glitch 2:07 Lesson 3 the end prematurely stops 13:31 Lesson 7 transition glitch 4:37 Lesson 11 transition glitch 6:30 Lesson 11 end prematurely stops Lesson 12 transition glitch 18:06 Lesson 16 voice says RI circuit and screen prints RL 13:03 聽 Actual errors Lesson 10 glitch 24:55 Lesson 11 glitch 4:33 Lesson 12 glitch 17:53 Lesson 12 glitch 18:49 Lesson 13 glitch 1:09 聽 Basic Electricity Cassette A.zip Basic Electricity Cassette B.zip Basic Electricity Cassette C.zip Basic Electricity Cassette D.zip Basic Electricity All Other Assetts.zip Basic Electricity Warranty.pdf 3 1 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted February 10, 2023 Share Posted February 10, 2023 WOW! That is really great! 馃檪 聽 The 'normal' ones, we do have: https://atariwiki.org/wiki/Wiki.jsp?page=Atari Educational System Lesson Cassettes From the Dorsett ones: https://atariwiki.org/wiki/Wiki.jsp?page=Dorsett Educational System Lesson Cassettes 聽 we call for help on the missing ones: Some tapes had severe damage and therefore couldn't be digitized. If anyone is in the possession of the following tapes, please give us a message or a post here. We really need your help and appreciate just any hint on the programs, who seem to be lost in time, like tears in rain. The left ones to digitize are as follows:- General Shop Practices: Oa1 Tool Identification Lesson, Part 1 Oa7 Discussion of a Two-Cycle Engine Oa8 Use of Micrometers and Calipers- Health Services Career: Hc5 Medical History Hc6 Extended Care- Physics: Ph16 Theory of Relativity Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 10, 2023 Author Share Posted February 10, 2023 WOW!!.聽 That last upload!!!聽 Almost 2 gigs!!!!聽 Sorry Albert. 聽 I think I have to find another place for the zips (at least). (you agree, don't you Albert!?) 聽 OK.聽 I have 16 TB free locally.聽 I t h i n k . . .聽 聽I c a n get something going! LOLlololahem... 聽 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 10, 2023 Author Share Posted February 10, 2023 2 hours ago, SoulBuster said: *Since CAS cannot carry the vocal/audio portion of the recordings, no CAS files are included. Will CAS ever carry the Vocal/Audio portion of Atari Cassettes? 聽 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted February 10, 2023 Share Posted February 10, 2023 This question must be forwarded to Avery & Mark... 聽 We would be extremly glad, if we have a FujiNet-Adapter-Emulation in the Atari emulators... 聽 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted February 10, 2023 Author Share Posted February 10, 2023 11 minutes ago, luckybuck said: This question must be forwarded to Avery & Mark... 聽 We would be extremly glad, if we have a FujiNet-Adapter-Emulation in the Atari emulators... 聽 4.10 does not have it. Or am I mistaken? 聽 Quote Link to comment Share on other sites More sharing options...
