Atari8man2004 Posted March 26 Share Posted March 26 14 minutes ago, _The Doctor__ said: almost makes you wish you could assign a dither/no dither mask, the world could be blended and the Owl dithered. That would pop! A dither mask would be great ! nice. Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 26 Share Posted March 26 18 hours ago, Atari8man2004 said: Astronaut Colors: 31 Plus src No Dither Atari8man_Astronaut.xex 22.1 kB · 9 downloads Would sell Ataries! 1 Quote Link to comment Share on other sites More sharing options...
ilmenit Posted March 26 Share Posted March 26 Thanks to @Sheddy I have a working build environment for Rasta Converter on a new Visual Studio. This allowed me to merge and test the pull requests that were added by the others. The binary build Beta8 done by Sheddy here is the one to use now, the fixes are very good. Having some free time I'll make an official release to download from Github directly. Now I'm trying to understand the highly optimized code introduced by @phaeron with the multi-threading and caching that he added. While the code is of good quality, it's lacking the general comments about concepts used. Also I did not program in C++ for more than 10 years now and never used it for multi-threading so the task is not easy. I have some ideas to check and implement, but first I need to do more code cleanup to make it easier to work with the code in the future. 3 5 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 26 Share Posted March 26 Content Creation Here's my setup for right now. I will set up more space for even doing more cool stuff 3 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 26 Share Posted March 26 1 hour ago, ilmenit said: Thanks to @Sheddy I have a working build environment for Rasta Converter on a new Visual Studio. This allowed me to merge and test the pull requests that were added by the others. The binary build Beta8 done by Sheddy here is the one to use now, the fixes are very good. Having some free time I'll make an official release to download from Github directly. Now I'm trying to understand the highly optimized code introduced by @phaeron with the multi-threading and caching that he added. While the code is of good quality, it's lacking the general comments about concepts used. Also I did not program in C++ for more than 10 years now and never used it for multi-threading so the task is not easy. I have some ideas to check and implement, but first I need to do more code cleanup to make it easier to work with the code in the future. While going through some old folders (and trying to fix an annoying issue with Rasta GUI), I came across a beta 7 ZIP, which had extended feature support (and were labelled as "fast builds"). Do you know if these changes have been merged in? The files in questions were titled "RastaConverterBeta7.icl17.SSE2.exe", and "RastaConverterBeta7.icl17.AVX512.exe". I do not have the source, only the exes. Quote Link to comment Share on other sites More sharing options...
Sheddy Posted March 26 Share Posted March 26 33 minutes ago, Stephen said: While going through some old folders (and trying to fix an annoying issue with Rasta GUI), I came across a beta 7 ZIP, which had extended feature support (and were labelled as "fast builds"). Do you know if these changes have been merged in? The files in questions were titled "RastaConverterBeta7.icl17.SSE2.exe", and "RastaConverterBeta7.icl17.AVX512.exe". I do not have the source, only the exes. they look familiar. I remember sharing those quite a few years ago now. I had got a trial version of the Intel Compiler to try learning something. That didn't work out, but I played with various processor options and Profile Guided Optimization for RastaConverter. There weren't any changes over beta7, but the compiler just did an outstanding optimization for speed on the code. The Intel compiler isn't the same anymore (but is free) and I can't get Profile Guided Optimization to work with RastaConverter and Visual Studio anymore. But it has been compiled with the best settings I could find for speed. 1 Quote Link to comment Share on other sites More sharing options...
drpeter Posted March 27 Share Posted March 27 (edited) 6 hours ago, _The Doctor__ said: almost makes you wish you could assign a dither/no dither mask, the world could be blended and the Owl dithered. That would pop! The way to do this is in pre-processing: produce two (or more) output.png-dst.png images with different types of (or no) dithering then combine the output.png-dst.png images into a single input image with the right kind of dithering in the places you want them and finally run Rasta with that as input and no dithering or other tweaks. I did this in my recent Stonehenge image: the sky below the clouds has knoll dithering strength 3 and the clouds and foreground low strength jarvis dithering. Edited March 27 by drpeter 5 Quote Link to comment Share on other sites More sharing options...
drpeter Posted March 27 Share Posted March 27 6 hours ago, Atari8man2004 said: Night Owl Colors: 56 Plus src Atari8man_Night_Owl.xex 22.12 kB · 11 downloads Another stunner! A question- although it seems to be for a PAL palette, the proportions of this image and many of your other recent ones seem slightly vertically flattened- see for example the very obviously elliptical moon in this one- and the proportions look more 'normal' on an NTSC display where the almost square but very slightly vertically flattened PAL pixels are instead noticeably vertically stretched. Is this because of the kit you are displaying images on? Or is it a deliberate compositional thing to vertically squeeze images into 240 vertical pixels? 1 Quote Link to comment Share on other sites More sharing options...
drpeter Posted March 27 Share Posted March 27 (edited) (for some reason double-posted!) Edited March 27 by drpeter Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 27 Share Posted March 27 3 hours ago, drpeter said: Another stunner! A question- although it seems to be for a PAL palette, the proportions of this image and many of your other recent ones seem slightly vertically flattened- see for example the very obviously elliptical moon in this one- and the proportions look more 'normal' on an NTSC display where the almost square but very slightly vertically flattened PAL pixels are instead noticeably vertically stretched. Is this because of the kit you are displaying images on? Or is it a deliberate compositional thing to vertically squeeze images into 240 vertical pixels? I have been using Irfan_View 64 for windows for color count and to resize the image when I enter 320 for the width it never sets the hieght to 240 it's always off by a few. Sometimes I try to get a better ratio by making a clip of the image in a 4:3 ration this seems to work better like in this Image of "Pink Roses" . Any ideas are greatly appreciated. Atari8man_Pink_Roses.xex 7 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 27 Share Posted March 27 4 hours ago, drpeter said: The way to do this is in pre-processing: produce two (or more) output.png-dst.png images with different types of (or no) dithering then combine the output.png-dst.png images into a single input image with the right kind of dithering in the places you want them and finally run Rasta with that as input and no dithering or other tweaks. I did this in my recent Stonehenge image: the sky below the clouds has knoll dithering strength 3 and the clouds and foreground low strength jarvis dithering. Oh this sound great I will do some studies with method. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted March 27 Share Posted March 27 (edited) 3 hours ago, Atari8man2004 said: I have been using Irfan_View 64 for windows for color count and to resize the image when I enter 320 for the width it never sets the hieght to 240 it's always off by a few. Sometimes I try to get a better ratio by making a clip of the image in a 4:3 ration this seems to work better like in this Image of "Pink Roses" . Any ideas are greatly appreciated. Atari8man_Pink_Roses.xex 22.11 kB · 3 downloads I use irfanview all the time, never noticed. It always resizes to 320x 240 or 320x200 respectively. Great conversion by the way. Edit make sure you have preserve aspect ratio Unchecked when resizing. That could be your problem. Edited March 27 by Beeblebrox 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 27 Share Posted March 27 8 hours ago, Beeblebrox said: I use irfanview all the time, never noticed. It always resizes to 320x 240 or 320x200 respectively. Great conversion by the way. Edit make sure you have preserve aspect ratio Unchecked when resizing. That could be your problem. irfanview is like a "swiss army knife" with so many options it's my go to app. Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 28 Share Posted March 28 (edited) Celebrity 11 Collaboration @drpeter and me 168 x 240 resolution many colors (more than C64 has!) palette: real.act /pal=real.act /details=mask.png /details_val=4 /dither=jarvis /dither_val=0.9 /dither_rand=0.21 /s=34500 /threads=4 /seed=0 /save=10000000 drpeter_and_GravityWorm_Celebrity__0011.xex Edited March 28 by GravityWorm 7 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted March 28 Share Posted March 28 2 minutes ago, GravityWorm said: Celebrity 11 Collaboration @drpeter and me 168 x 240 resolution many colors (more than in C64!) palette: real.act drpeter_and_GravityWorm_Celebrity__0011.xex 19.36 kB · 0 downloads nice. Think this could work well with more dithering and a mask. Great skin tones. 1 Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 28 Share Posted March 28 44 minutes ago, Beeblebrox said: nice. Think this could work well with more dithering and a mask. Great skin tones. I used mask on face and hand. Ditherning 0.9 Jarvis /pal=real.act /details=mask.png /details_val=4 /dither=jarvis /dither_val=0.9 /dither_rand=0.21 /s=34500 /threads=4 /seed=0 /save=10000000 /continue 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 28 Share Posted March 28 50 minutes ago, GravityWorm said: Celebrity 11 Collaboration @drpeter and me 168 x 240 resolution many colors (more than in C64!) palette: real.act drpeter_and_GravityWorm_Celebrity__0011.xex 19.36 kB · 1 download Very nice!! I like your description -many colors (more than in C64!) 1 2 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 28 Share Posted March 28 Pink Roses colors: 58 Atari8man_Pink_Roses.xex 11 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 28 Share Posted March 28 Haunted House colors: 39 Atari8man_Haunted_house.xex 5 Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 28 Share Posted March 28 Just now, Atari8man2004 said: Pink Roses colors: 58 Atari8man_Pink_Roses.xex 22.09 kB · 0 downloads Awesome vase, perfect. Flowers very good. I wonder if dithering could improve flowers🤔 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 28 Share Posted March 28 Alien Invader 2 Colors: 114 Bingo! I broke the 100 color mark! Atari8man_Alien_invader_2.xex 6 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted March 28 Share Posted March 28 4 minutes ago, GravityWorm said: Awesome vase, perfect. Flowers very good. I wonder if dithering could improve flowers🤔 Dither can make or break an Image some of my images have no dither. 2 Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 28 Share Posted March 28 1 minute ago, Atari8man2004 said: Dither can make or break an Image some of my images have no dither. I mean dither only on the flowers. Partial dither. Look at some of my images or @drpeter's Stonehenge 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted March 28 Share Posted March 28 (edited) 1 hour ago, GravityWorm said: I used mask on face and hand. Ditherning 0.9 Jarvis /pal=real.act /details=mask.png /details_val=4 /dither=jarvis /dither_val=0.9 /dither_rand=0.21 /s=34500 /threads=4 /seed=0 /save=10000000 /continue Sure. I'd ramp up the dithering on all of the subject and perhaps do my double dithering technique as described in the RC thread last year. Works a treat with portrait and skin tones eg my own conversion portrait last year https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/?do=findComment&comment=5339446 Edited March 28 by Beeblebrox 2 Quote Link to comment Share on other sites More sharing options...
GravityWorm Posted March 28 Share Posted March 28 20 minutes ago, Beeblebrox said: Sure. I'd ramp up the dithering on all of the subject and perhaps do my double dithering technique as described in the RC thread last year. Works a treat with portrait and skin tones eg my own conversion portrait last year https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/?do=findComment&comment=5339446 I remember. You use this technique a lot. Oh. I did not get it. Now I understand you did that on purpose. I thought you just used very low quality source images, overexposed and noisy. But my observations are not valid I still need to see Rasta Converter pictures on a real CRT... I'm planing to visit a local 8 bit computers museum... There are at least two in my area... 1 Quote Link to comment Share on other sites More sharing options...
