My experiments with Atari 7800
Eagle
50 minutes ago, Muddyfunster said:
JS7800 is based on Prosystem which has a lot of inaccuracies in the emulation. JS7800 is neat and I love it, but it's not great for stuff that requires super accurate emulation.
Yeah true. If you need super accurate emulation,  Just get out a real 7800 and ditch emulation!
Even that has its shortcomings.  Different revisions of the hardware, people using different multicarts, different internal modifications, and variations in condition (amongst other things) can all add up to inconsistent test results on actual hardware.
That said, I remain inclined to consider software testing conducted on hardware as providing a more consistent baseline point (and therefore result) than testing in emulation.  That's not to say that testing in emulation is invalid: it's absolutely not.  But given that the hardware is the common ancestor of the emulators, to my mind it's the target upon which software should always work properly.
Question- Is there anything different between the different revisions functonality wise?
My 7800 has the expansion port on the side. Do I have the first revision?
PAL versions have a BIOS without cartridge protection checks and include Asteroids as a game that starts automatically at power-up when no cartridge is inserted.
For NTSC machines, the major differences seem to be the presence (or not) of a RAM timing circuit, the RAM supplier, and the CPU supplier.  For more info, take a look at this thread and the comments in another thread starting here.
It's probably better to think of it as an early version as opposed to the 'first' version.  While the expansion port had been dropped by about 1987/1988, it was included on different versions of the system prior to then.  They've also shown up on a small number of machines with serial numbers in date ranges where they wouldn't expect to be found, so there are no 100% perfect rules for determining what may have been installed or not.
2 hours ago, Ecernosoft said:
What is this?
This bin file for our new cart with special banking.
I attached because few devs have them.
You can add header with bit 7 (mirror ram) and run on Dragon Fly or A7800 emulator.
But you will have some missing graphics and you cant hear the music from SN76489.
  • 2 weeks later...
13 hours ago, mksmith said:
Wow!
I will attach full source code later.
But it's much simpler than horizontal or vertical scroll
Main macro below for one line:
	.macro render
	ldx #$40-1
@	lda :1,x
;	clc
	adc count
	and #$0f
	ora :3,x
	tay
	lda texture,y
	sta :2,x
	dex
	bpl @-
	.endm
and that's all :D
Repeated 52 times with different addresses for each line
Most important code ;)
		lda #$06
		sta $FFFF
BIT 1 - enable mirroring RAM A8
BIT 2 - enable mirroring RAM A9 (only SN cart)
In Atari800 world we call this Konop mode or GTIA ++
https://atariwiki.org/wiki/Wiki.jsp?page=Ironman Atari#section-Ironman+Atari-GTIA9
BTW you can add header for SN bin file with bit 7 set and will run on DF and A7800 emulator (you need sign as well because I always forget)
  • Like 8
	.macro render
	ldx #$40-1
@	lda :1,x
;	clc
	adc count
	and #$0f
	ora :3,x
	tay
	lda texture,y
	sta :2,x
	dex
	bpl @-
	.endm
and that's all :D
		lda #$06
		sta $FFFF
Ok dude, you NEED to make a demoscene thing. Like, REALLY. If you did and posted it on YT it would be AMAZING!
Or make a game! Make a great game with your asm knowledge and blow me and ICT out of the water! 🤣
	.macro render
	ldx #$40-1
@	lda :1,x
;	clc
	adc count
	and #$0f
	ora :3,x
	tay
	lda texture,y
	sta :2,x
	dex
	bpl @-
	.endm
and that's all :D
		lda #$06
		sta $FFFF
So impressive what you are achieving with these 👏
  • Like 4
On 9/11/2022 at 2:06 PM, Eagle said:
We had scroll horizontal and vertical so now we have scroll forward :D
edit: SN cart bin attached
You've really laid the gauntlet for showing the 7800 was more capable than the GTIA/ANTIC combo from the 8-bit line.  I'd love to see a FRIENDLY competition for what can be achieved, best of the best in a demo situation, not general game.  Wonder if you could drop this in the 5200 programming forum and spark a friendly competition, with no bickering, no mud slinging, just working code allowed.
Numen 7800? ;)
A8 people are aware about it. I’m always posting on AtariArea discord before AAge forum.
Some A8 coders are involved in SN cart project as well.
Also I don’t want go in to Gr7/prior0 discussion  :D
You need to draw Table for circles and rays (using colours from 0 to 15)
Get first pixel/byte from Table_Rays - this will be lower nibble
Get first pixel/byte from Table_Circles - as higher nibble
Now you have x,y position for Texture (0..255)
Get pixel/byte from Texture and put on screen
Repeat :D
More about demo effects you can find on Tebe website
https://madteam.atari8.info/index.php?prod=fx#tunnel
But you will need google translator ;)
edit:
I attached tool from Tebe website. Will help you to understand and make your own tunnels/wormholes
	.macro render
	ldx #$40-1
@	lda Table_Circles,x		;Table Circles colours are $00,$01,$02,$03....$0F
;	clc
	adc count			;incrase every cycle for tunnel animation (you can do this for circles as well and tunnel wil start rotate)
	and #$0f
	ora Table_Rays,x		;Table Rays colours are $00,$10,$20....$F0 - so you don't have to shift bits)
	tay				;we have in Y register x,y for Texture
	lda texture,y
	sta Screen,x			;put on screen
	dex
	bpl @-
	.endm
tunnel.7z
Edited by Eagle
Thanks! These amazing looking demo effects are great!
I am still trying to navigate through how to map arbitrary sized sprite graphics to scanlines. In the Lynx you had the anchor point that made the code trivial. On the 7800 I need to manually maintain some anchor x/y offset for every frame of animation. Perhaps the easiest way is just to try out different options and see what works for me.
