marcing Posted April 20, 2022 Share Posted April 20, 2022 Side note, I also tested this monitor with: Amstrad CPC, Atari with VBXE, C128 (80 column after conversion from RGBI to VGA). It works ok. Some vertical lines observed on VBXE. interesting fact is that VBXE has combined H/V synchronization (CSYNC - XOR of HSync and VSync). and that also is ok for that monitor. 2 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted April 23, 2022 Share Posted April 23, 2022 (edited) So far I am very impressed with this monitor. I did notice few glitches on some demo screen hacks, so I decided to look into it a little bit more by hacking the monitor DDC-CI VPC (I2C) protocol on VGA pin 12-DATA & pin 15 CLOCK. I'm hoping I can read the frequencies when am I experiencing the issue with simple Arduino compatible microcontroller on the DDC/CI (Display Data Channel Command Interface).? Here is the Arduino library for controlling external computer monitors over the VESA DDC/CI standard created by Toni Tanner, 2021: DDC/CI VCP library. And my super simple example CODE: // https://github.com/tttttx2/ddcvcp // https://www.ddcutil.com/vcpinfo_output/ #include "DDCVCP.h" //VCP code C0: Display usage time // Active power on time in hours, MCCS versions: 2.0, 2.1, 3.0, 2.2 // MCCS specification groups: Miscellaneous, ddcutil feature subsets: // Attributes: Read Only, Continuous (complex) #define VCP_code_Display_usage_time 0xC0 DDCVCP ddc; bool power_onoff = false; void setup() { pinMode(LED_BUILTIN, OUTPUT); digitalToggle(LED_BUILTIN); Serial.begin(9600); Wire.setSCL(16); Wire.setSDA(17); while (!ddc.begin()) { Serial.print(F("- Unable to find DDC/CI. Trying again in 5 seconds.\n")); delay(5000); } Serial.print(F("- Found DDC/CI successfully.\n")); } void loop() { ddc.setBrightness(10); digitalToggle(LED_BUILTIN); Serial.println(F("setBrightness(10)")); delay(500); ddc.setBrightness(50); digitalToggle(LED_BUILTIN); Serial.println(F("setBrightness(50)")); delay(500); ddc.setBrightness(100); digitalToggle(LED_BUILTIN); Serial.println(F("setBrightness(100)")); delay(500); power_onoff = ddc.getPower(); // bool DDCVCP::getPower() if (power_onoff == false) { ddc.setPower(power_onoff); // setPower(bool value) } digitalToggle(LED_BUILTIN); delay(500); Serial.print (F("getClock - sampling clock frequency ")); Serial.println(ddc.getClock()); delay(500); Serial.print(F("Display usage time in hours ")); Serial.println(ddc.getVCP(VCP_code_Display_usage_time)); delay(500); } I am connected to the monitor directly without the Atari ST computer this is because the cable I have for the Atari is actually shorting out one of the pins to ground (PIN12 ID1- SDA_DDC Serial Data Line), Back in the day (80s) ID0,ID1,ID2,ID3 pin 11,12,4,15 respectively in VGA standard connector where used for Monitor ID Bit. Edited April 23, 2022 by Chri O. add 2nd pic 2 Quote Link to comment Share on other sites More sharing options...
+MIK710_0 Posted June 2, 2022 Share Posted June 2, 2022 (edited) On 1/8/2022 at 8:32 AM, tuf said: Results are as expected - works as well as the ST modes! Here's some snaps of a PAL screen on an NTSC A500 using a simple DB23 to VGA adapter. Hi! that discover it's amazing! No one have tried some DBLPal / Double PAL resolution? Something like that?: Edited June 2, 2022 by MIK710_0 2 Quote Link to comment Share on other sites More sharing options...
leech Posted June 2, 2022 Share Posted June 2, 2022 Man, I need to clean up my computer desk and set stuff up in an organized fashion, as everyone else seems to have sane set ups. Granted I haven't put the top on my A4000 in years, and same with my Falcon.. Quote Link to comment Share on other sites More sharing options...
Tillek Posted June 2, 2022 Share Posted June 2, 2022 2 hours ago, leech said: Man, I need to clean up my computer desk and set stuff up in an organized fashion, as everyone else seems to have sane set ups. Granted I haven't put the top on my A4000 in years, and same with my Falcon.. No... they just piled all the junk up out of the camera view, took the picture, then put it back. 1 2 Quote Link to comment Share on other sites More sharing options...
leech Posted June 2, 2022 Share Posted June 2, 2022 1 hour ago, Tillek said: No... they just piled all the junk up out of the camera view, took the picture, then put it back. That is usually what I do. Or edit the picture so it doesn't show all the junk. 2 Quote Link to comment Share on other sites More sharing options...
Tillek Posted June 2, 2022 Share Posted June 2, 2022 46 minutes ago, leech said: That is usually what I do. Or edit the picture so it doesn't show all the junk. Ok, so this is totally worthy of that meme with the guy in the orange jacket. Alas, I'm "working" and don't have enough time... but pretend I did. 1 Quote Link to comment Share on other sites More sharing options...
Tillek Posted June 2, 2022 Share Posted June 2, 2022 Nevermind... Yes I did.... 2 Quote Link to comment Share on other sites More sharing options...
leech Posted June 2, 2022 Share Posted June 2, 2022 3 hours ago, Tillek said: Nevermind... Yes I did.... I had a project to build out some Pentium 1-3 era system and ended up with a few motherboards that need to be recapped, video cards, random case, etc. Basically my floor looked similar to that scene in Pink Floyd the Wall where he goes crazy and smashes up his guitar and makes an odd 'map' on the floor with various pieces of furniture and food. "hello? Are you feeling okay?" 2 Quote Link to comment Share on other sites More sharing options...
DoAndroidsDreamOfOldComputers Posted June 25, 2022 Share Posted June 25, 2022 To add some potentially relevant information to this thread, I've had good luck with Dell monitors of recent manufacture. I haven't tested anything on the SE2722H, but I have tested a few computers (Atari included) on other Dells, including those manufactured in 2022. Here's a summary (taken in part from a post to another forum): I bought a CGA2RGBv2 adapter (https://gglabs.us/node/2063), and tested it on an IBM 5155 with a CGA card -- the adapter will convert the CGA signal to a VGA compatible pinout and voltages, but the signal will still be 15Khz. I tested on three Dell monitors--two 16:9 aspect ratio P2419Hs and a 5:4 aspect ratio P1917S. The interesting thing is that when using the VGA connector, the P1917 (made in 2016) and one of the P2419Hs (made in Sept 2020) will sync using the CGA2RGBv2; the resolution reported by the monitor is 1440x240. The other P2419H, built in Dec 2018, won't. I checked with an IBM 5150, too. The service menus of the two P2419Hs look very different, and the firmware appears to be different. I would be interested to hear if anyone has had any luck connecting 15Khz machines--PCs or other types of machines--to other monitors with VGA that have come out in the last 5 years. Note that http://15khz.wikidot.com/ lists partial support for 15KHz signals for the P1917S. The P2419H is not listed, but the P2214H is. Additionally, I've tested a P2414H (an earlier model) and a couple P2219H monitors, and these seemed to work fine, too. I did some preliminary testing with a BBC Micro, and that also appears to work. This is all through the CGA2RGBv2. More recently, I tested an Atari 520ST on the P1917S, a P2219H, a P2722H (still listed on Dell's site), and a Lenovo Q24i-1L. All of these will sync on the Atari, but the Lenovo always shows a wide-screen aspect ratio. With the Dell's, switching to 4:3 works fine. In my view, the Dell on-screen GUI is better than the Lenovo GUI. I tested Low, Mid, and High resolution, and the results look like the pictures others have posted (including the cross-hatch pattern on high-res mode). As an aside, for the Atari, I'm using separate low/mid and high-res cables from CoolNovelties. Unfortunately, not all Dell monitors will work. The 15khz.wikidot site indicates this, and my own tests of the following models came up with negative results: a P2417 and two P1914's wouldn't sync. As noted above, even some monitors of the same model or series won't work. I have a few P2422H's at work that I can also test if folks are interested. These are all business class monitors (so, no freesync). I'm not very knowledgeable when it comes to Atari STs, so pointers about what software to use would be helpful. I'm in the US, and I assume my machine was intended for that market. 1 Quote Link to comment Share on other sites More sharing options...
rustynutt Posted July 28, 2022 Share Posted July 28, 2022 Back from the dead Finally jumped on 2 of the SE2722's. $319 delivery next day. The early 2000 Dell 24" I'd been using on the PC went on the blink, and the really old (forgot what brand, it's burried during a computer room remodel) monitor that worked in RGB mode on the Falcon wasn't best video quality. Being 66, 800x600 on a 24" was really getting difficult. These should shine with the SuperVidel as well as the occasional RGB demo's on the Falcon. Thank you all for the testing Quote Link to comment Share on other sites More sharing options...
rustynutt Posted July 28, 2022 Share Posted July 28, 2022 Oh, from Office Depot out of San Jose. Quote Link to comment Share on other sites More sharing options...
+H454 Posted July 28, 2022 Share Posted July 28, 2022 Down to $169.99 at Microcenter - https://www.microcenter.com/product/638580/ Office Depot / MAX $159.99 until the end of July https://www.officedepot.com/a/products/9072317/Dell-SE2722H-27-FHD-LED-Monitor/ Quote Link to comment Share on other sites More sharing options...
rustynutt Posted July 28, 2022 Share Posted July 28, 2022 3 minutes ago, H454 said: Down to $169.99 at Microcenter - https://www.microcenter.com/product/638580/ Office Depot / MAX $159.99 until the end of July https://www.officedepot.com/a/products/9072317/Dell-SE2722H-27-FHD-LED-Monitor/ I'd tried Microcenter on my phone, it spit and sparked for some reason. Googled the monitor and came up with the Office Depot site. Quote Link to comment Share on other sites More sharing options...
+H454 Posted July 28, 2022 Share Posted July 28, 2022 45 minutes ago, rustynutt said: I'd tried Microcenter on my phone, it spit and sparked for some reason. Googled the monitor and came up with the Office Depot site. Microcenter and search engines don't seem to get along. If I want to check MC, I have search their website whenever I check prices. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 12, 2022 Share Posted August 12, 2022 So I picked up one of the 27" Dell's posted here while it was on sale for $159.00. I've got one of those Ube switch's that I had purchased some time ago. Using a standard VGA cable I hooked everything up. It all boots up. I had to adjust the vertical and horizontal position a bit but it's good (this is in 16:9 mode - haven't tried 4:3 yet). But...it's in hi-res. I went through all the monitor settings and I can't find anything to change there and Options-> Set Preferences on the Mega STe only shows hi-res available, low and medium are greyed out. Is there something on the Ube switch I need to change? Thanks all. Quote Link to comment Share on other sites More sharing options...
tuf Posted August 12, 2022 Share Posted August 12, 2022 (edited) 8 minutes ago, DarkLord said: Is there something on the Ube switch I need to change? This might be a dumb question - I'm not familiar with the Ube...does it have a switch on it? You wont ever have access to all 3 modes at the same time (Low/Med/High). The monitor port senses which monitor you've got connected, and the switches just let you choose one or the other. Edited August 12, 2022 by tuf Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 12, 2022 Share Posted August 12, 2022 Never mind - I found it. I just had to play around with it. There is a switch (very tiny!) on the top of the Ube switch that lets you set it to low, medium, or hi-rez. I guess it was just set to hi-rez when I turned it on the first time. This Dell monitor and Uve switch combo is pretty nice. Clicking the button reboots the Mega STe and sets the resolution - nice. 1 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 12, 2022 Share Posted August 12, 2022 5 minutes ago, tuf said: Dumb question - I'm not familiar with the Ube...does it have a switch on it? I got it, thanks though. It does indeed have a switch on top. Oh, and for anyone who's not familiar with the Ube switch, it's a button you press, not slide... Quote Link to comment Share on other sites More sharing options...
leech Posted August 12, 2022 Share Posted August 12, 2022 40 minutes ago, tuf said: This might be a dumb question - I'm not familiar with the Ube...does it have a switch on it? You wont ever have access to all 3 modes at the same time (Low/Med/High). The monitor port senses which monitor you've got connected, and the switches just let you choose one or the other. It is that tiny button on top, for future reference. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 12, 2022 Share Posted August 12, 2022 Hey, that's a pretty nifty cover you got there for the Ube switch. is that 3D printed? Can I have one? <nudge-nudge> <wink-wink> Be happy to reimburse you. Quote Link to comment Share on other sites More sharing options...
leech Posted August 12, 2022 Share Posted August 12, 2022 9 minutes ago, DarkLord said: Hey, that's a pretty nifty cover you got there for the Ube switch. is that 3D printed? Can I have one? <nudge-nudge> <wink-wink> Be happy to reimburse you. Ha, I didn't print it. Trying to remember who I ordered it from. Came with the ubeswitch though. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 13, 2022 Share Posted August 13, 2022 Hmm, mine didn't. I feel snubbed. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted August 13, 2022 Share Posted August 13, 2022 So I'm pretty happy with this Dell 27" monitor, with only 2 complaints. First, I wish it had been available in Atari grey. Second, I realized that the monitor on my Win10 box, sitting just a few feet away, is actually smaller. So...because I play Guild Wars 2, Divinity 2 Original Sin and Baldurs' Gate 3 on it, I guess I'll have to upgrade it as well. Work, work, work, work, work, work...work. 1 Quote Link to comment Share on other sites More sharing options...
leech Posted August 13, 2022 Share Posted August 13, 2022 25 minutes ago, DarkLord said: So I'm pretty happy with this Dell 27" monitor, with only 2 complaints. First, I wish it had been available in Atari grey. Second, I realized that the monitor on my Win10 box, sitting just a few feet away, is actually smaller. So...because I play Guild Wars 2, Divinity 2 Original Sin and Baldurs' Gate 3 on it, I guess I'll have to upgrade it as well. Work, work, work, work, work, work...work. Haha, I should at some point down the road figure out what monitors I must keep and those which need to go... I stocked up on a bunch with the eventual hope to have space for setting up a bunch of different machines. One of these days... Quote Link to comment Share on other sites More sharing options...
