+ZeroPage Homebrew Posted February 12 Author Share Posted February 12 18 hours ago, Thomas Jentzsch said: BTW: The color timing issue with your console was there from the 1st show (see top of IXION play field). So that's perfect consistency. Very interesting! I guess it's not too surprising since it's the same 2600 as we play on now with the same (but replaced) RGB mod. 🙂 - James Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 12 Share Posted February 12 6 hours ago, ZeroPage Homebrew said: Very interesting! I guess it's not too surprising since it's the same 2600 as we play on now with the same (but replaced) RGB mod. 🙂 I am only mentioning, because you had suspected that the mod might be the culprit. Probably you just have to replace the TIA to get rid of the problem. Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted February 12 Share Posted February 12 On 2/11/2023 at 3:32 AM, Thomas Jentzsch said: Six viewers! Very cool, I didn't realize the first game played was Super Cobra Arcade! I feel honored (and a bit embarrassed I wasn't one of the six people watching 😊 ). On 2/11/2023 at 3:32 AM, Thomas Jentzsch said: BTW: The color timing issue with your console was there from the 1st show (see top of IXION play field). So that's perfect consistency. You can see the timing issue on SC:A as well in the lower right display of the current level; the bottom of the '1' is chopped off. ✂️ 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 12 Share Posted February 12 29 minutes ago, johnnywc said: Very cool, I didn't realize the first game played was Super Cobra Arcade! I feel honored (and a bit embarrassed I wasn't one of the six people watching 😊 ). I can't remember, but depending on the time this was live, I might have been one of them. 2 Quote Link to comment Share on other sites More sharing options...
vitoco Posted February 13 Share Posted February 13 I couldn't join this afternoon, but it seems that there were connection problems... lots of portions of the stream available!!! I guess that the show will be uploaded in a single video to YouTube. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 13 Share Posted February 13 @ZeroPage Homebrew Thanks for presenting Top&Tom 2 (aka Bot&Tom) that well. Tanya's and your comments really made my day! 👍 And thanks to Twitch for a stable connection at least during this time. 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 13 Author Share Posted February 13 11 hours ago, Thomas Jentzsch said: @ZeroPage Homebrew Thanks for presenting Top&Tom 2 (aka Bot&Tom) that well. Tanya's and your comments really made my day! 👍 You're welcome, it's such a fun game we could have kept playing it for much longer. 11 hours ago, Thomas Jentzsch said: And thanks to Twitch for a stable connection at least during this time. What a nightmare that was, for all the messing about during the stream to try and get it working, it turned out the issue was outside of my network. It was possibly my ISP issue as there was about 5% packet loss one hop away from me and it cleared up by itself about 2 hours after the stream. If I did this full time I would definitely invest in redundant connections to the Internet to avoid this issue. 18 hours ago, vitoco said: I couldn't join this afternoon, but it seems that there were connection problems... lots of portions of the stream available!!! I guess that the show will be uploaded in a single video to YouTube. You bet, since I didn't have to reboot my computer or stop the recording the show will be uploaded in full without interruption to YouTube and you won't have any issues watching it there. 🙂 - James 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 13 Author Share Posted February 13 On 2/12/2023 at 1:45 AM, Thomas Jentzsch said: I am only mentioning, because you had suspected that the mod might be the culprit. Probably you just have to replace the TIA to get rid of the problem. That would be nice! I might let me soldering skills increase before attempting that, we don't want a repeat of what happened to that poor POKEY chip I "removed" from a Ballblazer cart. - James Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted February 14 Share Posted February 14 2 hours ago, ZeroPage Homebrew said: That would be nice! I might let me soldering skills increase before attempting that, we don't want a repeat of what happened to that poor POKEY chip I "removed" from a Ballblazer cart. No soldering required - your TIA is socketed. Just get a new one from Best, or a donor that's also socketed. You only need to: Open the case Unplug the two Molex connectors (there's a release tab on them) Remove the screws holding the RF shield to the case Unplug the connector from the switch board Remove the two screws connecting the switch board to the RF shield (optional - but it's easier to work with if you remove the switch board) Remove the bottom of the RF shield Slide out the main board Flip it over, GENTLY pry out the old TIA from the mod board using a chip lifter Carefully seat the new TIA, and squeeze it into place Reroute the cables so they clear the shield Reinstall the shield Reconnect the switch board Reconnect the Molex connectors Test!! Reassemble Actually... what you should do first, is find a TIA without that issue. Then do the above steps. 1 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 14 Author Share Posted February 14 5 minutes ago, Nathan Strum said: No soldering required - your TIA is socketed. Just get a new one from Best, or a donor that's also socketed. Since it's socketed then I can definitely handle doing this, thank you so much Nathan! Now I begin the hunt for an inexpensive TIA or a dirt cheap 'parts' console with a working TIA. Best has them for $39.95 USD + shipping which is a decent price but I'd probably find some other things in their catalogue to order at the same time if I go through them. - James 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 17 Author Share Posted February 17 CLICK HERE TO VOTE NOW! 2 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 21 Author Share Posted February 21 2 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted February 21 Share Posted February 21 So the countdown has begun. I like it! Looking forward to Saturday. 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 21 Share Posted February 21 Looking forward to it too. BTW: Is there e.g. a thread, where we can find a summary of the results from the last 4 years? We have the archive, but to have some kind of overview would be nice. 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 21 Author Share Posted February 21 37 minutes ago, Thomas Jentzsch said: BTW: Is there e.g. a thread, where we can find a summary of the results from the last 4 years? We have the archive, but to have some kind of overview would be nice. There's no individual thread or post with a summary of Years 1-4 but I'll put one together after the Awards are over. 🙂 - James 2 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 22 Author Share Posted February 22 6 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 24 Author Share Posted February 24 4 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 24 Author Share Posted February 24 3 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 26 Share Posted February 26 365... 4 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted February 26 Author Share Posted February 26 5th ANNUAL ATARI HOMEBREW AWARD RESULTS!! Thank you to everyone who tuned in to watch the event live, everyone had an amazing time! If you missed it, below is the video and a link to the list of winners and runners up!WATCH EVENT: https://youtu.be/c_4lKhBXWhM FULL RESULTS: https://forums.atariage.com/topic/347449-5th-annual-atari-homebrew-awards-voting-information-discussion/?do=findComment&comment=5216388 - James 7 2 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted February 27 Share Posted February 27 Congrats James on another successful Atari awards. Thank you again for all your ongoing efforts during the year to keep them alive! 7 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted February 27 Share Posted February 27 9 hours ago, mksmith said: Congrats James on another successful Atari awards. Thank you again for all your ongoing efforts during the year to keep them alive! Seconded. The awards (and the stream!) have been a huge service for the Atari community. I appreciate all of the work that you put into both! 5 1 Quote Link to comment Share on other sites More sharing options...
+TwentySixHundred Posted February 28 Share Posted February 28 Managed to watch the replay of the awards on Twitch today. Great as always and a congratulations to all the winners and runner ups. 1 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted March 12 Author Share Posted March 12 I'm back from a business trip to Melbourne Australia where I was lucky enough to meet up with Matt Smith @mksmith! I also checked out an arcade in Melbourne but I'll leave my review until the next show. Below are some pics of a couple of the games I played while I was there. Now that I'm back I will start working on my Atari 2600 project and doing some shows here and there, but ZPH is still on break for a little while. Today I started catching up to the Atari Homebrew release lists for all the new games and updates that happened while I was gone. There will probably be a show this coming Tuesday so keep your eyes open for that! - James 13 Quote Link to comment Share on other sites More sharing options...
Albert Posted March 12 Share Posted March 12 That's awesome! Glad you and Matt were able to meet up! And that you were able to hit an arcade in Melbourne as well! Very cool. ..Al 6 Quote Link to comment Share on other sites More sharing options...
